Buy "sunpro" online - search for the best price - compare prices
Page (3 of 3)
1 2 3 |
Sunpro Super Tach II - CP7911
45.99
45.99
White face, chrome bezel tachometer with 0 to 8000 rpm range.Product Features:250 sweepAdjustable red line pointerWorks on 4, 6, and 8 cylinder enginesIncludes mounting hardware. Most Tachometers & Related products are available for in-store pickup from Advance Auto Parts.
Sunpro Super Tach II 2 5/8inch - Black Face & Black Bezel - CP7906
32.99
32.99
Sunpro Super Tach II Gauges feature internal dial lighting, accurate air core meters, a 0-8,000 RPM scale, 250 dial sweep and adjustable red line pointers. They are designed to work with 4-, 6- or 8-cylinder engines, and function with breaker-point, electronic, and most aftermarket ignition systems (not magnetos). Most Tachometers & Related products are available for in-store pickup from Advance Auto Parts.
Sunpro Super Tach II 2 5/8inch - Black Face & Chrome Bezel - CP7908
61.99
61.99
Sunpro Super Tach II 3 3/8inch - Black Face & Chrome Bezel - CP7901
47.99
47.99
Sunpro Super Tach II 3 3/8inch - White Face & Chrome Bezel - CP7903
47.99
47.99
Sunpro Super Tach III - CP7905
99.89
99.89
Black-face tachometer with 0 to 10,000 RPM range.Product Features:High-intensity blue shift light that can be set to light at a specific point using the front adjusting knobSolid metal housing with swivel mounting footEven back lighting for excellent night visibilityWorks on 2, 4 , 6, and 8 cylinder engines. Most Tachometers & Related products are available for in-store pickup from Advance Auto Parts.
Sunpro Temperature Sender Adapter Kit - CP7555
4.49
4.49
Includes 2 brass bushings to adapt mechanical oil or water temperature gauges to 1/4" and 3/8" NPT external threads. Product Features:Includes 2 brass bushings to adapt mechanical oil or water temperature gauges to 1/4" and 3/8" NPT external threads. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Sunpro Triple Gauge Pod - CP7549
37.99
37.99
The Sunpro gauge pods let you add additional gauges to your vehicle's A-pillar post quickly and easily for a clear view of engine vital statistics. These gauge pods are made of heat- and UV-resistant (will not warp or fade) ABS plastic and are paintable for a custom fit and finish. Gauge pods fit all Sunpro 2" gauges. A universal design allows these pods to be molded to fit most vehicles including: Acura, Civic, CRX, Eclipse, Focus and Mustang. Includes manual and mounting hardware. 18"-19" length. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Sunpro Vacuum Gauge Tubing Kit - CP7575
4.49
4.49
Fits vacuum gauges with barb fittings. Includes: 72" of 3/16" plastic tubing, barbed T-connector, 1/8" NPT to 3/16" I.D. nipple. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Sunpro Vacuum Pump Brake Bleeder Kit - CP7835
59.99
59.99
A complete kit that allows the user to bleed all types of vehicle brake systems without any mess. Kit includes a vacuum pump and adapters for all types of systems. Most Brake Tools products are available for in-store pickup from Advance Auto Parts.
Sunpro White Face Triple Gauge Kit - CP8208
39.99
39.99
Comes with Mechanical Oil/Water Temperature, Electrical Voltmeter and Mechanical Oil Pressure. Features chrome bezel with removable chrome panel. Includes gauges and mounting hardware; 72" capillary tubing with 5/8" NPT thread and 1/4", 3/8", and 1/2" adapters; and 72" high temperature nylon tubing with 1/8" and 1/4" NPT thread fittings. Requires hook-up wire for voltmeter. Gauges have12 Volt internal lighting and are designed for 12 Volt negative ground systems. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Temperature Sending Unit for Sunpro Gauges - CP7576
10.49
10.49
Electric sending unit for use with Sunpro electric oil or water temperature gauges. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Page (3 of 3)
1 2 3 |
