Buy "robinair" online - search for the best price - compare prices
Page (15 of 19)
11 12 13 14 15 16 17 18 19 |
RobinAir REPL. PLNGR SYRINGE INJEC - ROB16262
19.59
19.59
Add oil or dye to fully pressurize A/C systems in secondsR-12 1/4 in. Fitting Robinair's Oil Injector for R12 is made for improved productivity.? ? . Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. POWER CORD - 220/24 - ROB19097
27.49
27.49
Remove and install the valve core from a 1/4" male flare access fitting without the loss of refrigerantDesigned with a stainless steel ball and brazed side fitting for durability and long life Durable, solid brass tool has a ball valve that can be opened and closed in just a quarter-turn, rather than a stem-type valve. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. POWER CORD 110 VT - ROB19049
23.19
23.19
Remove and install the valve core from a 1/4" male flare access fitting without the loss of refrigerantDesigned with a stainless steel ball and brazed side fitting for durability and long life Durable, solid brass tool has a ball valve that can be opened and closed in just a quarter-turn, rather than a stem-type valve. Most Gauges & Specialty Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. POWER CORD ASS'YRD - ROB15366
36.99
36.99
115 volt, 2-stage designHeavy duty motor - high torque design for easy start up and efficient operationDie cast aluminum housing makes the pump lightweight but durableLifetime filtration - the intake filter prevents foreign matter from entering the pumping chamber, and an internal exhaust filter separates oil vapor from the exhaust flow"No-hassle" over-the-counter replacement warranty HVAC high performance vacuum pump is engineered specifically for air conditioning and refrigeration service, and built with Robinair's proven offset rotary vane for fast, thorough evacuation. The two-stage, offset rotary vane design provides powerful, quiet high vacuum capability and assures moisture removal, while the high pumping capacity reduces evacuation time. Direct exhaust causes the exhaust to expel through the handle to direct it away from the service technician. Oil drain valve is positioned at the bottom of the oil reservoir and angled for faster, more complete draining. Oil fill port makes adding oil simple since the port is accessible from the front or either side. The sight glass on the front of the pump shows you when enough oil has been added. 1/2" ACME and 1/4" MFL intake fittings. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. RECTIFIER BOARD 251 - ROB19701
68.19
68.19
Allows gas to be recovered via the liquid port of a virgin refrigerant cylinder with a low side coupler for fast filling of your internal cylinderThe brass fitting is metered with a small orifice to prevent refrigerant flooding preventing damage to the recovery units compressor. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. RED CAP- ASCO SOLEN - ROB19502
13.74
13.74
RobinAir REPL. SEAL END FOR 14476 - ROB13178
7.29
7.29
For models using 34724 Filter-Drier (17700A, 17700-2K, 34700, 34700-2K, 34800, 34800-2K, 34900 Series) Keep recovery and recycling units operating at peak efficiency with a convenient maintenance kit. Contains one quick change filter-drier to be used on both R-12 and R-134a stations, and one 16 ounce bottle of our Premium High Vacuum Pump Oil. Most AC Gaskets & Seals products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. SEAL KIT FOR VAC PU - ROB15367
58.29
58.29
RobinAir REPL. SENSOR/16700 - ROB16704
80.11
80.11
Specially engineered tipBuilt with a mirror finish for superior sensitivity and durability The materials, shape, and finish of the sensor and surrounding shell are critical to the effectiveness and life of the tip. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. SHIELD KIT - ROB43114
50.09
50.09
Use this handy kit to measure natural gas or LP gas pressure across appliance manifolds from 0-35" of water columnTest gas stoves, furnaces, dryers and other gas appliancesEconomical and accurate - easier to use than a manometerDiaphragm gauge is calibrated in inches of water column, also shows ounces per square inchIncludes fitting for quick connection to the appliance manifold Packed in high impact plastic case for protection during transit and use. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. STEM ASS'Y FOR13047 - ROB13117
19.59
19.59
Psi/kPa pressure readingsR-22 and R-134a temperature readings in degrees Fahrenheit. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. STRAP & CAP FOR VAC - ROB15330
11.49
11.49
RobinAir REPL. TANK 7 GALLON - ROB75370
82.99
82.99
Used for measuring the freezing point of either propylene or ethylene glycol based cooling systemsUsed for checking the strength of electrolyte solution batteriesThis precision instrument features high-quality optics with ultra smooth focusingScale range: 32? F to -60? F. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. UPPER GRAY SHROUD - ROB19746
96.49
96.49
RobinAir REPL. UV BULB/REFLECTOR - ROB16254
38.69
38.69
Protect your A/C service equipment - Know whether or not you have acceptable R-134a refrigerant before servicing the vehicleGuard against costly recovery equipment repairsUncover hard to find air contamination - Discover refrigerant identifier notifies you when the system contains excessive airFast and accurate - "pass" and "Fail" lights clearly show if refrigerant is pure enough to be recoveredInput power: 12VDCThe best defense against unknown refrigerant and the risks associated with unknown refrigerant is a refrigerant identifier. Most technicians never question the purity of virgin refrigerant, and most assume the refrigerant in a vehicle is "pure enough" unless the A/C system has a mysterious cooling problem. If a technician has no way of checking the refrigerant before they pull it out of a customer? s vehicle into their recovery equipment it may contaminate their service equipment as well as other vehicles that are serviced with the contaminated equipment. Contaminated refrigerant can wreak havoc on any R134a recovery, recycle and recharge machine. The average repair cost is $300, and in many cases contaminated refrigerant will void the product? s warranty. Shield your Recovery machine from contaminated refrigerant by using the Discover refrigerant identifier before connecting to the vehicle. California approved. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. UV LENS & O-RING - ROB16249
49.29
49.29
Protect your A/C service equipment - Know whether or not you have acceptable R-134a refrigerant before servicing the vehicleGuard against costly recovery equipment repairsUncover hard to find air contamination - DiscovR refrigerant identifier notifies you when the system contains excessive airFast and accurate - "pass" and "Fail" lights clearly show if refrigerant is pure enough to be recoveredInput power: 12VDCThe best defense against unknown refrigerant and the risks associated with unknown refrigerant is a refrigerant identifier. Most technicians never question the purity of virgin refrigerant, and most assume the refrigerant in a vehicle is "pure enough" unless the A/C system has a mysterious cooling problem. If a technician has no way of checking the refrigerant before they pull it out of a customer? s vehicle into their recovery equipment it may contaminate their service equipment as well as other vehicles that are serviced with the contaminated equipment. Contaminated refrigerant can wreak havoc on any R134a recovery, recycle and recharge machine. The average repair cost is $300, and in many cases contaminated refrigerant will void the product? s warranty. Shield your Recovery machine from contaminated refrigerant by using the DiscovR refrigerant identifier before connecting to the vehicle. California approved. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL. VALVE ASS'Y FOR VAC - ROB15368
40.49
40.49
RobinAir REPL. VENT BOLT FOR VAC P - ROB15338
18.89
18.89
RobinAir REPL. WHEEL FOR CART STAT - ROB10751
53.39
53.39
4 in 1 A/C applicationsA reversible wrench with four square openings: 1/4" and 3/16" on one end and 3/8" and 5/16" on the otherSizes are stamped near the openings. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPL.NUT FOR FACE SEAL MA - ROB41616
11.49
11.49
Removes and installs A/C clutch plates fast and easilyWorks with GM A/C compressors V5, DA6 and HR6Used to remove/install clutch on GM V5, DA6, HR6.? This handy tool removes clutch plates for a variety of popular A/C compressors.? This tool can be used both for removing the clutch plate to gain access to the shaft seal and for re-installing it.? The compact design makes it possible to work in tight spots and, in many cases, the tool can be used with the compressor mounted on the vehicle. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
RobinAir REPLACEMENT ADAPTER - ROB17581
15.09
15.09
Closed Loop - Circulates solvent continuously through components (adapters are needed)Pulsing Action - Loosens dirt, corrosion and other debris; by switching the hoses, you can also back flushAir Agitation Needle Valve - Bubbles air into liquid stream to enhance cleaning actionHose Adapters - Contains adapters to mate with 1/4" flare and 3/8" quick disconnect fitting kitsSight Glass - Tank level sight glass for easy filling? The 17580 makes flushing of lines, evaporators and condensers fast and easy. One gallon of flush solvent is recommended for each flush procedure. During the closed loop flush operation, the solvent is filtered through a replaceable filter before being restored to the internal storage vessel. An activated charcoal filter limits odors while solvent is being removed from the component during the purge cycle. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir Replacement Compound Gauge, R-22, R-134A, Celsius - ROB11797
21.49
21.49
RobinAir Replacement Compound Gauge, R-22, R-134A, Celsius - ROB11798
22.19
22.19
RobinAir REPLACEMENT FLOAT SWT - ROB19225
101.89
101.89
Remove and install the valve core from a 1/4" male flare access fitting without the loss of refrigerantDesigned with a stainless steel ball and brazed side fitting for durability and long life Durable, solid brass tool has a ball valve that can be opened and closed in just a quarter-turn, rather than a stem-type valve. Most AC Tools products are available for in-store pickup from Advance Auto Parts.
RobinAir Replacement Kit For Manifold Hose - ROB18019
83.79
83.79
Recovers, recycles, evacuates, and recharges R-12, R-134a, R-22, R-502 MP and HP blends, and many moreIdeal for refrigerated trailers, buses, RVs with multiple refrigerantsLockout panel prevents mixing of refrigerantsComes with two 50-pound tanksInternal clearing Robinair's Refrigerant AC Machine recovers, recycles, evacuates, and recharges R-12, R-22, R-134A and R-502 MP (and HP blends). All in one machine!!!? If your shop services a variety of vehicle types with different or multiple A/C and refrigeration equipment or systems, you need this machine.? DROP SHIP ONLY. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Page (15 of 19)
