Buy "weiand" online - search for the best price - compare prices
Page (3 of 12)
1 2 3 4 5 6 7 |
Weiand Action +Plus; Water Pump - 8210WIN
167.99
167.99
Weiand's light weight, performance aluminum mechanical Action-Plus water pumps give a weight saving of 30 percent to 50 percent over stock cast-iron pumps. These pumps feature a premium quality bearing and seal that have twice the load capacity of stock pumps. Weiand's exclusive housing counter bore keeps the bearing form walking out. All pumps are designed with the necessary bracket bosses and water connections to fit popular street applications.Product Features:Fits Later Applications w/Water Inlet On LH SideStreet PerformanceHeavy Duty Shaft w/5/8 in. PilotSix-Blade Stamped SteelAnti-Cavitation Impeller100 Percent Leak Tested. Most Cooling & Water Pumps products are available for in-store pickup from Advance Auto Parts.
Weiand Action +Plus; Water Pump - 8211P
296.99
296.99
Weiand's light weight, performance aluminum mechanical Action-Plus water pumps give a weight saving of 30 percent to 50 percent over stock cast-iron pumps. These pumps feature a premium quality bearing and seal that have twice the load capacity of stock pumps. Weiand's exclusive housing counter bore keeps the bearing form walking out. All pumps are designed with the necessary bracket bosses and water connections to fit popular street applications.Product Features:Fits Later Applications w/Water Inlet On LH SideStreet PerformanceHeavy Duty Shaft w/5/8 in. PilotSix-Blade Stamped SteelAnti-Cavitation Impeller100 Percent Leak TestedBearing Shaft And Seal. Most Cooling & Water Pumps products are available for in-store pickup from Advance Auto Parts.
Weiand Action +Plus; Water Pump - 8211WIN
190.99
190.99
Weiand Action +Plus; Water Pump - 8215P
168.99
168.99
Weiand Action +Plus; Water Pump - 9208P
144.99
144.99
Weiand's light weight, performance aluminum mechanical Action-Plus water pumps give a weight saving of 30 percent to 50 percent over stock cast-iron pumps. These pumps feature a premium quality bearing and seal that have twice the load capacity of stock pumps. Weiand's exclusive housing counter bore keeps the bearing form walking out. All pumps are designed with the necessary bracket bosses and water connections to fit popular street applications.Product Features:Twisted Snout Water Pump Design For Updated StyleStreet PerformanceHeavy Duty Shaft w/5/8 in. PilotSix-Blade Stamped SteelAnti-Cavitation Impeller100 Percent Leak Tested. Most Cooling & Water Pumps products are available for in-store pickup from Advance Auto Parts.
Weiand Action +Plus; Water Pump - 9212P
136.99
136.99
Weiand Action +Plus; Water Pump - 9240P
139.99
139.99
Weiand Action +Plus; Water Pump - 9242P
144.99
144.99
Weiand Air Cleaner Replacement Filter Element - 90633
41.99
41.99
Product Features:Air Cleaner Replacement Filter Element. Most Rectangular Air Filters products are available for in-store pickup from Advance Auto Parts.
Weiand Air Scoop - 7223
246.99
246.99
Highly polished cast aluminum castings look great on a supercharger installation or can be used on a carburetor alone.Product Features:Aluminum CastingsBases Are AdjustableBall-Bearing Butterfly AssemblyCenter-To-Center Carburetor SpacingLooks Great On A SuperchargerCan Be Used On Carburetor AloneIncludes Air CleanerAll Hardware Included. Most Air Cleaner Assemblies products are available for in-store pickup from Advance Auto Parts.
Weiand Bolt Kit - 6991
35.99
35.99
Product Features:Bolt Kit. Most Supercharger Parts products are available for in-store pickup from Advance Auto Parts.
Weiand Bolt Kit - 6992
48.99
48.99
Weiand Coupler - 7034
156.99
156.99
Product Features:Coupler. Most Supercharger Parts products are available for in-store pickup from Advance Auto Parts.
Weiand Coupler - 7035
176.99
176.99
Weiand Emission System Water Outlet - 6200
115.99
115.99
Features two threaded bosses for temp control switch satin finish.Product Features:Emission System Water Outlet. Most Thermostats, Gaskets & Housing products are available for in-store pickup from Advance Auto Parts.
Weiand Emission System Water Outlet - 6201WIN
98.99
98.99
Weiand Gasket - 7158WIN
10.99
10.99
Product Features:Gasket. Most Supercharger Parts products are available for in-store pickup from Advance Auto Parts.
Weiand Gasket - 7159WIN
6.99
6.99
Weiand Gasket - 93333
22.99
22.99
Weiand Hi-Ram; Intake Manifold - 1981
363.99
363.99
Product Features:Square Flange Carburetor MountingSpecial D-Shaped Port Runner DesignLarge Plenum Chamber. Most Intake Manifold Hardware products are available for in-store pickup from Advance Auto Parts.
Weiand Hi-Ram; Intake Manifold - 1984
338.99
338.99
Weiand Hi-Ram; Intake Manifold - 1985
360.99
360.99
Weiand Hi-Ram; Intake Manifold - 1988
338.99
338.99
Weiand Hi-Ram; Intake Manifold - 1993
380.99
380.99
Weiand Hi-Ram; Intake Manifold - 1994
442.99
442.99
Page (3 of 12)
1 2 3 4 5 6 7 |
