Buy "tif" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
TIF High Side R12 and R22 Auto Glycerine Refrigerant Gauge - TIF9632R
39.99
39.99
63mm, glycerin-filled Zero-Adjustable high side gaugePSI readingsR12, R22 and R502 readings in degrees Fahrenheit. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF IMMERSION PROBE - TIF7004
43.92
43.92
Degrees F or degrees C selectable with a very wide temperature sensing range Auto Zero each reading with display updates 3 times per second Field calibratable, interchangeable probes Included are three different probes for testing different materials or sources 9V Battery powered The TIF model 7000, the original TIF Thermometer, comes with 3 different probes.? The first is the Air Probe which can be used for instant readings of air temperatures from -40 degrees F to over 1000 degrees F.? The second probe, the Surface Probe, is used for quick surface readings from -40 degrees F to 1999 degrees F.? The Immersion probe tests liquid temperature from -40 degrees F to 500 degrees F.? Accuracy: +/-1%, +/- digit (32 degree to 212 degree F). Custom fitted ABS carrying case.? Wide sensing range.? Super fast response.?. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF Infrared Phototachometer - TIF780
156.00
156.00
Memory Hold Button On Target indicator Low battery indicator, auto power offMeasures RPM up to 20,000 with 1 RPM resolution High and Low ranges Infrared technology makes the 780 accurate, convenient and easy to use. The Infrared beam is not affected by ambient light, and the non-contact design results in no torque loss for true precision.? Quartz crystal ensures accuracy. Features 4-1/2 digit LCD. Measures RPM on drills, saws, hones, gears, motors, engines, fans, compressors, generators, pulleys and grinding wheels. Specifications: Range: Low. 0-200 RPMHigh: 0-20,000 RPM Resolution: Low and High 1 RPM Accuracy: 1 % of reading Operating Temp: 32 degrees to 125 degrees F (0 degrees to 52 degrees C) Power Supply: (1) 9V battery Battery Life: 100 hours Dimensions: 6.5" x 2.5" x 1.7", (16.5 x 6 x 4cm) Weight: 8.5 oz (238 g). Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF Infrared Thermometer Pro - TIF7610
51.79
51.79
SoC (System-on-a-chip) Technology, complete infrared design incorporated on a single chip, creating compact and lightweight designInnovative optical lens - high accurate measurements over wide temperature range; 10: 1 distance to spot (D: S) ratioLaser pointer simply point at desired target and press trigger for temperature readingVisual low battery indicators; requires two "AAA" batteriesMeasurement range: -76 to +932? F (-60 to +500? C) To measure a surface temperature, the user aims the IR Thermometer at the target, presses a button, and reads the temperature display. The device has an optical lens that collects the radiated infrared energy from the object and focuses it on the detector. The detector converts the energy into an electrical signal that's amplified and displayed as a temperature reading. An infrared thermometer measures temperature by sensing the magnitude of radiated energy at infrared frequencies. Using this data and the actual temperature of the detector, the thermometer calculates the temperature of the surface that emitted the energy. Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
TIF Infrared Thermometer Pro D:S 12:1 - TIF7612
73.09
73.09
SoC (System-on-a-chip) Technology - complete infrared design incorporated on a single chip, creating compact and lightweight designInnovative optical lens - high accurate measurements over wide temperature range; 12: 1 distance to spot (D: S) ratioTemperature modes - maximum (MAX), minimum (MIN), difference (DIF) and average (AVG) temperature modesHigh and low pass filters with audible alarms for out of range measurementsExternal temperature port can extend the temperature up to 1999 degrees Fahrenheit To measure a surface temperature, the user aims the IR Thermometer at the target, presses a button, and reads the temperature display. The device has an optical lens that collects the radiated infrared energy from the object and focuses it on the detector. The detector converts the energy into an electrical signal that's amplified and displayed as a temperature reading. An infrared thermometer measures temperature by sensing the magnitude of radiated energy at infrared frequencies. Using this data and the actual temperature of the detector, the thermometer calculates the temperature of the surface that emitted the energy.? . Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
TIF Infrared Thermometer Pro D:S 20:1 - TIF7620
103.49
103.49
SoC (System-on-a-chip) Technology - complete infrared design incorporated on a single chip, creating compact and lightweight designInnovative optical lens - high accurate measurements over wide temperature range; 20: 1 distance to spot (D: S) ratioTemperature modes - maximum (MAX), minimum (MIN), difference (DIF) and average (AVG) temperature modesHigh and low pass filters with audible alarms for out of range measurementsExternal temperature port can extend the temperature up to 1999 degrees Fahrenheit To measure a surface temperature, the user aims the IR Thermometer at the target, presses a button, and reads the temperature display. The device has an optical lens that collects the radiated infrared energy from the object and focuses it on the detector. The detector converts the energy into an electrical signal that's amplified and displayed as a temperature reading. An infrared thermometer measures temperature by sensing the magnitude of radiated energy at infrared frequencies. Using this data and the actual temperature of the detector, the thermometer calculates the temperature of the surface that emitted the energy. Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
TIF Low Side R12 and R22 Auto Glycerine Refrigerant Gauge - TIF9622B
39.99
39.99
63mm, glycerin filled Zero-Adjustable low side compound gaugePSI readingsR12, R22 and R502 readings in degrees Fahrenheight. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF MPC Style Multi-Gas Refrigerant Leak Detector - TIFXP1A
224.99
224.99
Super sensitive leak detector of ALL halogen refrigerantsTwo second warm-up time for instant readinessLeak sampling up to 2000 times per second at the tipLeak size and severity indicator with 18 alarm levels3 year warranty. The revolutionary new "Generation X" line of TIF refrigerant leak detectors brings you tomorrow's technology today. We not only changed the way our leak detectors look, but the way to look at leak detectors. Innovative MPC circuitry and Advanced Digital Signal Processing monitor the sensing tip up to 2000 times per second. Automatic reset, true mechanical pump and visual indicators speed and simplify leak searches. A completely re-designed sensing tip increases sensitivity, improves reliability and lasts twice as long as its predecessor. This results in fewer comebacks, less hassle and lower maintenance costs. We are so confident in the design and quality of these detectors that they are backed by a warranty of up to 3 Years! Specifications: Power Supply: 3VDC; 2 "C" cell alkaline batteries Ultimate sensitivity: XP-1 - Less dm 0.1 oz/yr (3gr/yr) Sensing tip life: Approx. 20 Hours Operating temp: 30o to 125o F (0o to 52o C) Battery life: XP-1 - Approx. 30 hrs Duty cycle: continuous Response time: instantaneous Reset Time: One second Warm up time: approx. 2 seconds Unit weight: 1.2 lbs. (560 grams) Unit dimensions: 9" x 2.25" x 2.25" ("22.9cm x 5.7cm x 5.7cm) Fixed probe length: 14" (35.5cm) Tri-color, Six segment visual leak size indicator displays 18 alarm levels Seven levels of sensitivity adjustment provide an increase of up to 64x Battery test function with true voltage indicationMute feature silences audible alarm True mechanical pump provides positive airflow through sensing tipOne touch reset Tactile keypad controls Three year warranty,. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF Pocket IR Thermometer - TIF7201
22.19
22.19
Backlit LCD display with dual readingsCelsius / Fahrenheit switch and MAX function Auto power off after 15 seconds Battery level indication Distance to spot (D/S): 1: 1 This Soc technology, System-on-a-chip technology is compact and lightweight. Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
TIF Refrigerant Electronic Sightglass - TIF4000A
304.59
304.59
Optimizes refrigerant charge for maximum coolingOperates on any metal tubing4' cordOperates through use of ultrasonicsEliminates the need for an optical sight glass Checks for refrigerant flood back. Built into ABS carrying case. Operating temperature: 32 degrees to 120 degrees F. Response time: instantaneous. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF Refrigerant Leak Detector - TIFRX-1A
174.99
174.99
Detects leaks of ALL halogenated refrigerants, including R-410AAdvanced Digital Signal Processing, monitors sensing tip up to 2000 times per secondVisual leak size indicatorsErgonomic design for one handed useTwo sensitivity levels Powerful and sensitive refrigerant leak detection in a compact tool. Rubber cushion grip handle. True Mechanical Pump. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF REPLACEMENT FILTER - TIF8501
24.09
24.09
TIF SENSING TIP - TIF560
291.59
291.59
Optimizes refrigerant charge for maximum coolingOperates on any metal tubing4' cordOperates through use of ultrasonicsEliminates the need for an optical sight glass Checks for refrigerant floodback. Built into ABS carrying case. Operating temperature: 32 degrees to 120 degrees F. Response time: instantaneous. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF Slimline Electronic Refrigerant Charging Scale - TIF9010A
205.99
205.99
Touch Key controlsThree display modes - lbs./oz.; Decimal lbs.; kilogramsVery high resolution: 0.1 oz./0.005 lbs./2 gramsExtreme accuracy: ? +/-0.5% of readingCan be used with all type of refrigerants This compact and portable refrigerant scale brings greater performance, reliability and usability to the trade. With the greatest resolution in the industry, and no compromise on capacity, this unit offers features and specs that you don't want to do without.? Other features include: auto zero, 110 pound/50kg capacity and removable control box with prop stand/hanging hook.? Compatible with TIF9020 for automatic capability. Operating temp: 32 degrees to 120 degrees F. Power supply: 9VDC. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF Super Scanner Refrigerant Leak Detector - TIF5750A
357.99
357.99
Detects ALL halogenated refrigerants including R-410A Detachable high efficiency probe? Reset Button for instant re-calibration Two Sensitivity positions, including our unique scan modeLED Leak Size Indicators show leak severity Locates A/C leak sources fast! Full featured yet easy to use, the original TIF detector. The 5750A offers the detachable, flexible probe with micro-pump, leak intensity indicators, and all the features you have come to know and trust. Ultimate sensitivity: less than 0.1 ounces per year. Includes the patented SCAN mode that revolutionized leak detection. Constant power indication. Carrying case and spare sensing tip included. One year warranty. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
TIF ULTRASONIC SENSORS - TIF4004
98.59
98.59
Tips for TIF Refrigerant Leak Detectors - TIF555
41.09
41.09
Page (2 of 2)
1 2 |
