Buy "sharpe" online - search for the best price - compare prices
Page (2 of 3)
1 2 3 |
Sharpe Gravity Feed Cup Filter - Sold in packs of 5 - SHA21719
16.59
16.59
21719 Gravity Feed Cup Filter - Sold in packs of 5For use on all Platinum, SHASGF98HVLP, Cobalt and SHASGF98 Gravity Feed Spray Guns Featuring convenient push-pull lids and our "no drip" feature Also Available: SHA6685 650cc Aluminum Gravity Feed Cup - 23 oz.SHA6678565cc Nylon Gravity Feed Cup - 22 oz.SHA21719Gravity Feed Cup Filter - Sold in packs of 5. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Heavy Duty Gear Lube - SPM1021
485.29
485.29
Patented electronic meter5-year warranty on the meterHeavy duty pump design Heavy duty hand operated gear lube system for a 16 gallon open drum consists of: 2: 1 hand pump, deluxe drum cover, fluid hose with shut off valve, curved outlet nozzle and electronic meter. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Sharpe High Volume Air Adjusting Regulator with Gauge 36AAV-HV - SHA3310
22.99
22.99
Static air pressure at the gunDynamic air pressure at the gunAir pressure drop from the compressed air source to the point of useAdequate or inadequate compressed air supplyAir inlet: 1/4 in npsm. Most Air Compressors products are available for in-store pickup from Advance Auto Parts.
Sharpe Model 18C-3R Air Regulator - SHA1630
54.99
54.99
3 Regulated outletsAir Inlet 3/8" F.P.T.All outlets 1/4" F.P.T.Capacity 50 CFMShipping Wt. 1 lb. 9 oz. Most Air Compressors products are available for in-store pickup from Advance Auto Parts.
Sharpe Model 707F 3/4inch In-Line Filter with Overnight Drain - SHA6920
203.99
203.99
Removes oil and water contaminationDisassemble and clean filter without toolsFeatures a large reusable filter element5 micron filtration. Most Air Compressors products are available for in-store pickup from Advance Auto Parts.
Sharpe Model 750FC 1/2inch In-Line Filter and Coalescer - SHA6910
353.79
353.79
Prevents fish-eyes by removing water, oil and contamination without the use of desiccantDesigned for use in prep stations and air/finishing areasStage 1 provides removal of water and contaminants down to 5 micronsStage 2 provides removal of oil and sub-Micronics particles down to .01 micronsAir flow capacity: 115 cfm. Most Air Compressors products are available for in-store pickup from Advance Auto Parts.
Sharpe Model 880A Air Control Unit - SHA6950
159.99
159.99
Highly effective at removing water, oil and contamination to protect air cylinders and air toolsContains 18C-3R regulator with a 160 lb. inverted gauge and air cockRegulated outlet and filtered main line outlet includedFilter capacity: 75 cfmRegulator capacity: 50 cfm. Most Air Compressors products are available for in-store pickup from Advance Auto Parts.
Sharpe Model F88 Air FIlter - SHA8130
108.49
108.49
Highly effective at removing water, oil and contaminationProtects air cylinders and air tools and features a reusable edge-type filter element5 micron filtrationFilter capacity: 75 cfm. Most Air Compressors products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor Compliant Spray Gun 2.0 Needle Nozzle - SHA253445
436.09
436.09
Compliant performance at 35 psiLightweight, ergonomic gun body for painter comfortProvides the perfect blend of first-rate atomization and extraordinary transfer efficiencyUse with clears, base coats, and primers3 year warranty Sharpe knows that in today? s auto-refinish market, time truly is money. As painting professionals, you are faced with greater pressure in the market to complete jobs faster and to get them done right the first time. That? s why we developed the RAZOR Gun platform. It offers superior performance AND reduces production time.? This is the lightest gun on the market. One Universal Platform The new RAZOR guns represent a single gun platform that supports painting needs from clear coat to primer material - making it easier to adjust to one gun, rather than switching between guns to complete various jobs. This means less time spent learning and maintaining multiple guns and more time spent in the spray booth. Plus, standardizing on a single gun family reduces your costs for replacement parts. Premium Performance In addition to a universal platform, the new RAZOR guns offer superior atomization, spray patterns and material flow that outperform competitive models. If your material demands high transfer efficiency, fine atomization or wide patterns, the RAZOR has got you covered. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor Compliant Spray Gun with 1.2mm Nozzle - SHA253441
504.29
504.29
First rate atomization, with transfer efficiency equal to or better than HVLPCompliant technology is capable of atomizing higher viscosity materials and offers higher production rates when compared to HVLPErgonomic gun handle, lightweight and low trigger pull for ultimate painter comfortMade in the U.S.A. and backed my a 3 year warranty3M PPS adapter and 23 oz. polished aluminum gravity cup included The Razor has 100% stainless steel fluid passages and stainless steel needle and nozzle. The Razor offers long term affordability with ultra long life needle packings and low cost of ownership due to cost effective repair parts. Nickel plated finish allows for easy cleaning. Applications include: base and clear coats, high solid, single stage. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor Compliant Spray Gun with 1.3 mm Nozzle - SHA253442
474.99
474.99
Sharpe Razor Compliant Spray Gun with 1.4 mm Nozzle - SHA253443
474.99
474.99
First rate atomization, with transfer efficiency equal to or better than HVLPCompliant technology is capable of atomizing higher viscosity materials and offers higher production rates when compared to HVLPErgonomic gun handle, lightweight and low trigger pull for ultimate painter comfortMade in the U.S.A. and backed my a 3 year warranty3M PPS adapter and 23 oz. polished aluminum gravity cup included The Razor has 100% stainless steel fluid passages and stainless steel needle and nozzle. The Razor offers long term affordability with ultra long life needle packings and low cost of ownership due to cost effective repair parts. Nickel plated finish allows for easy cleaning. Applications include: base and clear coats, single stage, sealers, low solid clear. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor Conventional Siphon Feed Spray Gun with 1.5mm Nozzle - SHA288291
504.29
504.29
Extremely smooth spray pattern for superior finishesCapable of atomizing a broad range of coatingsErgonomic gun handle, lightweight and low trigger pullLong-term affordability with ultra long life needle packingMade in the U.S.A. and backed by a 3 year warranty Includes spray gun and 1 qt. cup assembly. Applications: base and clear coats, single stage, sealers, low solid clear. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor HVLP Primer Spray Gun with 1.5mm Nozzle - SHA253437
279.99
279.99
Delivers top quality atomizationMinimizes overspray to reduce masking and sandingErgonomic blue anodized gun handle, lightweight and low trigger pull for ultimate painter comfortMade in the U.S.A. and backed by a 3 year warranty3M PPS adapter is NOT included; can be purchased separately The Razor primer has a stainless steel needle and nozzle. The Razor offers long-term affordability with ultra long life needle packing and low cost of ownership due to cost effective repair parts. 23 oz. brushed aluminum cup included. Applications: Primer, high viscosity. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor HVLP Primer Spray Gun with 1.8 Needle Nozzle - SHA253438
279.99
279.99
Sharpe Razor HVLP Spray Gun with 1.3 mm Nozzle - SHA253433
474.99
474.99
Extremely smooth spray pattern for superior finishesCapable of atomizing a broad range of coatings from primerErgonomic gun handle, lightweight, and low trigger pull for ultimate painter comfortMade in the USA and backed by a 3 year warranty3M PPS Adapter and 23 oz. polished aluminum gravity cup included The best American made gun for spraying base coat and clear coat when HVLP technology is required. The Razor has 100% stainless steel fluid passages and stainless steel needle and nozzle. The Razor offers long-term affordability with ultra-long life needle packings and low cost of ownership due to cost effective repair parts. Nickel plated finish allows for easy cleaning. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor HVLP Spray Gun with 1.4 mm Nozzle - SHA253434
455.69
455.69
Sharpe Razor HVLP Spray Gun with 1.5 mm Nozzle - SHA253435
474.99
474.99
Sharpe Razor HVLP Waterborne Gun with 1.4mm Tip - SHA289571
507.99
507.99
HVLP technology air cap technology optimized for waterborne or water base paintSuperior atomization for material distributionErgonomic gun handle, lightweight, and low trigger pull for ultimate painter comfort3M PPS Adapter and 23 ounce plastic gravity cup includedMade in the USA and backed by a 3-year warranty The HVLP Waterborne gun has been optimized for waterborne or water base paint. Made with 100 percent stainless steel fluid passages and stainless steel needle and nozzle. The RAZOR offers long-term affordability with ultra long life needle packing and low cost of ownership due to cost effective repair parts. Nickel-plated finish allows for easy cleaning. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Razor Waterborne HVLP Spray Gun with 1.3mm Nozzle - SHA289389
507.99
507.99
HVLP technology air cap technology optimized for waterborne or water base paintSuperior atomization for material distributionErgonomic gun handle, lightweight and low trigger pull for ultimate painter comfortMade in the U.S.A. and backed by a 3 year warranty3M PPS Adapter and 23 oz. plastic gravity cup included The Razor is waterborne compatible with 100% stainless steel fluid passages and stainless steel needle and nozzle. The Razor offers long-term affordability with ultra long life needle packings and low cost ownership due to cost effective repair parts. Nickel plated finish allows for easy cleaning. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Repair Kit 775 - SHA25196
40.99
40.99
25196Repair Kit. Most Air Compressors products are available for in-store pickup from Advance Auto Parts.
Sharpe Repair Kit 975 - SHA27222
43.79
43.79
27222Repair Kit 975. Most AC Valves & Tubing products are available for in-store pickup from Advance Auto Parts.
Sharpe Siphon Cup Assembly - SHA6610
57.99
57.99
Use with Siphon Feed Gun1 quart capacityWill not drip when spraying in any positionThread size: 3/8" in npsm f) swivel nutNo accidental spills or damaged work areas. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Spray Gun Brush Kit - SHA8260
66.29
66.29
Professional brush kit effectively cleans any model spray gun including HVLPIncludes one model 8255 spray gun lube applicator. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Sharpe Zephyr Drying Gun - SHA289956
112.99
112.99
Decreased drying time for waterborne or water base paintCan be used freehand or with Zephyr Gun StandIntake filter will prevent contamination of vehicle surface This easy to use gun is designed to decrease the drying time of waterborne paint using compressed air. The Zephyr Gun can be used freehand or attached to the 360 degree Zephyr Gun Stand. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Page (2 of 3)
1 2 3 |
