Buy "volant performance" online - search for the best price - compare prices
Page (3 of 3)
1 2 3 |
Volant PowerCore Cold Air Intake GMC Yukon 6.2L 09-12
350.99
350.99
Volant PowerCore Cold Air Intake GMC Yukon 62L 09The New PowerCore Filter is the most revolutionary on the market Coming from the famous manufacture by Donaldson with Volants specifications the PowerCore uses advanced UltraWeb NanoFiber technology This material is a highquality synthetic that wont deteriorate as easily as traditional paper element and cottonguaze filter media while also providing vastly improved filtration up to 9999 In addition its water resistant and never needs oiling The PowerCore works by directing air into the front of the filter where it is channeled into its fluted design The channels are alternately sealed allowing air to enter through an open flute and forcing it to exit out and adjacent flute This allows the air to be filtered in one pass through the UltraWeb NanoFiber media with less restriction allowing clean air to enter your engine for increased airflow and higher filtration efficiencey This technology allows the PowerCore air filter to include a 4 year or 100000 miles warranty when used in urban conditionsWith the evolving industry of aftermarket parts more and more companies revolutionize everyday mod all car enthusiast look for Volant Air Filters are setup to display their own CrossLink polyethylene box which is engineered to each specific application for low restriction and an increase in air volume With this air filter box from Volant Performance the simply does what it was engineered for it insulates and protects the filter from engine heat moisture dust and debris to provide colder air to the engine for an increase in horsepowerAlong with the Air Filter Box this system is stratigically engineered for the use of sound baffles and awkward bends restricting flow from the factory air inlet ducts The Volant CrossLink polyethylene air ducts are sculptured to give the engine less restrictive breathing Incorporating larger diameters and unique bends that cant be duplicated with metal ducts allow for maximum airflow velocity and throttle responseTo keep up with the maintance Volant Performance provides their own ways to keep clean The Pro 5 comes with many of the intakes which contain cleanable and reusable high grade cotton filter media with fivelayers of protection It reduces air restriction and increases engine output by using precision pleat geometry that optimizes airflow throughout the intake system
Page (3 of 3)
1 2 3 |
