Buy "permatex" online - search for the best price - compare prices
Page (6 of 7)
2 3 4 5 6 7 |
Permatex Thread Sealant with PTFE (1 oz) - 80631
4.79
4.79
Economical general-purpose fitting sealant. Seals and resists pressure in air, oil, diesel fuel and hydraulic systems. Remains pliable at high and low temperatures. Handles temperatures ranging from -65 F to 300 F and resists common shop fluids. Most Sealers products are available for in-store pickup from Advance Auto Parts.
Permatex Thread Sealant with PTFE (4 oz) - 80632
7.49
7.49
Permatex Threadlocker Pipette Blue - 19967
1.49
1.49
MPN #19967. Permatex Threadlocker Pipette Blue. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker - 24105
16.79
16.79
OEM specified. For dealership warranty requirements, ensures extended drivetrain warranty compliance. Fast-curing formula. Sensor safe, low odor, noncorrosive. Meets performance specs of OE silicone gaskets. Retains high flexibility and oil resistance properties through use of an adhesion system. Handles temperatures ranging from -65 F to 500 F intermittent and resists auto and shop fluids and vibration. Most Sealers products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker (.5 oz) - 22072
3.79
3.79
Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker (3.35 oz) - 82180
7.49
7.49
Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker (9.5 oz) - 85080
15.79
15.79
Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker 9.5 oz.
17.95
17.95
Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker comes in a new easy trigger self dispensing...
Permatex Ultra Blue Multipurpose RTV Silicone Gasket Maker - 81725
17.99
17.99
OEM specified. Permatex Ultra silicones were developed to meet today's technology changes. Sensor-safe, low odor, noncorrosive. Great oil resistance and joint movement values. Eight times more flexible than cork/composite gaskets and 3 times more oil resistant than conventional silicones. Handles temperatures ranging from -65 F to 500 F intermittent and resists auto and shop fluids and vibration. Most Sealers products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Blue Multipurpose RTV Silicone Gasket Maker (3 oz) - 81724
7.49
7.49
Permatex Ultra Blue RTV Silicone Gasket Maker 3 oz.
4.99
4.99
Permatex Ultra silicones were developed to meet todays technology changes. Sensor-safe low odor non-corrosive....
Permatex Ultra Bond Super Glue (.18 oz) - 21309
3.79
3.79
Designed to meet the most demanding automotive adhesive needs, this premium high-performance superglue provides a strong, fast-acting and long-lasting bond. Works on porous and nonporous materials including metals, plastics, laminated plastics, vinyl, rubber, ceramics, paper, wood, textiles, leather, synthetic leather, cork and chipboard. Transparent bond fills gaps to .010". Bottle features a clog-free nozzle and is designed to keep fingers glue-free. Most Sealers products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Copper Maximum Temperature RTV Silicone Gasket Maker (3 oz) - 81878
7.49
7.49
OEM specified. Highest operating temperatures for 4-cylinder, turbocharged or high-performance engines. Sensor-safe, low odor, noncorrosive. Superior adhesion. Three times more oil resistant than conventional silicones and 8 times more flexible than cut gaskets. Handles temperatures ranging from -75 F to 700 F intermittent and resists auto and shop fluids and vibration. Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Disc Brake Caliper Lube - 09977
1.49
1.49
This environmentally friendly, nonmelting synthetic lubricant is formulated to lubricate under adverse braking conditions, helping to assure that critical caliper pins, sleeves, bushings and pistons remain reliably lubricated. Most Brake Lubricant products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Disc Brake Caliper Lube (.5 oz) - 85188
3.99
3.99
An environmentally friendly, non-melting synthetic lubricant, this product is formulated to lubricate under adverse brake conditions to help assure that critical caliper pins, sleeves, bushings and pistons remain lubricated throughout the life of the pad. Most Brake Grease products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Disc Brake Caliper Lube (8 oz) - 24110
11.59
11.59
This environmentally-friendly, nonmelting synthetic lubricant is formulated to lubricate under adverse braking conditions, helping to assure that critical caliper pins, sleeves, bushings and pistons remain reliably lubricated. Most Brake Cleaners & Fluid products are available for in-store pickup from Advance Auto Parts.
Permatex ULTRA GREY Gasket Maker
5.99
5.99
Designed for high torque applications predominantly Japanese designs requiring a unique RTV gasket. Exceeds...
Permatex Ultra Grey Rigid High-Torque RTV Silicone (5 oz) - 22074
4.29
4.29
OEM specified. Designed specially for high-torque and high-vibration applications, like those common in import engines, this premium RTV gasket maker exceeds manufacturers' performance requirements. Noncorrosive and low-odor. Offers maximum vibration resistance with outstanding resistance to oils, cooling and shop fluids. Guaranteed not to leak. Temperature range -65 F to 500 F (-54 C to 260 C) intermittent. Most Sealers products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Grey Rigid High-Torque RTV Silicone Gasket Maker (13 oz) - 82195
17.99
17.99
OEM specified. Designed for high-torque and high-vibration applications like those common in import engines. This premium RTV gasket maker exceeds manufacturers' performance requirements. Noncorrosive and low-odor. Maximum vibration resistance with outstanding resistance to oils, cooling and shop fluids. Won't leak. Handles temperatures ranging from -65 F to 500 F intermittent. Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Grey Rigid High-Torque RTV Silicone Gasket Maker (3.5 oz) - 82194
7.49
7.49
OEM specified. Designed for high-torque and high-vibration applications like those common in import engines. This premium RTV gasket maker exceeds manufacturers' performance requirements. Noncorrosive and low-odor. Maximum vibration resistance with outstanding resistance to oils, cooling and shop fluids. Won't leak. Handles temperatures ranging from -65 F to 500 F intermittent. Most Sealers products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Grey RTV Gasket Maker (9.5 oz) - 85084
22.99
22.99
MPN #85084. Permatex Ultra Grey RTV Gasket Maker (9.5 oz). Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Permatex Ultra Rubber Gasket Sealant and Dressing (1 oz) - 85409
3.49
3.49
Formulated specially for rubber gaskets. Conditions gaskets for longer life and seals potential leak paths. It also functions to hold gaskets in place during installation. The nonhardening, soft-setting formula makes gasket repositioning quick and easy. Provides outstanding oil and fluid resistance. Temperature range -65 F to 400 F (-54 C to 204 C). Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Permatex Valve Grinding Compound (1.5 oz) - 80036
4.29
4.29
Aids valve grinding and seating operations to remove burrs, surface defects, carbon, gum and corrosion. Can be used for lapping and grinding chromium. Mixes with water to form an easy-to-use paste. Most Valve Train Hardware products are available for in-store pickup from Advance Auto Parts.
PERMATEX Vinyl and Leather Repair Kit
9.95
9.95
A complete repair kit for home and automotive vinyl and leather upholstery. Contains heat transfer tool...
Permatex Water Pump And Thermostat RTV Silicone Gasket (.5 oz) - 22071
3.79
3.79
A noncorrosive, sensor-safe RTV silicone gasket material formulated specifically for water pumps and thermostat housings. Highest water-glycol resistance available in an RTV silicone. Handles a temperature range of -65F - 500F intermittent. Most Radiator Additives & Flushes products are available for in-store pickup from Advance Auto Parts.
Page (6 of 7)
2 3 4 5 6 7 |
