Buy "tera manufacturing, inc." online - search for the best price - compare prices
Page (19 of 19)
15 16 17 18 19 |
TeraFlex VSS Front 9550 Shock Absorber, 3-4" Lift
62.99
62.99
Fits:1997-2006 Jeep Wrangler TJ & Unlimited (Rubicon)VSS Front 9550 Shock Absorber, 3-4" Lift Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability.
TeraFlex VSS Front 9550 Shock Absorber, 6" Lift
62.99
62.99
TeraFlex VSS Front 9550 Shock Absorber, 6" Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK VSS Front 9550 Shock Absorber Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
62.99
62.99
Fits:1997-2006 Jeep Wrangler TJ & Unlimited (Rubicon)VSS Front 9550 Shock Absorber, 6" Lift Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability.
TeraFlex VSS Front 9550 Shock Absorber, 6+" Lift
60.99
60.99
TeraFlex VSS Front 9550 Shock Absorber, 6+" Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK VSS Front 9550 Shock Absorber, 34.90 Ext, 20.55 Col, 6+" LiftInstallation Difficulty: EasyInstallation Time: 0.5 Hours on AverageWeight: 6Length: 24Width: 3Height: 3Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex VSS Rear 9550 Shock Absorber, 6" Lift
62.99
62.99
TeraFlex VSS Rear 9550 Shock Absorber, 6" Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK VSS Rear 9550 Shock Absorber Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
60.99
60.99
Fits:1997-2006 Jeep Wrangler TJ & Unlimited (Rubicon) VSS Rear 9550 Shock Absorber, 6" Lift Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability.
TeraFlex VSS Rear 9550 Shock Absorber, 2.5" Lift
62.99
62.99
TeraFlex VSS Rear 9550 Shock Absorber, 2.5" Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK VSS 9550 Shock Absorber Kit, Set Of 4, 2.5" Lift Sold as a set of 4. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex VSS Rear 9550 Shock Absorber, 2"-3" Lift
62.99
62.99
Fits:1997-2006 Jeep Wrangler TJ & Unlimited (Rubicon)VSS 9550 Shock Absorber Kit, Set Of 4, 2"-3" Lift Sold as a set of 4. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability.
TeraFlex VSS Rear 9550 Shock Absorber, 3-4" Lift
62.99
62.99
TeraFlex VSS Rear 9550 Shock Absorber, 3-4" Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK VSS Rear 9550 Shock Absorber Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
62.99
62.99
Fits:1997-2006 Jeep Wrangler TJ & Unlimited (Rubicon)VSS Rear 9550 Shock Absorber, 3-4" Lift Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability.
TeraFlex VSS Rear 9550 Shock Absorber, 6+" Lift
60.99
60.99
TeraFlex VSS Rear 9550 Shock Absorber, 6+" Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK VSS Rear 9550 Shock Absorber, 34.59 Ext, 21.25 Col, 6+" LiftInstallation Difficulty: EasyInstallation Time: 0.5 Hours on AverageWeight: 6Length: 24Width: 3Height: 3Sold individually. The VSS gas shock uses a twin-tube design, with a triple-chromed rod to ensure extended trouble-free operation. This shock is all performance and packed with features for extreme durability. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex Weld On Front Track Bar Bracket
95.99
95.99
Available while supplies last. TeraFlex Weld On Front Track Bar Bracket Fits: 1997-2006 Jeep Wrangler TJ and Unlimited (Rubicon) This bracket is precision laser cut from 3/16" steel and accurately formed to ensure proper positioning. Raw steel ready for paint or powder coating.
TeraFlex Wheel Offset Adapter with a 5x4.5" Bolt Pattern, Pair
141.99
141.99
TeraFlex Wheel Offset Adapter with a 5x4.5" Bolt Pattern, Pair Fits: 1997-2006 Jeep Wrangler TJ 2004-2006 Jeep Wrangler TJ Unlimited (Rubicon) 1993-1998 Jeep Grand Cherokee ZJ 1987-1995 Jeep Wrangler YJ 1984-1996 Jeep Cherokee XJ Product Overview: This TeraFlex Wheel Offset Adapter will provide a 1" offset for factory wheels for additional tire clearance when turning. The wheel spacer is not intended for wheels wider than 8" or aftermarket wheels with less than 4" of backspacing. 5 x 4.5" bolt pattern. Years Covered: 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
TeraFlex Yoke U-Bolt Conversion, Complete Yoke Kit
385.99
385.99
TeraFlex Yoke U-Bolt Conversion, Complete Yoke Kit Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Yoke U-bolt Conversion, Complete Yoke KitThe U-bolt conversion kit replaces the yoke and changes the OEM Rzeppa CV flange with a standard CV cardan joint style yoke and U-bolt style connector. The conversion makes u-joint changes easier after breakages.Installation Difficulty: Medium. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex Yoke U-Bolt Conversion, Front Axle Yoke Kit
98.99
98.99
TeraFlex Yoke U-Bolt Conversion, Front Axle Yoke Kit Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Yoke U-Bolt Conversion, Front Axle Yoke KitThe U-bolt conversion kit replaces the yoke and changes the OEM Rzeppa CV flange with a standard CV cardan joint style yoke and U-bolt style connector. The conversion makes u-joint changes easier after breakages.Installation Difficulty: Medium. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex Yoke U-Bolt Conversion, Rear Axle Yoke Kit
98.99
98.99
TeraFlex Yoke U-Bolt Conversion, Rear Axle Yoke Kit Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Yoke U-Bolt Conversion, Rear Axle Yoke KitThe U-bolt conversion kit replaces the yoke and changes the OEM Rzeppa CV flange with a standard CV cardan joint style yoke and U-bolt style connector. The conversion makes u-joint changes easier after breakages.Installation Difficulty: Medium. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
TeraFlex Yoke U-Bolt Conversion, Transfer Case Output Yoke Kit
98.99
98.99
TeraFlex Yoke U-Bolt Conversion, Transfer Case Output Yoke Kit Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Yoke U-bolt Conversion, Transfer Case Output Yoke KitThe U-bolt conversion kit replaces the yoke and changes the OEM Rzeppa CV flange with a standard CV cardan joint style yoke and U-bolt style connector. The conversion makes u-joint changes easier after breakages.Fits JK Front or Rear. Installation Difficulty: Medium. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Teraflex, 59.75" Right Side, Emergency Brake Cable
46.99
46.99
TeraFlex, 59.75" Right Side, Emergency Brake Cable Fits: 1997-2001 Jeep Cherokee XJ with TeraFlex Rear Disc Brake Kit Dimensions: Length: 59.75" Width: .05" Height: .05" Weight: 1.01 Lbs Product Information: This kit will provide your XJ Cherokee Rear Disc Brake conversion with a new emergency brake cable. This cable will NOT work with stock drum brakes, and will ONLY work with the TeraFlex Disc Brake Kit. Special Note: Sold individually Order two for a full axle. Specifications: Install Difficulty: Moderate Install Time: 0.8 Hrs Average Years Covered: 1997, 1998, 1999, 2000 and 2001
Teraflex, 42" Left And Right Hand Side, Emergency Brake Cable
46.99
46.99
TeraFlex, 42" Left And Right Hand Side, Emergency Brake Cable Fits: 1997-2006 Jeep Wrangler TJ 2004-2006 Jeep Wrangler Unlimited TJL 1997-2001 Jeep Cherokee XJ Dimensions: Length: 42" Width: .05" Height: .05" Weight: 1.02 Lbs Product Information: This kit will provide your TJ Wrangler & Jeep Cherokee XJ Rear Disc Brake conversion with a new emergency brake cable. This cable will NOTwork with stock drum brakes, and will ONLY work with the TeraFlex Disc Brake Kit. Special Note: Sold Individually Order Two for a full axle Specifications: Install Difficulty: Moderate Install Time: 0.8 Hrs Average Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
TeraFlex, LOW 231 HD Transfer Case, Low Range Conversion Kit
1239.99
1239.99
TeraFlex, LOW 231 HD Transfer Case, Low Range Conversion Kit Fits: 1997-2006 Jeep Wrangler TJ 1988-1995 Jeep Wrangler YJ 2004-2006 Jeep Wrangler Unlimited TJ Fits These Engines: Jeep 4.0L I-6 Gasoline Product Information: The Tera Low231 conversion kit is the solution for providing Wranglers, Cherokees, and Comanches with low crawl ratios. This kit provides rock-crawling performance without affecting high range gears for daily drivers, or the trip to and from the back country. It provides a true 4.0:1 reduction through a heavy duty 5 gear planetary system. Every part in this kit is new, with no core charges. Shift linkage and driveshaft length changes are not necessary. Jeep Years Covered: 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
U-Bolt Yoke Conversion Kit, (For Dana 30 & Dana 44)
89.99
89.99
U-Bolt Yoke Conversion Kit, (For Dana 30 & Dana 44) Fits: 1997-2006 Jeep Wrangler TJ 2003-2006 Jeep Wrangler TJ Unlimited 1987-1995 Jeep Wrangler YJ 1984-2001 Jeep Cherokee XJ Product Overview: The U-bolt conversion kit replaces the yoke and changes the OEM strap/nut with a stronger U-bolt style connector. The conversion is not only stronger but makes u-joint changes easier after breakages. Installation Difficulty: Medium Installation Time: 1.5 hours on average Details: 2 Door & 4 Door Models Includes: Front axle yoke & U-Bolts
Page (19 of 19)
15 16 17 18 19 |
