Buy "omega" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
Omega 25 Ton Pin Style Jack Stands - OMEHW93526
875.69
875.69
Pin style column adjusts in 2" height intervalsHeavy duty square tubingLarge saddle securely supports loadIdeal for fleet, agricultural, and construction maintenanceSold in pairs Made in the U.S.A. Minimum height: 12-1/4"; maximum height: 20"; adjustment: 2" intervals; base size: 10" x 10". Most Jacks & Accessories products are available for in-store pickup from Advance Auto Parts.
Omega 25 Ton Shop Press with Hand Pump - OME60253
736.89
736.89
Ideal for the removal or installation of gears, universal joints, pulleys, wrist pins, and other various press jobsExcellent for any bending, bonding, or straightening applicationsHeavy duty springs for fast ram returnMulti position bed for work height adjustmentHeavy steel welded construction Specs: Capacity: 25 TonHeight: 59"Width: 28"Work Space (Min.): 2-1/2"Work Space (Max): 34-1/4". Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Omega 3 Ton Jack Stands - OMEHW93503
102.69
102.69
Saddle column provides ratchet action height adjustmentDual purpose handle serves as carry handle and saddle column releaseMulti position ratchet bar provides strength and durabilityFormed base adds stability and helps reduce sinkage into pavementMinimum height 11-1/2", maximum height 17", height intervals 11/16"This pair of jack stands can support up to 3 tons making repair work on your vehicle safe and secure. Four legged based structural frame for stability and quality is unsurpassed by none. If you don't want to lose any productivity or consistency, go with the best, go with Hein-Werner. Made in the U.S.A. Drop Ship Only. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Omega 3 Ton MagicLift Service Jack with Free Pair of Jackstands - OME25030JS
242.69
242.69
Magic Lift performance for a quicker lift for the professional installerHeavy gauge steel constructionMetered release valve for precise load controlSpecial reinforced handle gives a one piece handle feelLarge 5-1/2" saddle provides positive gripping area to vehicle Minimum height is 5-3/4"; maximum height is 20"; Weight: 85 lbs. Includes a FREE pair of Jackstands (32035) with purchase.? While supplies last. Most Hoists, Stands & Accessories products are available for in-store pickup from Advance Auto Parts.
Omega 3 Ton Service Jack - OMEHW93652
561.29
561.29
Heavy duty frame for rugged applicationsLonger chassis ideal for truck and SUVLarge front wheels and rear casters for easy maneuveringEasy alignment over performs specifications, long life, designed for the discriminating professional and it's repairableMade in the U.S.A. This service jack has a one piece handle and flanged side plates to increase strength. The wide frame provides more stability under a load. The cast iron pump base adds strength and durability. The pressure relief valve prevents overloading. The in-line pump assembly assures long life and no off-center forces for ease in pumping, aligning and reduce wear. The cast iron lift arm allows for heave duty loads. U-joint release mechanism for precise load control. Most Tire Repair products are available for in-store pickup from Advance Auto Parts.
Omega 3-1/2 Ton Magic Lift Service Jack - OME27035
330.50
330.50
Innovative design of Magic Lift offers a quick lift for professional performanceLow profile design allows for easy access to lift pointsWide stance and low center of gravity provide optimum stability under load stressUniversal joint release mechanism for precise load controlMin. Ht: 4"; Max Ht.: 21-5/8" Heavy gauge rolled side frames resist twisting. Exclusive designed breather plug eliminates air in the hydraulic system, optimizing jack performance. The handle connection is specially re-enforced to be as firm as the one piece handle. Most Jacks & Accessories products are available for in-store pickup from Advance Auto Parts.
Omega 3,500 lb. Electric Winch - OMEI-9635
239.99
239.99
12 Volt DC poweredHigh torque emergency handleConvenient carrying handleDesigned for pulling, positioningUniversal mounting adapter plate This automotive winch has the rolling capacity of 11, 000 lbs. It comes with a wireless remote control, power lead and remote switch for safe operation. Also includes a 30' winch cable with attached hook, a mounting bracket for trailer hitch ball mounting and emergency crank handle with adjustable clutch.?. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Omega 300 Lb. Capacity Creeper Seat Tool Box - OMEC-2701T
98.99
98.99
Three compartment tool boxVinyl padded seat cushionFour swivel casters for mobilityFront and back tool trays The heavy duty creeper seat with tool storage provides a convenient storage solution for common tools used for brake jobs, detailing, and body work. 4 full bearing casters wheels smoothly and effortlessly move around the shop. Rated at 300lbs along with a fully padded seat for add stability and comfort during use. Most Creepers, Dollys & Ramps products are available for in-store pickup from Advance Auto Parts.
Omega 4 Ton Body Repair Kit with Plastic Case - OME50040
224.00
224.00
Designed for applications of pushing, spreading and pressing of vehicle body panels as well as various component parts and assembliesPumps are rated from 8,000 to 10,000 PSIPerfect fit attachments use quick-connect technology for effortless assemblyPortable for easy usage in shop or on the roadCustom fitted, rugged blow molded storage case A must for body collision repair use. U.S. patent no. 5,520,400. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Omega 40inch Professional Z Creeper - OME91000
99.99
99.99
Transforms with no tools in seconds40" Steel frame constructionPadded seat and headrest450 lbs. rated capacitySix 3" polyurethane wheels. Most Creepers, Dollys & Ramps products are available for in-store pickup from Advance Auto Parts.
Omega 5 Ton Flat Body Cylinder with Adapters - OMEB65139
180.99
180.99
5 ton flat body ram with 4 magnetic adapters is designed to get into the tightest of spotsThe adapters will eliminate the need for different sized flat body rams or self made adaptersEach kit contains a .25, .5, 1, 1.25 in. stackable magnetic adapters and a 5 ton flat body cylinder, which has collapsed height of 1.26 in. and a .24 in. ram strokeThis kit comes in an easy to carry plastic case and can be used with either the 4 or 10 ton Porto-Power kit. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Omega 5 Ton Long Chassis Jack - OME22050
744.99
744.99
Ideal for lifting heavy trucks, buses, agricultural and heavy construction equipment with hard to access lift pointsWide stance, low center of gravity provides optimum stability under load stressHeavy gauge, sturdy frame helps prevent distortion or twistingFoot pedal operation provides quick, no load lifts to load pointU.S. Patented by-pass mechanism protects user and hydraulic cylinder from over-pumping danger. Most Tire Repair products are available for in-store pickup from Advance Auto Parts.
Omega 500 Lbs Clutch Jack - OME40500
987.99
987.99
Handles 14 and 15-1/2 inch clutch assembliesTurns a 2 man job into a 1 man jobThe spline rotates 360 degrees and turns side to sideOptional flywheel adapter is availableComes with both the 1-3/4" and 2" splineThe OME40500 Clutch jack from Omega is designed to make the removal of 14" and 15-1/2" clutches a one man job. The side to side and the vertical tilt adjustment gives you precise clutch alignment. Most Hoists, Stands & Accessories products are available for in-store pickup from Advance Auto Parts.
Omega 6 Ton Magic Lift Jack Stands - OME32066
112.99
112.99
Magic lift technology quickly raises the ratchet bar to support point on vehicleHeavy gauge, steel frame helps prevent distortionCounter-weighted pawl locks ratchet bar securelyOne piece ductile iron ratchet barSturdy, welded steel construction These 6 ton heavy duty jack stands are used to quickly raise the ratchet bar to the desired support point on the vehicle. Capacity: 6 ton Minimum height: 15.75" Maximum height: 24.375" Style: Auto Ratchet. Most Jacks & Accessories products are available for in-store pickup from Advance Auto Parts.
Omega Air Actuated Foot Pump - OME22903
323.29
323.29
Efficiently operate any single-acting rams up to 55 ton capacity in many industrial and construction applicationsProvides up to 10,000 PSI with standard shop air supply of 90-175 PSIMade of durable, lightweight corrosion-free aluminumBuilt-in pressure by-pass system protects overload operationUser friendly foot-actuated design for easy control of moving fluid at tremendous rate; use 3/8" NPT fluid coupler. Most Hoists, Stands & Accessories products are available for in-store pickup from Advance Auto Parts.
Omega Hydraulic Forklift Jack - OME28045
700.49
700.49
Dual lift points for various lifting applications; the lower point is for forklift truck lifts and the higher point is for most farm equipment liftsPrecision control of lifting and lowering functions. Most Hoists, Stands & Accessories products are available for in-store pickup from Advance Auto Parts.
Omega Hydraulic Strut Spring Compressor - OME90000
646.00
646.00
The World's easiest, safest and most efficient equipment to replace strut components! Adjustable strut shaft clasp secures the strut during operationAngle rotatable spring clasp bracket fits most models and sizesSmooth, long stroke hydraulic actuator (ram).Sliding ram bracket provides multiple height adjustment Extendable spring clasp holder with linear adjustment. Remote control hydraulic pump provides effortless, safe one man operation. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Omega Magic-Lift 5-Ton Service Jack
816.95
816.95
Brings the saddle up to lifting point with just one stroke After the saddle reaches lifting point...
Strut Spring Compressor - Hydraulic
709.95
709.95
Smooth long stroke 4-ton ram with remote hydraulic pump provides effortless safe one man operation...
Page (2 of 2)
1 2 |
