Buy "streamlight" online - search for the best price - compare prices
Page (5 of 8)
1 2 3 4 5 6 7 8 |
Streamlight Replacement Lens for Ultra Stinger Flashlight - STL20160
1.10
1.10
Articulating 185 degree rotating headContains 4 LEDs with 4 levels of output intensities for each LEDWaterproof, durable, lightweight flashlight built to MIL-STD-810F, method 512.4Long run times - up to 100+ hours at low intensityEasy to use switch for on-off, dimming and mode selection functions Tactical flashlight with 185 degree rotating head. Features 1 each White, Red, Blue and Green LEDs. Each LED provides 4 levels of output intensities: Low (5%), Medium (20%), Medium-High (50%) and High (100%) plus a Strobe function (100%). Pull and rotate locking color selector knob with tactile indicator allows for easy operation with gloves. Constructed of high impact, super tough nylon that is o-ring sealed for waterproof operation (meets MIL-STD-810F, Method 512.4) and contains an unbreakable, gasket sealed polycarbonate lens with scratch resistant coating. Includes cord attachment hole that supports up to 25 lbs, tethered tailcap to prevent loss, spring steel clip that attaches to MOLLE or belt and (2) "AA" alkaline batteries. Coyote Tan color. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Ring Holder for Stinger Series - STL75906
7.00
7.00
3 Modes of lighting: ? High, Medium, Low plus Strobe functionLight output range of 50 lumen's to 200 lumen'sPiggyBack charger/holder charges the light and spare battery simultaneouslySuper bright C4 LED has a 50,000 hour lifetime and is impervious to shockFeatures dual independent head and tail cap switching This LED? light produces up to 48,000 Candle/200 Lumen's (High), up to 24,000 Candle/100 Lumen's (Medium) and up to 11,000 Candle/50 Lumen's (Low).? Run times of up to 2 hours (High), 3.75 hours (Medium), 7.25 hours (Low) and 5.5 hours (Strobe).? ? Deep dish parabolic reflector produces a long range targeting beam with optimum peripheral illumination. Optimized electronics provides regulated intensity.? Constructed of machined aircraft aluminum with non-slip rubberized comfort grip.? Includes both AC and DC charge cords and a PiggyBack charger/holder that charges both the light and spare battery simultaneously. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Scorpion LED Lithium Powered Flashlight - STL85010
66.19
66.19
C4 LED is 2 times brighter than a Super high-flux LED, delivers 120 lumensLED is impervious to shock and never needs replacedRubber armored sleeve provides a "sure-grip" in all weather environmentsAnti roll head keeps the light in placeEasy to use push button tail "on-off" switching This compact, machined aluminum flashlight is one of the brightest, lightest personal flashlights ever created. Up to 3.5 hours runtime to the 10% output level. Up to 7,500 peak beam candlepower. Powered by two 3 volt lithium energy cells, LED has a 50,000 hour lifetime and never needs replaced. O-ring sealing protects against moisture. Length: 5.72"; weight: 5.3 oz. Limited lifetime warranty. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Scorpion Lithium Powered Flashlight - STL85001
48.27
48.27
Two 3 volt CR123A lithium batteries with a storage life of 10 years6 volt xenon gas bulb, designed to last through 5 sets of batteries (spare bulb included)Up to 7,900 candela; 78 lumensAdjustable spot-to-flood focusUp to 80 minutes of run time O ring sealed for moisture protection. Machine aluminum covered by a rubber-armored sleeve for a sure grip. One of the brightest and lightest personal flashlights ever created, the Scorpion is the only tactical light with a rubberized grip and tailcap switch. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Septor LED Yellow Headlamp - STL61052
39.87
39.87
This ultra-bright LED headlamp lets you choose 1, 3 or 7 LEDs.Powered by 3 "AAA" alkaline batteries (included)Seven 100,000 hr. life ultra-bright, white LEDs50 lumens typical (7 LEDs), 25 lumens typical (3 LEDs), 9 lumens typical (1 LED)Runs up to 150 hrs. (single LED) Adjustable elastic head strap and rubber hard hat strap. Face cap diameter: 1.86". Max width: 2.55". Max depth: 2.53" including head strap and mounting plate. 4.72 oz. 90? tilting head. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Sidewinder Flashlight - STL14002
68.79
68.79
Articulating 185 degree rotating headContains 4 LEDs with 4 levels of output intensities for each LEDWaterproof, durable, lightweight flashlight built to MIL-STD-810F, method 512.4Long run times - up to 100+ hours at low intensityEasy to use switch for on-off, dimming and mode selection functions Tactical flashlight with 185 degree rotating head. Features 1 each White, Red, Blue and Green LEDs. Each LED provides 4 levels of output intensities: Low (5%), Medium (20%), Medium-High (50%) and High (100%) plus a Strobe function (100%). Pull and rotate locking color selector knob with tactile indicator allows for easy operation with gloves. Constructed of high impact, super tough nylon that is o-ring sealed for waterproof operation (meets MIL-STD-810F, Method 512.4) and contains an unbreakable, gasket sealed polycarbonate lens with scratch resistant coating. Includes cord attachment hole that supports up to 25 lbs, tethered tail cap to prevent loss, spring steel clip that attaches to MOLLE or belt and (2) "AA" alkaline batteries. Coyote Tan color. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger Black FlashLight with AC/DC Charger and Piggyback Holder - STL75300
147.99
147.99
15,000 candlepowerXenon Halogen bulbMachined aluminumLength: 7-3/8"Charge your Stinger while simultaneously charging it? s spare battery Other features include: spare bulb in the end cap, anodized against corrosion, self-cleaning switch and spot-to-flood beam. Stinger Piggyback Charger doubles your battery power! The Stinger Piggyback Charger works with Stinger, Stinger HP, Stinger XT, Stinger XT HP, as well as PolyStinger. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger Blue Rechargeable Flashlight (Light Only) - STL75074
100.29
100.29
Xenon gas-filled bi-pin bulb; spare bulb in tail capAdjustable focus beamUp to 15,000 candela; 125 lumens3 Cell 3.6V sub-C NiCad battery is rechargeable up to 1,000 times (not included)Up to 1 hour continuous use These compact, super-bright, rechargeable, lightweight personal lights are the most powerful lights ever made in their size. The machined aluminum housing that's anodized against corrosion and the unbreakable polycarbonate lens make the Stingers virtually indestructible. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger Blue Rechargeable Flashlight with AC-DC and 2 Holders - STL75071
137.29
137.29
Xenon gas-filled bi-pin bulb; spare bulb in tailcapAdjustable focus beamUp to 15,000 candela; 125 lumens3 Cell 3.6V sub-C NiCd battery is rechargeable up to 1,000 timesUp to 1 hour continuous use These compact, super-bright, rechargeable, lightweight personal lights are the most powerful lights ever made in their size. The machined aluminum housing? that's anodized against corrosion and the unbreakable polycarbonate lens make the Stingers virtually indestructible. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger Blue Rechargeable Flashlight with AC/DC Charger and Piggyback Holder - STL75073
147.39
147.39
Xenon gas-filled bi-pin bulb; spare bulb in tail capAdjustable focus beamUp to 15,000 candela; 125 lumens3 Cell 3.6V sub-C NiCad battery is rechargeable up to 1,000 timesUp to 1 hour continuous use These compact, super-bright, rechargeable, lightweight personal lights are the most powerful lights ever made in their size. The machined aluminum housing that's anodized against corrosion and the unbreakable polycarbonate lens make the Stingers virtually indestructible. Stinger Piggyback Charger doubles your battery power! The Stinger Piggyback Charger works with Stinger, Stinger HP, Stinger XT, Stinger XT HP, as well as PolyStinger. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger Carbon Fiber Flashlight with AC/DC Charger and Piggyback Holder - STL75086
138.69
138.69
Stinger compact, rechargeable flashlight with carbon fiber finishMachined aluminum construction with push button switchPowerful xenon bi-pin bulb provides up to 15,000 candlepowerRechargeable up to 1000 times, with up to one hour of continuous useIncludes both AC and DC charge cords, Piggyback charger with spare battery and spare bulb in end cap The Carbon Fiber Stinger Flashlight is 10 oz., 7.38" long. Bulb provides bright light, easy to replace/Focusable beam allows adjustment of light. Withstands work environment/Ease of use. Color distinguishes it among tools and other flashlights. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger DS LED HP Rechargeable Flashlight - STL75882
193.99
193.99
3 Modes of lighting: ? High, Medium, Low plus Strobe functionLight output range of 50 lumen's to 200 lumen'sPiggyback charger/holder charges the light and spare battery simultaneouslySuper bright C4 LED has a 50,000 hour lifetime and is impervious to shockFeatures dual independent head and tail cap switching This LED? light produces up to 48,000 Candle/200 Lumen's (High), up to 24,000 Candle/100 Lumen's (Medium) and up to 11,000 Candle/50 Lumen's (Low).? Run times of up to 2 hours (High), 3.75 hours (Medium), 7.25 hours (Low) and 5.5 hours (Strobe).? ? Deep dish parabolic reflector produces a long range targeting beam with optimum peripheral illumination. Optimized electronics provides regulated intensity.? Constructed of machined aircraft aluminum with non-slip rubberized comfort grip.? Includes both AC and DC charge cords and a Piggyback charger/holder that charges both the light and spare battery simultaneously. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger DS LED Rechargeable Flashlight with AC/DC and PiggyBack - Blue - STL75617
184.39
184.39
Features dual independent head and tail cap switchingRechargeable flashlight with 3 levels of lighting plus strobeC4 LED has a 50,000 hour lifetime and never needs replacedPiggyBack charger/holder charges both light and spare battery simultaneouslyRechargeable up to 1000 times Constructed of durable machined aluminum with nonslip rubber grip. Produces up to 160 lumens/18,000 candela. Run times: 1.75 (high), 3.5 (medium), 6.75 (low) and 5.5 (strobe). Multi-function push button switch. Deep dish parabolic reflector produces a smooth beam. Includes flashlight and battery. Includes both AC and DC charge cords, PiggyBack charger/holder, and spare battery. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger DS LED Rechargeable Flashlight with AC/DC and PiggyBack - Red - STL75616
184.39
184.39
Features dual independent head and tail cap switchingRechargeable flashlight with 3 levels of lighting plus strobeC4 LED has a 50,000 hour lifetime and never needs replacedPiggyback charger/holder charges both light and spare battery simultaneouslyRechargeable up to 1000 times Constructed of durable machined aluminum with nonslip rubber grip. Produces up to 160 lumens/18,000 candela. Run times: 1.75 (high), 3.5 (medium), 6.75 (low) and 5.5 (strobe). Multi-function push button switch. Deep dish parabolic reflector produces a smooth beam. Includes flashlight and battery. Includes both AC and DC charge cords, Piggyback charger/holder, and spare battery. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger DS LED Rechargeable Flashlight with PiggyBack Charger and AC/DC Charge Cords - S
174.49
174.49
Stinger LED DS is the only rechargeable flashlight with a fully independent dual switch - both push button (head) and tail cap switchingC4 LED, 50,000 hour lifetime3 levels of lighting allows user to choose the level of lighting needed for task at handPiggyBack charger charges light and spare battery simultaneouslyRechargeable flashlight -saves user money on battery replacement costs Constructed of machined aircraft aluminum with on slip rubber grip and unbreakable polycarbonate lens. 3 levels of lighting - high, medium and low (plus Strobe). Run times of up to 1.75 hours (high), 3.50 hours (medium) and 6.75 hours (low), up to 5.5 hours (strobe). Deep dish parabolic reflector produces a long range targeting beam with optimal peripheral illumination. Fits into existing Stinger charger/holders. Includes PiggyBack charger that charges light and spare battery (included) simultaneously, both AC and DC charge cords and anti-roll rubber ring. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger FlashLight with AC/DC Charger and Fast Charger Piggyback Holder - STL75303
161.39
161.39
15,000 candlepowerXenon Halogen bulbMachined AluminumSpare bulb in the end capAnodized against corrosionSelf-cleaning switchSpot-to-flood beam STINGER PIGGYBACK CHARGER Double your battery power! Now you can charge your Stinger flashlight while simultaneously charging it? s spare battery. The Stinger Piggyback Charger works with Stinger, Stinger HP, Stinger XT, Stinger XT HP, as well as PolyStinger. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger HP Rechargeable Flashlight with AC/DC Charger and 2 Holders - STL75503
135.99
135.99
40,000 candlepowerXenon Halogen bulbMachined AluminumLength: 8-1/4"Weight: 12.2 oz. Spare bulb in the end cap. Anodized against corrosion. Self-cleaning switch, Spot-to-flood beam. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger HP Rechargeable Flashlight with AC/DC Charger and Fast Charger Piggyback Holder
160.89
160.89
40,000 candlepowerXenon Halogen bulbMachined AluminumAnodized against corrosionSelf-cleaning switchSpot-to-flood beam STINGER PIGGYBACK CHARGER Double your battery power! Now you can charge your Stinger flashlight while simultaneously charging it? s spare battery. The Stinger Piggyback Charger works with Stinger, Stinger HP, Stinger XT, Stinger XT HP, as well as PolyStinger. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger HP Rechargeable Flashlight with AC/DC Charger and Piggyback Holder - STL75523
147.99
147.99
Streamlight Stinger LED Flashlight Holster (Loop) - STL75928
34.50
34.50
Flapless belt holsterDurable Nylon ConstructionBlackFits all Stinger Series flashlights and 3 Watt Rechargeable flashlightsMade in USA. Most Spot & Trouble Lights products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger LED Rechargeable Flashlight - Blue (Light Only) - STL75611
122.99
122.99
Rechargeable flashlight with 3 levels of lighting plus strobeC4 LED has a 50,000 hour lifetime and never needs replacedRechargeable up to 1000 timesConstructed of durable machined aluminum with nonslip rubber gripProduces up to 160 lumens Run times: 1.75 (high), 3.5 (medium), 6.75 (low) and 5.5 (strobe). Multi-function push button switch. Deep dish parabolic reflector produces a smooth beam. Includes flashlight and battery.? Chargers and charge cords must be purchased separately. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger LED Rechargeable Flashlight - Red (Light Only) - STL75610
122.99
122.99
Streamlight Stinger LED Rechargeable Flashlight with AC/DC and 1 PiggyBack Holder - STL75732
166.89
166.89
C4 LED technology, impervious to shock with a 50,000 hour lifetimeUp to 17,000 candela and up to 180 lumens measured system outputDeep dish parabolic reflector produces a targeting beam with optimum peripheral illuminationAnti-roll rubber ring and non slip rubber gripFits in existing Stinger snap in chargers Constructed of machined aluminum with nonslip rubber grip and unbreakable polycarbonate lens. 3 cell, 3.6 volt sub-C Nickel cadmium battery is rechargeable up to 1000 times. Multi function on/off push-button switch designed for extremely long life. Runtime: High brightness: Up to 2 continuous hours to the 10% output level; Medium brightness: Up to 3.75 continuous hours to the 10% output level; Low brightness: Up to 7.25 continuous hours to the 10% output level; Strobe: Up to 5.50 continuous hours. Includes both AC and DC Charge cords and 1 Piggyback Charger that charges both the light and spare battery (included) simultaneously. The flashlight is black and 8.41" long and weighs 12.4 oz. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger LED Rechargeable Flashlight with AC/DC and PiggyBack - Blue - STL75613
177.79
177.79
Rechargeable flashlight with 3 levels of lighting plus strobeC4 LED has a 50,000 hour lifetime and never needs replacedPiggyBack charger/holder charges both light and spare battery simultaneouslyRechargeable up to 1000 timesConstructed of durable machined aluminum with nonslip rubber grip Produces up to 160 lumens/18,000 candela. Run times: 1.75 (high), 3.5 (medium), 6.75 (low) and 5.5 (strobe). Multi-function push button switch. Deep dish parabolic reflector produces a smooth beam. Includes flashlight and battery. Includes both AC and DC charge cords, PiggyBack charger/holder, and spare battery. Most Flashlights & Batteries products are available for in-store pickup from Advance Auto Parts.
Streamlight Stinger LED Rechargeable Flashlight with AC/DC and PiggyBack - Red - STL75612
177.19
177.19
Page (5 of 8)
1 2 3 4 5 6 7 8 |
