Buy "purolator" online - search for the best price - compare prices
back to search | Brands A-F | Brands G-M | Brands N-S | Brands T-Z | All Brands
Page (2 of 23) | | 1 2 3 4 5 6 | |
Have you ever noticed a musty smell in your vehicle's cabin? Do you seek comfort from your allergies by keeping your vehicle's windows rolled up but get no relief? It could be because you have a dirty cabin air filter! What? s that you ask? Keep on reading! Think of a cabin filter like a home furnace filter. Furnace filters prevent dust and other contaminants from tainting the air you breathe in your house. Cabin filters work the same way in your vehicle. Cabin air filters prevent particles such as pollen, dust, mold spores, tobacco smoke, soot, smog, mildew, pet dander and fungus from getting from the outside into the air you and your passengers breathe inside your vehicle. Installing A BreatheEasy Cabin Filter may sound difficult, but in most cases, it is very simple to install a Purolator BreatheEasy cabin filter--some take less than 5 minutes! For other installations that may be more involved, you may want to contact your mechanic or vehicle dealership service center. Purolator recommends that you replace your dirty cabin filter with a new Purolator BreatheEasy cabin filter every 12,000 to 18,000 miles, or as specified by your vehicle? s manufacturer. Product Features:Multi-Layer ProtectionBetter Breathing for non-allergy and allergy sufferersClean smelling airProtects the air conditioning systemCatches microscopic pollutants like soot, smog, and tobacco smokeActivated charcoal eliminates odors and unhealthy gasesParticular layer restricts entry of large airborne particles into the A/C system like dust, pollen, mold spores and fungus. Most Cabin Air Filters products are available for in-store pickup from Advance Auto Parts.
Have you noticed the small filter located in the air filter housing? Have you ever wondered what it? s for? Or have you possibly thrown it away? That small filter is? known as a breather. Breathers, also known as emission control filters, filter fresh air that? s drawn into the engine? s crankcase. Because the engine must breathe to purge itself of fuel and water vapors, breathers are used in conjunction with the PCV valve. Although small in size, Purolator breathers are big in importance. Like any other filter, the breather is used to trap harmful contaminants and prevent them from damaging the engine. Failure to change the breather will allow unfiltered air (with all of its contaminants and dirt) to be drawn into the engine crankcase which can cause engine damage. Generally, the breather element should be changed every 12,000 miles - however, check with your vehicle manufacturer's recommended change interval as it may vary. The simplest recommended plan of preventive maintenance is to change the breather element at the same time the air filter is changed. This eliminates trying to juggle and anticipate two different change intervals, and it's convenient because you'll be able to access two filters in the air filter housing at once. Not all vehicles are equipped with a breather element. Use the Purolator Application Guide or contact the Pros to find out if your vehicle has a breather. If it does, visit your favorite automobile parts retailer and ask for a Purolator breather filter today!Product Features:Traps harmful contaminantsPrevents harmful contaminants from damaging the engine. Most Air Filter Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
