Buy "richporter" online - search for the best price - compare prices
Page (3 of 20)
1 2 3 4 5 6 7 |
Richporter Distributor - GM11
229.99
229.99
RPT "All New" Distributors deliver powerful consistent OE spark for maximum combustion efficiency, accurate timing, and rock solid high-rpm performance. From traditional points-style distributors to the latest magnetic, optical, and sync signal designs, we? ve got the right option from which to choose.Product Features:Includes NEW OE style cap and NEW rotor - ready to install!All electronic module components are 100% computer tested to ensure full functionality.Automated test equipment verifies signal strength, correct polarity of wire harness, air gap, crank reluctor tooth size, as well as ignition coil and pickup performance.PT uses the correct gear hardness for the appropriate application. If the gear is too hard, it can damage the cam; if it's too soft, the gear itself can be damaged, which ultimately can cause severe engine damage - possibly even complete engine failure. Most Distributors products are available for in-store pickup from Advance Auto Parts.
Richporter Distributor - GM13
167.49
167.49
Richporter Distributor - GM14
132.99
132.99
Richporter Distributor - GM17
201.49
201.49
Richporter Distributor - GM21
137.99
137.99
Richporter Distributor - GM22
296.99
296.99
Richporter Distributor - GM23
157.49
157.49
Richporter Distributor - GM24
149.09
149.09
Richporter Distributor - HT01
453.99
453.99
Richporter Distributor - HT02
447.99
447.99
Richporter Distributor - HT03
380.89
380.89
Richporter Distributor - HT04
257.99
257.99
Richporter Distributor - HT05
332.39
332.39
Richporter Distributor - HT06
496.49
496.49
Richporter Distributor - HT07
270.89
270.89
Richporter Distributor - HT09
335.99
335.99
Richporter Distributor - HT10
351.39
351.39
Richporter Distributor - HT20
337.99
337.99
Richporter Distributor - HT28
317.99
317.99
Richporter Distributor - HY01
239.99
239.99
Richporter Distributor - HY02
321.99
321.99
RPT "All New" Distributors deliver powerful consistent OE spark for maximum combustion efficiency, accurate timing, and rock solid high-rpm performance. From traditional points-style distributors to the latest magnetic, optical, and sync signal designs, we? ve got the right option from which to choose.Product Features:Includes NEW OE style cap and NEW rotor - ready to install!All electronic module components are 100% computer tested to ensure full functionality.Automated test equipment verifies signal strength, correct polarity of wire harness, air gap, crank reluctor tooth size, as well as ignition coil and pickup performance.PT uses the correct gear hardness for the appropriate application. If the gear is too hard, it can damage the cam; if it's too soft, the gear itself can be damaged, which ultimately can cause severe engine damage - possibly even complete engine failure. Most Sensors products are available for in-store pickup from Advance Auto Parts.
Richporter Distributor - IZ01
406.99
406.99
Richporter Distributor - IZ02
304.99
304.99
Richporter Distributor - IZ03
299.99
299.99
Richporter Distributor - MT01
524.99
524.99
Page (3 of 20)
1 2 3 4 5 6 7 |
