Buy "tera manufacturing, inc." online - search for the best price - compare prices
Page (2 of 19)
1 2 3 4 5 6 |
TeraFlex 1/2" Rear Guide and Leveling Spacer, Single
37.99
37.99
TeraFlex 1/2" Rear Guide and Leveling Spacer, Single Fits: 2007-2013 Jeep Wrangler JK & Rubicon Models 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Models Special Note: Spacers are sold individually. Product Overview: This TeraFlex 1/2" Spacer is the perfect solution to level your Jeep if it is dipping in the front from the weight of a winch, sagging, or to level out a loaded vehicle. The spacers are designed to work in stock configuration, or with a lifted vehicle. Kit Includes: 1 Coil Spring Spacer Kit Specifications: Installation Difficulty: Easy Installation Time: 30 minutes on average Weight: 1 lb. Length: 9" Width: 7" Height: 7" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 1/2" T - Case Lowering Kit
30.99
30.99
Fits:1997-2002 Jeep Wrangler TJ½" T-Case Lowering KitDesigned to reuse the factory bolts. Fits Wrangler TJs 1997-2002. Installation Difficulty: Easy.Installation Difficulty: Easy
TeraFlex 1/4" Lowering Sleeve Spacer For Front Speedbump
4.99
4.99
TeraFlex 1/4" Lowering Sleeve Spacer For Front Speedbump Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK 1/4" Lowering Sleeve Spacer for Front SpeedbumpUsed with Universal SpeedBump Bumpstops. Sold individually Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 14" FlexArm Tube Length
81.99
81.99
Fits:Universal Application14" FlexArm Tube LengthTeraFlex offers standard lengths of FlexArm tubing pre-tapped for our large Monster ends (1-1/4" x 12tpi threads). These can be used for custom suspension links or torque arms.The DOM tubing is 1.75" OD and .281 wall for superior strength to meet the needs of high power and torque applications. Tube length is measured as the actual length of tube.
TeraFlex 2.5" - 3" Front Coil Springs, 1 Pair
227.99
227.99
TeraFlex 2.5" - 3" Front Coil Springs, 1 Pair Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK 2.5" Front Coil Springs, 1 Pair - 4 Door 3.0" Front Coil Springs, 1 Pair - 2 Door One pair of TeraFlex manufactured front coil springs for the JK Wrangler and JK Wrangler Unlimited (Rubicon). Sold as a set of 2. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" - 3" Rear Coil Springs, 1 Pair
227.99
227.99
TeraFlex 2.5" - 3" Rear Coil Springs, 1 Pair Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK 2.5" Rear Coil Springs, 1 Pair - 4 Door 3.0" Rear Coil Springs, 1 Pair - 2 Door One pair of TeraFlex manufactured rear coil springs for the JK Wrangler and JK Wrangler Unlimited (Rubicon). Sold as a set of 2. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Budget Boost Lift Kit without Shocks
259.99
259.99
TeraFlex 2.5" Budget Boost Lift Kit without Shocks Fits: 2007-2013 Jeep Wrangler JK & Rubicon Models 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Models Special Notes: Maximum Tire Size: 35" Aftermarket wheels with 4.5" backspacing or less are required. Product Overview: The TeraFlex 2.5" Budget Boost Lift Kit without Shocks is the most economical lift for your Wrangler JK. The budget boost is designed to lift your vehicle without many modifications. The budget boost will increase off-road performance. Kit Includes: 2 Front Coil Spring Spacers 2 Rear Coil Spring Spacers 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Sway Bar Links 2 Rear Brake Line Extensions Rear Track Bar Bracket Installation Hardware Kit Specifications: Installation Difficulty: Moderate Installation Time: 3 hours on average Weight: 25 lbs. Length: 16" Width: 12" Height: 10" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Front Leveling Spacer, 1 Pair
81.99
81.99
TeraFlex 2.5" Front Leveling Spacer, 1 Pair Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK 2.5" Front Leveling Spacer, 1 PairInstallation Difficulty: EasyInstallation Time: 1 Hour on AverageWeight: 4Length: 18Width: 14Height: 14These spacers are sold as a pair and will fit both 2 door JK Wranglers and 4 door JK Unlimiteds, and all JK Rubicon models. TeraFlex has the perfect solution to level your JK if it is dipping in the front from the weight of a winch, sagging, or to level out a loaded vehicle. These spacers are designed to work in stock configuration, or with a lifted vehicle. The spacers are available in 1/2", 1" or 2.5" lift increments depending on your needs. The rear spacer also incorporates our industry exclusive spring retainer and guide that helps to realign the spring to its proper location during extreme articulation without fear of the spring falling out. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Front Leveling Spacer, Single
42.99
42.99
TeraFlex 2.5" Front Leveling Spacer, Single Fits: 2007-2013 Jeep Wrangler JK & Rubicon Models 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Models Special Notes: Maximum Tire Size: 35" Spacers are sold individually. Product Overview: The TeraFlex 2.5" Front Leveling Spacer is the perfect solution to level your Jeep if it is dipping in the front from the weight of a winch, sagging, or to level out a loaded vehicle. These spacers are designed to work in stock configuration or with a lifted vehicle. Kit Includes: 1 Coil Spring Spacer Kit Specifications: Installation Difficulty: Difficult Installation Time: 6 Hour on average Weight: 2 lbs. Length: 9" Width: 7" Height: 7" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Performance Budget Boost Lift Kit with Adapters
340.99
340.99
TeraFlex 2.5" Performance Budget Boost Lift Kit with Adapters Fits: 2007-2013 Jeep Wrangler JK & Rubicon Model 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Model Special Notes: Maximum Tire Size: 35" Shocks are NOT included. Aftermarket wheels with 4.5" backspacing or less are required. Product Overview: The TeraFlex 2.5" Performance Budget Boost Lift Kit with Adapters is the most economical lift for the Wrangler JK. This kit is designed for you to lift your vehicle without many modifications. This kit will increase off-road performance. Kit Includes: Front Coil Spring Spacers Rear Coil Springs Spacers Front Shock Adapters Rear Shock Adapters Front Bump Stops Rear Bump Stops Rear Sway Bar Links Rear Brake Line Extensions Rear Track Bar Brackets Kit Specifications: Installation Difficulty: Moderate Installation Time: 3 hours on average Weight: 29 lbs. Length: 16" Width: 12" Height: 10" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Performance Budget Boost Lift Kit with Shocks
510.99
510.99
TeraFlex 2.5" Performance Budget Boost Lift Kit with Shocks Fits: 2007-2013 Jeep Wrangler JK & Rubicon Models Special Notes: Maximum Tire Size: 35" Aftermarket wheels with a 4.5" backspacing or less are required. Product Overview: The TeraFlex 2.5" Performance Budget Boost Lift Kit with Shocks is the most economical lift for your Wrangler JK. The budget boost is designed for owners who wish to lift their vehicle without many modifications. This budget boost kit will increase off-road performance. Kit Includes: 2 Front Shocks 2 Rear Shocks 2 Front Spacers 2 Rear Spacers 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Sway Bar Links Rear Track Bar Bracket Brake Line Extension Hardware Kit Specifications: Installation Difficulty: Medium Installation Time: 4 hours on average Weight: 49 lbs. Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Rear Guide & Leveling Spacer, 1 Pair
176.99
176.99
TeraFlex 2.5" Rear Guide & Leveling Spacer, 1 Pair Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK 2.5" Rear Guide & Leveling Spacer, 1 PairInstallation Difficulty: EasyInstallation Time: 1 Hour on AverageWeight: 8Length: 18Width: 14Height: 14These spacers are sold as a pair and will fit both 2 door JK Wranglers and 4 door JK Unlimiteds, and all JK Rubicon models. TeraFlex has the perfect solution to level your JK if it is dipping in the front from the weight of a winch, sagging, or to level out a loaded vehicle. These spacers are designed to work in stock configuration, or with a lifted vehicle. The spacers are available in 1/2", 1" or 2.5" lift increments depending on your needs. The rear spacer also incorporates our industry exclusive spring retainer and guide that helps to realign the spring to its proper location during extreme articulation without fear of the spring falling out. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Rear Guide and Leveling Spacer, Single
91.99
91.99
TeraFlex 2.5" Rear Guide and Leveling Spacer, Single Fits: 2007-2013 Jeep Wrangler JK & Rubicon Models 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Models Special Note: Spacers are sold individually. Product Overview: The TeraFlex 2.5" Rear Guide and Leveling Spacer is the perfect solution to level your Jeep if it is dipping in the front from the weight of a winch, sagging, or to level out a loaded vehicle. These spacers are designed to work in stock configuration or with a lifted vehicle. Kit Includes: 1 Coil Spring Spacer Kit Specifications: Installation Difficulty: Easy Installation Time: 30 minutes on average Weight: 4 lbs. Length: 9" Width: 7" Height: 7" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Rear Speedbump Bumpstops, Pair
99.99
99.99
TeraFlex 2.5" Rear Speedbump Bumpstops, Pair Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: TeraFlex brings to you, their SpeedBumps that are an innovative composite bumpstop system designed for high-speed, high-performance. The maintenance free, performance tuned microcellular polyurethane technology provides a simple installation with no further adjustment or tuning required for a lifetime of dedicated off road use. Order yours today! Installation Difficulty: Easy Installation Time: 2-4 Hours Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Suspension Lift Kit
479.99
479.99
TeraFlex 2.5" Suspension Lift Kit without Shocks Fits: 2007-2013 Jeep Wrangler JK & Rubicon Model Special Notes: Maximum Tire Size: 35" Wheel spacers TF-1055000, are required if stock wheels are used with this kit. Aftermarket wheels with 4.5" backspacing or less are required. Shocks NOT included. Product Overview: The TeraFlex 2.5" Suspension Lift Kit is an ultra lift kit for the serious, no-frills four-wheeling, reminiscent of the old days. Perfect for a daily driven Jeep Wrangler JK. Kit Includes: 2 Front Coil Springs 2 Rear Coil Springs 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Sway Bar Links 2 Rear Track Bar Brackets 2 Rear Brake Line Brackets Kit Specifications: Installation Difficulty: Medium Installation Time: 7 hours on average Weight: 56 lbs. Length: 24" Width: 12" Height: 8" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Suspension Lift Kit with Adapters
486.99
486.99
TeraFlex 2.5" Suspension Lift Kit with Adapters Fits: 2007-2013 Jeep Wrangler JK & Rubicon Model Special Notes: Maximum Tire Size: 35" Wheel spacers, TF-1055000, are required if stock wheels are used with this Lift Kit. Aftermarket wheels with 4.5" backspacing or less are required. Product Overview: The TeraFlex 2.5" Suspension Lift Kit with Adapters is an ultra lift kit for serious, no-frills four-wheeling, reminiscent of the old days. Perfect for a daily driven Jeep Wrangler JK. Kit Includes: 2 Front Coil Springs 2 Rear Coil Springs 2 Front Shock Adapters 2 Rear Shocks Adapters 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Sway Bar Links 2 Rear Track Bar Brackets 2 Rear Brake Line Brackets Kit Specifications: Installation Difficulty: Medium Installation Time: 7 hours on average Weight: 56 lbs. Length: 24" Width: 12" Height: 8" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
486.99
486.99
TeraFlex 2.5" Suspension Lift Kit with Adapters Fits: 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Model Special Notes: Maximum Tire Size: 35" Wheel spacers, TF-1055000, are required if stock wheels are used with this Lift Kit. Aftermarket wheels with 4.5" backspacing or less are required. Product Overview: The TeraFlex 2.5" Suspension Lift Kit with Adapters is an ultra lift kit for the serious, no-frills four-wheeling, reminiscent of the old days. Perfect for a daily driven Jeep Wrangler Unlimited JK. Kit Includes: 2 Front Coil Springs 2 Rear Coil Springs 2 Front Shock Adapters 2 Rear Shock Adapters 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Sway Bar Links 2 Rear Track Bar Brackets 2 Rear Brake Line Brackets Kit Specifications: Installation Difficulty: Medium Installation Time: 7 hours on average Weight: 56 lbs. Length: 24" Width: 12" Height: 8" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Suspension Lift Kit with VSS 9550 Shocks
730.99
730.99
TeraFlex 2.5" Suspension Lift Kit with VSS 9550 Shocks Fits: 2007-2013 Jeep Wrangler JK & Rubicon Models Special Notes: Maximum Tire Size: 35" Aftermarket wheels with 4.5" backspacing or less are required. Wheel spacers, TF-1055000, are required if stock wheels are used with this Lift Kit. On the 2012 and 2013 Jeep Wrangler JK models, you will need a Spacer Kit, TF-2610000, for the exhaust. Product Overview: The TeraFlex 2.5" Suspension Lift Kit with VSS 9550 Shocks is an ultra simple lift kit designed for the serious no-frills four wheeling reminiscent of the old days. Perfect for your daily driven Wranglers. Kit Includes: 2 Front VSS 9550 Shocks 2 Rear VSS 9550 Shocks 2 Front Coil Springs 2 Rear Coil Springs 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Brake Line Brackets 2 Rear Sway Bar Links Rear Track Bar Bracket Installation Hardware Kit Specifications: Installation Difficulty: Medium Installation Time: 7 hours on average Weight: 56 lbs. Length: 24" Width: 12" Height: 8" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
479.99
479.99
TeraFlex 2.5" Suspension Lift Kit without Shocks Fits: 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Model Special Notes: Maximum Tire Size: 35" Wheel spacers, TF-1055000, are required if stock wheels are used with this Lift Kit. Aftermarket wheels with 4.5" backspacing or less are required. Shocks NOT included. Product Overview: The TeraFlex 2.5" Suspension Lift Kit without Shocks is an ultra lift kit for the serious, no-frills four-wheeling, reminiscent of the old days. Perfect for a daily driven Jeep Wrangler JK. Kit Includes: 2 Front Coil Springs 2 Rear Coil Springs 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Sway Bar Links 2 Rear Track Bar Brackets 2 Rear Brake Line Brackets Kit Specifications: Installation Difficulty: Medium Installation Time: 7 hours on average Weight: 56 lbs. Length: 24" Width: 12" Height: 8" Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2.5" Suspension Lift Kit, with 9550 VSS Shocks
730.99
730.99
TeraFlex 2.5" Suspension Lift Kit with 9550 VSS Shocks Fits: 2007-2013 Jeep Wrangler Unlimited JK & Rubicon Model Special Notes: Maximum Tire Size: 35" Aftermarket wheels with 4.5" backspacing or less are required. Wheel spacers, TF-1055000, are required if stock wheels are used with this Lift Kit. Product Overview: This TeraFlex 2.5" Suspension Lift Kit is an ultra simple lift kit designed for the serious no-frills four wheeling reminiscent of the old days. Perfect for your daily driven Jeep Wrangler Unlimited JK Models. Kit Includes: 2 Front 9550 VSS Shocks 2 Rear 9550 VSS Shocks 2 Front Coil Springs 2 Rear Coil Springs 2 Front Bump Stops 2 Rear Bump Stops 2 Rear Brake Line Brackets 2 Rear Sway Bar Links Rear Track Bar Bracket Kit Specifications: Installation Difficulty: Medium Installation Time: 7 hrs. on Average Weight: 56 Length: 24 Width: 12 Height: 8 Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex 2" Budget Boost Leveling Spacer, Single
24.99
24.99
TeraFlex 2" Budget Boost Leveling Spacer, Single Fits: 1997-2006 Jeep Wrangler TJ & Rubicon Models 2004-2006 Jeep Wrangler Unlimited TJL & Rubicon Models 1993-1998 Jeep Grand Cherokee ZJ 1984-2001 Jeep Cherokee XJ (Front Only) Special Note: Spacers are sold individually. Product Overview: This TeraFlex Coil Spring Spacer is perfect to level your Jeep from sagging or from extra weight caused by heavy loads. Kit Includes: 1 Coil Spring Spacer Kit Specifications: 2" Coil Spring Spacer Years Covered: 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
TeraFlex 2" Budget Boost Lift Kit
142.99
142.99
TeraFlex 2" Budget Boost Lift Kit Fits: 1984-2001 Jeep Cherokee XJ Special Note: Maximum Tire Size: 30" Product Overview: The TeraFlex 2" Budget Boost Lift Kit is a simple and economical way to increase vehicle height by 1.5". Kits Includes: 2 Front Spring Spacers 2 Rear Shackles 4 Flat Washers 2 Bolts 2 Nuts Kit Specifications: Installation Difficulty: Moderate Installation Time: 2.5 hours on average Weight: 11 lbs. Length: 12" Width: 6" Height: 4" Years Covered: 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000 and 2001
142.99
142.99
TeraFlex 2" Budget Boost Lift Kit Fits: 1993-1998 Jeep Grand Cherokee ZJ Special Note: Maximum Tire Size: 30" This kit is NOT designed to be used in addition to an aftermarket suspension. Product Overview: The TeraFlex 2" Budget Boost Lift Kit is a simple and economical way to lift your Cherokee ZJ. This kit will provide 1.5" of lift. Kit Includes: 2 Front Coil Spring Spacers 2 Rear Coil Spring Spacers 2 Front Bump Stop Extensions 2 Rear Bump Stop Extensions 2 Front Bump Stop Bolts 2 Rear Bump Stop Bolts 4 Flat Washers Kit Specifications: Installation Difficulty: Moderate Installation Time: 2.5 hours on average Weight: 6 lbs. Length: 7" Width: 7" Height: 4" Years Covered: 1999, 2000, 2001, 2002, 2003 and 2004
308.99
308.99
TeraFlex 2" Budget Boost Lift Kit Fits: 2002-2007 Jeep Liberty KJ Special Notes: Maximum Tire Size: 29" Shock changes are NOT required with swaybars connected. Product Overview: The TeraFlex 2" Budget Boost Lift Kit has been designed for independent front suspension to give your Liberty KJ a 2" lift while maintaining a controlled and balanced ride. Kit Includes: 2 Front Strut Spacers 2 Rear Coil Spring Spacers 8 Nyloc Nuts 8 Flat Washers Installation Hardware Kit Specifications: Installation Difficulty: Moderate Installation Time: 2.5 hours on average Weight: 14 lbs. Length: 12" Width: 8" Height: 6" Years Covered: 2002, 2003, 2004, 2005, 2006 and 2007
274.99
274.99
TeraFlex 2" Budget Boost Lift Kit Fits: 2005-2010 Jeep Grand Cherokee WK 2006-2010 Jeep Commander XK Product Overview: The TeraFlex 2" Budget Boost Lift Kit is designed to give your Grand Cherokee WK and Commander XK some added lift and off-road ability. Because they have independent front suspensions, certain factors have to be addressed when creating a suspension lift. This kit is designed to gain the maximum lift without causing premature failure to the Independent Front Suspension axles and components. Kit Includes: 2 Front Strut Spacers 2 Rear Coil Spring Spacers (1 or 2 Piece Design) 2 (10mm x 75mm) Bolts & Washers 8 (12mm) Nuts 8 Flat Washers Kit Specifications: Installation Difficulty: Medium Installation Time: 2.5 hours on average Weight: 13 lbs. Length: 12" Width: 8" Height: 6" Years Covered: 2005, 2006, 2007, 2008, 2009 and 2010
Page (2 of 19)
1 2 3 4 5 6 |
