Buy "robinair" online - search for the best price - compare prices
Page (16 of 19)
12 13 14 15 16 17 18 19 |
RobinAir Replacement Oil-Less Compressor - ROB19652
420.59
420.59
Allows gas to be recovered via the liquid port of a virgin refrigerant cylinder with a low side coupler for fast filling of your internal cylinderThe brass fitting is metered with a small orifice to prevent refrigerant flooding preventing damage to the recovery units compressor. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir Replacement Oil-Less Compressor - ROB19706
500.79
500.79
RobinAir Replacement Thermistor Tube - ROB17162
177.09
177.09
Features low pressure drop with maximum moisture and acid retentionHermetically sealed cans prevent exposure to dirt and moistureComplete with gaskets to interchange with other manufacturer's models48 cu. in. cores can be used in most 4-3/4" O.D. flanged shellsHigher moisture and acid capacity for systems with excessive moisture due to leaks or ruptures Application: 17150A, 17350C, 17355C and 17500B. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir Replacement Valve Cores (Pack of 6) - ROB40352
9.49
9.49
Fits 3/16", 1/4", 5/6", 3/8" OD. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir SEAL FOOT/13047A - ROB13118
15.09
15.09
Psi/kPa pressure readingsR-22 and R-134a temperature readings in degrees Fahrenheit. Most AC Gaskets & Seals products are available for in-store pickup from Advance Auto Parts.
RobinAir SEAL GASKETS TUBE PIERC V - ROB40291
11.49
11.49
This popular Side Wheel Manifold is easy to use and designed for accuracyBar - Solid forged brass for long life; hand wheels are durable, color-coded LexanUniversal Gauges - Clearly marked so they? re easy to read and protected with Lexan lensesField Proven Face Seal Valves - provide a tight seal, less wear and improved flowFahrenheit Scale Standard side wheel manifold set, includes three 36" standard hoses with 1/4" fittings. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir Sensing Tip - ROB16503
29.29
29.29
Specially engineered tipBuilt with a mirror finish for superior sensitivity and durability The materials, shape, and finish of the sensor and surrounding shell are critical to the effectiveness and life of the tip. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir SET OF 3 BALL VALVE ADAPT - ROB18514
70.69
70.69
Connects to any 1/4" charging hose for convenient in-line control of refrigerant flowThe ball valve opens and closes in just a quarter turnFitting features a 45 degree bend for easier connections, even in tight spots. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir SHAFT SEAL INSTALLER/PROT - ROB41060
19.59
19.59
1/4" solid brass capsKnurled ridges for easy grippingPackage of six. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir Shell Sight Glass Assembly for Vacuum Pumps - ROB15135
92.89
92.89
Compact pocket size - 2.5" x 3"Takes guesswork out of evacuation - accurately indicates when system is ready for rechargeDesigned for use under high vacuum; reads down to 10 micronsEasy to read LCD automatically registers smaller numeric segments as system pulls down6' long lead and magnetic mounting strip - allows for convenient, easy-to-read positioning Range: 25,000 to 10 microns; vacuum fitting: 1/4"MFL; power supply: one 9 volt cell battery (included). Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir Side Wheel Manifold - ROB41600
52.63
52.63
Removes and installs A/C clutch plates fast and easilyWorks with GM A/C compressors V5, DA6 and HR6Used to remove/install clutch on GM V5, DA6, HR6.? This handy tool removes clutch plates for a variety of popular A/C compressors.? This tool can be used both for removing the clutch plate to gain access to the shaft seal and for re-installing it.? The compact design makes it possible to work in tight spots and, in many cases, the tool can be used with the compressor mounted on the vehicle. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir SIDE WHEEL MANIFOLD BAR W - ROB40169
78.89
78.89
This popular Side Wheel Manifold is easy to use and designed for accuracyBar - Solid forged brass for long life; hand wheels are durable, color-coded LexanUniversal Gauges - Clearly marked so they? re easy to read and protected with Lexan lensesField Proven Face Seal Valves - provide a tight seal, less wear and improved flowFahrenheit Scale Standard side wheel manifold set, includes three 36" standard hoses with 1/4" fittings. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir Side Wheel Manifold Bar Way - ROB40152
50.89
50.89
Solid Forged Brass Bar - long-lasting and durable with proven face seal valvesNew Universal Gauges - easy-to-read dial faces show R-134A temperatures in degrees Fahrenheit, plus pressures in PSI and kPa. Pressure Temperature Chart - stores in a slot on the back of the manifold, gives you multiple refrigerant capabilityFlexible Holster protects your manifold during use and storageOur R-134a manifold set includes R-134a low permeation hoses with field service couplers on the high and low side hoses. Yellow hose is 1/2" Acme x 1/2" Same quality components and construction as our other manifolds, including durable, solid forged brass manifold bar-but now with 1/2" Acme fittings. New universal gauges with easy-to-read dial faces.? Durable Lexan gauge lenses and hand wheels, stable hanging hook, and hose holders so your charging hoses are protected during storage.? . Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir Side Wheel Manifold Gauge Set - ROB41630
126.09
126.09
Ideal A/C service gauge set - rugged and simple to useIncludes 3 color-coded long 72" length red, yellow and blue hosesComes with protective holster Side wheel valves make this A/C manifold gauge set one of our most popular.? Rugged and durable for frequent service use.? Packaged with three 72" hoses with Quick Seal fittings for easy reach to all A/C ports on most large vehicles and systems.? . Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir SIDE WHEEL MANIFOLD W/UNI - ROB40151
50.89
50.89
RobinAir SLIP-ADJUST TUBING CUT - ROB42035
32.89
32.89
Designed for today's high pressure refrigerantsR-410A pressure temperature scale on gauge faceVibration free Gauges 800 PSI high side, 250 PSI low sideIncludes pressure / temperature chart for a wide range of other refrigerantsThree 60" color coded (1/4" FFL) Enviro-Guard Hoses with in-line ball valves Designed for today's High Pressure Refrigerants with vibration free Gauges scaled to 800 PSI High Side, 250 PSI Low Side. They feature a R-410A Pressure Temperature Scale on the gauge face and also include a pressure / temperature chart for a wide range of other refrigerants. Three 60" color coded (1/4" FFL) Enviro-Guard Hoses make the set complete and even have in-line ball valves for positive shut off preventing blow back when removing or installing them. The hoses rated at 740 psi working pressure, 3700 psi burst pressure. Enviro-Guard Hoses are constructed of special barrier material which prevent virtually any permeation of refrigerant, yet remains flexible. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir SOLDER TEE FITTING 3 PER - ROB40384
15.99
15.99
RobinAir SOLDER UNION 1/4inch OD OR 3 - ROB40427
15.09
15.09
RobinAir SOLDER UNION 3/16inch OR 1/4 - ROB40426
14.19
14.19
RobinAir SOLDER UNION, 1/8inch OD ACC - ROB40416
19.59
19.59
RobinAir SOLDER UNION, 3/16inch OD AC - ROB40417
18.69
18.69
RobinAir SOLDER UNION, 3/8inch OD ACC - ROB40420
14.19
14.19
RobinAir SOLDER UNION, 3/8inch OD OR - ROB40429
10.29
10.29
RobinAir SOLDER UNION, 5/16inch OD AC - ROB40419
14.19
14.19
RobinAir SOLVENT FILTER - ROB17586
19.59
19.59
Closed Loop - Circulates solvent continuously through components (adapters are needed)Pulsing Action - Loosens dirt, corrosion and other debris; by switching the hoses, you can also back flushAir Agitation Needle Valve - Bubbles air into liquid stream to enhance cleaning actionHose Adapters - Contains adapters to mate with 1/4" flare and 3/8" quick disconnect fitting kitsSight Glass - Tank level sight glass for easy filling? The 17580 makes flushing of lines, evaporators and condensers fast and easy. One gallon of flush solvent is recommended for each flush procedure. During the closed loop flush operation, the solvent is filtered through a replaceable filter before being restored to the internal storage vessel. An activated charcoal filter limits odors while solvent is being removed from the component during the purge cycle. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
Page (16 of 19)
