Buy "vermont american" online - search for the best price - compare prices
Page (9 of 12)
5 6 7 8 9 10 11 12 |
Vermont American High Carbon Steel Machine Screw Tap Bottoming 10-24NC - Carded - VER20262
3.01
3.01
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 25. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Bottoming 10-32NF - Carded - VER20263
3.01
3.01
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 21. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Bottoming 12-24NC - Carded - VER20264
3.16
3.16
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 16. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Bottoming 6-32NC - Carded - VER20260
2.76
2.76
20260 Tap High Carbon Steel Bottoming 6-32 NC Card For cutting all types of internal threadsStandard pipe and metricMade to exacting specificationsTough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap 20260 Tap Specs: High carbon steel bottoming 6-32 NC card Drill size: 36. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Bottoming 8-32NC - Carded - VER20261
2.90
2.90
20261 Tap High Carbon Steel Bottoming 8-32 NC Card For cutting all types of internal threadsStandard pipe and metricMade to exacting specificationsTough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap 20261 Tap Specs: High carbon steel bottoming 8-32 NC card Drill size: 29. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 10-24NC - Carded - VER20062
3.10
3.10
20062 Tap High Carbon Steel Plug 10-24 NC Card For cutting all types of internal threadsStandard pipe and metricMade to exacting specificationsTough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap 20062 Tap Specs: High carbon steel plug 10/24 NC card Drill size: 25. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 10-32NF - Carded - VER20063
3.19
3.19
20063 Tap High Carbon Steel Plug 10-32 NF Card For cutting all types of internal threadsStandard pipe and metricMade to exacting specificationsTough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap 20062 Tap Specs: High carbon steel plug 10-32 NF card Drill size: 21. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 12-24NC - Carded - VER20064
3.12
3.12
20064 Tap High Carbon Steel Plug 12-24 NC Card For cutting all types of internal threadsStandard pipe and metricMade to exacting specificationsTough carbon Tool steel for long lifeCut cleaner more accurate threads and lasts longerright-hand thread taps in Plug, Taper and Bottoming stylesDrill size permanently marked on each tap. 20064 Tap Specs: High Carbon Steel Plug 12-24 NC CardDrill Size: 16? 20064 Tap High Carbon Steel Plug 12-24 NC Card For cutting all types of internal threadsStandard pipe and metricMade to exacting specificationsTough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap 20064 Tap Specs: High carbon steel plug 12-24 NC card Drill size: 16. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 14-20NS - Carded - VER20065
3.41
3.41
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 10. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 4-36NS - Carded - VER20057
2.84
2.84
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 44. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 5-40NC - Carded - VER20059
2.88
2.88
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 38. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 6-32NC - Carded - VER20060
2.88
2.88
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 36. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Plug 8-32NC - Carded - VER20061
2.94
2.94
For cutting all types of internal threads Standard pipe and metric Made to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-hand thread taps in plug, taper and bottoming styles Drill size permanently marked on each tap Drill size: 29. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Machine Screw Tap Taper 10-32NF - Carded - VER20163
2.99
2.99
Vermont American High Carbon Steel Machine Screw Tap Taper 8-32NC - Carded - VER20161
2.87
2.87
Vermont American High Carbon Steel Metric Thread Pipe Tap Plug 1/8 in. - 28 BSP - VER21181
5.06
5.06
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tapFor foreign cars, motorcycles and machinery Popular plug style tap Drill size 5/16. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Spark Plug Tap Plug 10mm - 1.00 - VER21140
5.38
5.38
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tapFor foreign cars, motorcycles and machinery Popular plug style tapDrill size 23/64. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Spark Plug Tap Plug 14mm - 1.25 - VER21152
8.49
8.49
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tap For foreign cars, motorcycles and machinery Popular plug style tap Drill size 33/64. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Spark Plug Tap Plug 18mm - 1.50 - VER21164
12.13
12.13
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tap For foreign cars, motorcycles and machinery Popular plug style tap Drill size 21/32. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Standard Tap Plug 10mm - 1.25 - VER21141
5.38
5.38
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tapFor foreign cars, motorcycles and machinery Popular plug style tap. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Standard Tap Plug 10mm - 1.50 - VER21142
5.38
5.38
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longer Right-Hand thread taps in Plug, Taper and Bottoming styles Drill size permanently marked on each tap For Foreign cars, motorcycles and machinery Popular plug style tap Drill Size 11/32. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Standard Tap Plug 11mm - 1.50 - VER21144
5.89
5.89
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tap For foreign cars, motorcycles and machinery Popular plug style tap Drill size 3/8. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Standard Tap Plug 14mm - 2.00 - VER21154
8.49
8.49
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tap For foreign cars, motorcycles and machinery Popular plug style tap Drill size 15/32. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Standard Tap Plug 16mm - 1.50 - VER21158
9.76
9.76
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tapFor Foreign cars, motorcycles and machinery Popular plug style tap Drill size 37/64. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Vermont American High Carbon Steel Metric Thread Standard Tap Plug 16mm - 2.00 - VER21160
9.76
9.76
For cutting all types of internal threadsStandard pipe and metricMade to exacting specifications Tough carbon tool steel for long life Cut cleaner more accurate threads and lasts longerRight-hand thread taps in plug, taper and bottoming stylesDrill size permanently marked on each tap For foreign cars, motorcycles and machinery Popular plug style tap Drill size 35/64. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Page (9 of 12)
