Buy "thexton" online - search for the best price - compare prices
Page (3 of 4)
1 2 3 4 |
Thexton Lube Tube Extension Kit - THX471
33.29
33.29
9" extension reaches grease fittings in restricted or limited access areasMolded handle provides leverage for attaching grease coupler and removing from difficult fittingsLube Tube Kit includes Part No. 418 Right Angle Grease Coupler and a standard grease couplerStandard grease zerk in handle fits all grease guns Can't reach all the grease fittings on some of the vehicles front suspension or drive shafts?? Add this extension kit to any hand or pneumatic grease gun for improved reachability. Most Oil & Lube Tools products are available for in-store pickup from Advance Auto Parts.
Thexton Master Cylinder Bleeder Kit - THX346
10.89
10.89
Bleeds master cylinder on or off the carThe kit contains adapters to fit most domestic carsIncluded in a storage box with the ability to hang-up and full instructions This master cylinder bleeder kit makes bleeding a hassle-free job.? It's simple and economical in cost.? Has the same performance as an expensive, full-size power bleeder.? So turn your brake bleeding job into a one-man, 5-minute operation with this kit. ? . Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Petcock Socket Set - THE485
15.99
15.99
MPN #THE485. Thexton Petcock Socket Set. Most Socket Sets products are available for in-store pickup from Advance Auto Parts.
Thexton Plug All Stoppers - THE312
13.99
13.99
MPN #THE312. Thexton Plug All Stoppers. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Plug-All Vacuum and Fuel Line Stoppers - THX312
10.47
10.47
Plugs fit 1/8", 3/16", 1/4", 5/16", 3/8" and 1/2" hosesTapered caps close tubes from 1/8" to 1/2"Use during tune-ups, vacuum tests and more. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Radiator Petcock Socket Set - THX485
13.29
13.29
1/4" drive set includes a steel universal socket to fit radiators, engine blocks, storage tanks, etc. with an O-ring to hold a 7/8" wrench in placeSet also has a molded plastic socket to fit narrow wing plastic drain fittings, both plug and flow-through typesSocket comes with an O-ring to hold a 7/8" wrench in place Stop using pliers to open and close petcock drains.? This socket is especially made for radiator and engine petcock drains and won't crush the drain tube. Most Socket Sets products are available for in-store pickup from Advance Auto Parts.
Thexton Refractometer - THE105
120.99
120.99
MPN #THE105. Thexton Refractometer. Most Antifreeze Flush Kits products are available for in-store pickup from Advance Auto Parts.
Thexton Right Angle Grease Coupler - THX418
8.69
8.69
Fits grease fittings in confined areas, such as lower ball jointsSpecial seal and slot in coupler housing provides 90 degree accessFits all standard grease guns - can be used as general purpose grease coupler. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Small Fastener Removal Tool - THX482
55.89
55.89
New tool uses air power to break loose, frozen or rusted fastenersHardened steel body with 3/8" drive, adapter chuck and four screw bits3/8" drive allows using hex or specialized sockets to remove stubborn nuts and boltsProfessional Tool & Equipment News "Innovation Tool" award Here's the most recent and innovative method of removing broken or frozen fasteners! Air Hammer required. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Small Parts Cleaning Basket - THX405
32.77
32.77
Prevents loss of small carburetor, FI, or transmission partsWire mesh with galvanized steel cover that slides tightly over basketIncludes hook for hanging basket in solution for soaking parts This basket will allow soaking, cleaning, rinsing and air drying small components. Keep small pieces and parts from getting lost when cleaning!. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Spare Tire Removal Tool Kit - THX497
123.99
123.99
Saves time by not having to locate, remove and then replace tools supplied with vehicle, especially if the vehicle is loaded up with a family headed for vacationSafety - allows tow truck driver to get the job done and get off the side of the road in less timeSaves money by allowing driver or technician to get on to the next call or repair by not having to deal with vehicle supplied toolsKit is complete in heavy nylon pouch that fits easily behind the seat in the truck or in the tool boxFits most SUV's, pickups and vans This Spare Tire Removal Tool Kit reaches up to 32" to lower spare tire from undercarriage of pickups, vans and SUVs. Kit includes a hand crank and six different zinc-plated steel tools to fit most pickup, van and SUV-type vehicles. No need to locate tools supplied by vehicle manufacturer, because the Spare Tire Removal Tool Kit contains all the tools you need. No additional tools are required for lowering the spare. Includes heavy-duty nylon pouch. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Spare Tire Tool - THE497
144.99
144.99
MPN #THE497. Thexton Spare Tire Tool. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Spark Plug Installer/Remover Kit - THX492
12.49
12.49
Start and remove spark plugs in deeply recessed cylinder spark plug holesSet includes 3" and 6" plug starters6" length is designed for coil-on plug applications and other engines with recessed spark plugsThe shorter version is for other applications where space is limited Can't reach or safely start spark plugs in deep recessed holes? This kit contains the tools to fit most spark plugs especially coil-on-plug.? Tools are made of flexible, heat-resistant plastic to reach into recessed areas or over, under and around hot manifolds.? Shaft is stepped to grip insulator.? Non-slip, black grip surface for sure handling.?. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Spark Plug Starter Set - THE492
12.99
12.99
MPN #THE492. Thexton Spark Plug Starter Set. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Spark Plug Wire Puller - THE334
34.99
34.99
MPN #THE334. Thexton Spark Plug Wire Puller. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Thexton Spark Plug Wire Puller - THX334
18.89
18.89
Firmly grips frozen boots, removes with a twist and a pullEliminates wire separationFront tabs grip under boot, jaws secure sidesCompact to fit tight placesAll steel with vinyl grips. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Thexton Spark Tester - THE458
29.99
29.99
MPN #THE458. Thexton Spark Tester. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Term. Release Kit III - THE495
144.99
144.99
MPN #THE495. Thexton Term. Release Kit III. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Thexton Term. Removal Tool - THE582
20.99
20.99
MPN #THE582. Thexton Term. Removal Tool. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Thexton Term. Removal Tool - THE583
20.99
20.99
MPN #THE583. Thexton Term. Removal Tool. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Thexton Term. Removal Tool - THE584
20.99
20.99
MPN #THE584. Thexton Term. Removal Tool. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Thexton Terminal Release Kit II - THE595
79.99
79.99
MPN #THE595. Thexton Terminal Release Kit II. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Thexton Terminal Release Tool Kit - THX493
49.56
49.56
Tools quickly and easily disassemble automotive connectors to remove faulty terminalsEliminates connector damage Includes seven terminal tools Disassemble vehicle connectors in a snap!? Eliminates connector damage and is easier and faster than prying connectors apart with a screwdriver.? Includes seven terminal tools to fit the most common automotive connectors.? Each tool has a specially designed tip to depress the connector locking tab that secures the terminal. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Throttle Depressor - THE592
61.99
61.99
MPN #THE592. Thexton Throttle Depressor. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Thexton Transmission Cooler Line Plugs - THX319
12.49
12.49
Eliminates loss of transmission fluid and messy, slippery floorsFit 1/4", 5/16", and 3/8" tubes, transmission cooler line plugs seal male or female fittings16" chain keeps plugs together and serves as a tube supportAllows vehicle to be driven from service bay with radiator off When working on the transmission or radiator, be sure to have these handy.? The plug seals male or female fittings just like faucet valve.? You don't have to worry about transmission fluid leaking out everywhere. Works great, and are easy to install. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Page (3 of 4)
1 2 3 4 |
