Buy "robinair" online - search for the best price - compare prices
Page (4 of 19)
1 2 3 4 5 6 7 8 |
RobinAir A/C 90 Degree 1/4inch MFL x 1/4inch FFL Adapter - ROB40563A
13.99
13.99
Solid brass fitting is ideal for tight spots or locations where making connections is difficult. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir A/C Flush Gun Kit - ROB17595
49.29
49.29
The flush gun uses dry shop air to pressurize the solventThe attached nozzle directs the flow of solvent without spray-back An economical means of flushing contaminants and scale from A/C system components. The process thoroughly cleans the part, removing oil and any refrigerant contaminants and residue. Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
RobinAir A/C Power Flush Solvent - ROB17609
115.89
115.89
Quart, six per cartonMeets ANSI/ASHRAE 97-1933Compatible with all CFC, HCFC, and HFC refrigerants Gives you the cleaning power to flush particulates and system lubricant from A/C and refrigeration lines, evaporators, and condensers. An ideal substitute for CFC-113, it has excellent cleaning properties and good evaporation rate. Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
RobinAir A/C R-134A Manifold Gauge Set with 72inch Hose and Couplers - ROB45111
178.99
178.99
Brass manifold with easy-to-grip handlesR12/R134a gauges, PSI, and ? F Temp90? manual couplersRear R134a and 1/2" ACME fittings for holding hoses72" R134a hose set (1/2" ACME x 14mm). Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir A/C Sealant Remover Adapter Hose Kit - ROB17641
34.69
34.69
Kit for connecting one No. 17622, R-134A, or R-12. Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
RobinAir A/C SYSTEM CALCULATOR - ROB43310
64.89
64.89
It gives you a wide temperature range and highly accurate readings from -58 ? to 302 ? F (+-2? ); from -50? to 150? C (+-1? )Switch selects Celsius or FahrenheitSampling time is just one second, HOLD button retains reading in memoryEasy to read display can be read even in direct sunlightDurable case includes a cover to protect the probe Robinair's new digital thermometer gives you full-feature capabilities in a case that? s small enough to fit in your shirt pocket!? . Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir A/C System Sealant Remover - ROB17622
208.39
208.39
Removes sealant, dye, lubricant, and other contaminants from refrigerant prior to entering the recovery unitUsed with recover, recycle, and recharge units that have external or internal manifold pressure gaugesEasy hook up between vehicle and the A/C recovery unitWorks with refrigerant in either a gas or a liquid stateEasy removal of contaminants A/C System Sealant Remover adds to the life expectancy of your recovery unit. Most Refrigerant Systems products are available for in-store pickup from Advance Auto Parts.
RobinAir A/C VALVE CORE TOOL SET - ROB18340
169.39
169.39
Compact DesignSix-ball couplerQuick connect design with an integral safety sleeve Field service couplers connect to our special Enviro-Guard hoses to allow access to service ports on automotive R-134a A/C systems. The quick-connect design has an integral safety sleeve, which protects against injury and refrigerant loss if the coupler is disconnected under pressure. The compact design easily fits into tight quarters, which is especially handy for retrofits. Six-ball couplers provide a more stable grip on the fitting than do couplers with four balls. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir ACCESS FITTING - ROB13143
10.59
10.59
Normal 0 false false MicrosoftInternetExplorer4 /* Style Definitions */ table. Mso Normal Table {mso-style-name: "Table Normal"; mso-tstyle-rowband-size: 0; mso-tstyle-colband-size: 0; mso-style-noshow: yes; mso-style-parent: "; mso-padding-alt: 0in 5.4pt 0in 5.4pt; mso-para-margin: 0in; mso-para-margin-bottom: .0001pt; mso-pagination: widow-orphan; font-size: 10.0pt; font-family: "Times New Roman"; mso-ansi-language: #0400; mso-fareast-language: #0400; mso-bidi-language: #0400;} 72" hose for R-134a with automatic couplersAluminum manifold1" dial thermometerTemperature / pressure chartBlow molded case Deluxe combination side can tap features: - 1/4" MFI and 1/2" ACME ports, hinged inserts for cans of R-12, R-134a and their respective oils. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir ACCESS FITTING (BULK 25) - ROB13210
7.99
7.99
Robinair oil has a lower moisture content than other oilsEngineered to maintain maximum viscosity at high running temperaturesEngineered to improve cold weather starts Premium oil for vacuum pumps, (4 )Four 1-gallon jugs per case.? Robinair? s oil is engineered to maintain maximum viscosity at high running temperatures and to improve cold weather starts.? Laboratory tests prove that Robinair oil is more thermally stable in comparison to other leading brands, which means it resists breaking down due to heat for a longer period of time.? Robinair oil has a lower moisture content than other oils, thanks to our special packaging and handling procedures. Moisture degrades the oil? s purity, thinning it and reducing the pump? s ability to reach a deep vacuum.? . Most AC Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir ACCESS FITTING HALF UN OD - ROB40401
18.69
18.69
Fits 3/16", 1/4", 5/6", 3/8" OD. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir ACCESS SWIVEL TEE, 1/4inch M - ROB40386
18.69
18.69
RobinAir ACCESS TEE FITTING, 1/4inch - ROB40396
17.79
17.79
RobinAir ACCESS VALVE (6)* - ROB13142
18.69
18.69
RobinAir Access Valve Core Rem/Install - ROB14773
15.29
15.29
Robinair oil has a lower moisture content than other oilsEngineered to maintain maximum viscosity at high running temperaturesEngineered to improve cold weather starts Premium oil for vacuum pumps, (4 )Four 1-gallon jugs per case.? Robinair? s oil is engineered to maintain maximum viscosity at high running temperatures and to improve cold weather starts.? Laboratory tests prove that Robinair oil is more thermally stable in comparison to other leading brands, which means it resists breaking down due to heat for a longer period of time.? Robinair oil has a lower moisture content than other oils, thanks to our special packaging and handling procedures. Moisture degrades the oil? s purity, thinning it and reducing the pump? s ability to reach a deep vacuum.? . Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir ACTIVATED CARBON FILTER - ROB17577
53.39
53.39
Additional or replacement R-12 refrigerant tank for A/C recovery, recharge and recycle machines1/4" fittings: 17800A, 17800-2K, 17700A, 25150, 25175, 25200B series. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir ADAPTER 1/4inch FFL X 1/2inch A - ROB18319
15.99
15.99
Compact DesignSix-ball couplerQuick connect design with an integral safety sleeve Field service couplers connect to our special Enviro-Guard hoses to allow access to service ports on automotive R-134a A/C systems. The quick-connect design has an integral safety sleeve, which protects against injury and refrigerant loss if the coupler is disconnected under pressure. The compact design easily fits into tight quarters, which is especially handy for retrofits. Six-ball couplers provide a more stable grip on the fitting than do couplers with four balls. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir ADJ SPANNER WRENCH - ROB10290
37.89
37.89
Specially designed for accessing vehicle A/C systems for service procedures Five different adapters are included to fit most vehicles with R-12 systems Contains three flexible adapters Contains two 90? brass adapters Fits most A/C manifold sets and recharge and recovery machines Our ROB10237A kit of access adapters are ideal for accessing R-12 vehicle A/C systems, as well as other types of systems!. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir Air Vac for R-12 and R-134a - ROB34970
66.19
66.19
Fast, efficient air operated vacuum pumpRugged Lexan case is both oil? and scratch resistant and comes with a convenient handleCompressed air driven, no oil or moving parts to replace1 cfm1/4" Flare and 1/2" ACME fittings Easy to use - connect back fitting to compressed air source and front fitting to center hose of a standard manifold set attached to an A/C system. 75 PSI rating. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir Base and Foot for 15200 Pump - ROB41186
15.09
15.09
Removes and installs A/C clutch plates fast and easilyWorks with GM A/C compressors V5, DA6 and HR6Used to remove/install clutch on GM V5, DA6, HR6.? This handy tool removes clutch plates for a variety of popular A/C compressors.? This tool can be used both for removing the clutch plate to gain access to the shaft seal and for re-installing it.? The compact design makes it possible to work in tight spots and, in many cases, the tool can be used with the compressor mounted on the vehicle. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir Blue Low Side 90 Degree Manual Coupler - ROB18174
27.19
27.19
Six-ball coupler provide a more stable grip on the fittingAllows access to service ports on automotive R-134a A/C systemsCompact design makes it easy to fit into tight quarters, which is especially handy for retrofitsQuick Connect coupler has an integral safety sleeveColor coded Blue, Low side 90 degree coupler This coupler is for Automotive R-134a, it's a field service coupler that is used to connect our special Enviro-Guard hose. Which allows access to service ports on automotive R-134a A/C systems.? It's designed with the quick connect, which has an integral safety sleeve that protects against injury and loss of refrigerant if the coupler is disconnected under pressure.? . Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir BOTTOM CASE FOR 25000 - ROB19806
40.23
40.23
Allows gas to be recovered via the liquid port of a virgin refrigerant cylinder with a low side coupler for fast filling of your internal cylinderThe brass fitting is metered with a small orifice to prevent refrigerant flooding preventing damage to the recovery units compressor. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir Brass Caps - ROB40572
8.49
8.49
1/4" solid brass capsKnurled ridges for easy grippingPackage of six. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir CASE FRONT C/TECH LINE - ROB19809
53.39
53.39
RobinAir CASE OF 12-16OZ BOTTLES - ROB13119
47.69
47.69
Psi/kPa pressure readingsR-22 and R-134a temperature readings in degrees Fahrenheit. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
Page (4 of 19)
1 2 3 4 5 6 7 8 |
