Buy "old forge" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
Old Forge Slotted Panel Cutter Air Chisel - OLD1958
18.13
18.13
Black oxide finishUse with a .401 Parker shankThis tool leaves a clean, smooth edge with the cut curling up through the slot in the middle This tool has the exclusive Old forge CURL-CUTMade in the U.S.A. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Old Forge Spot Weld Breaker Air Chisel - OLD1960
10.56
10.56
Black oxide finishUse with a .401 Parker shankThe ideal tool for cutting spot weldsIt also works very well for cutting molding and rivets6" in length. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Old Forge Straight Punch Air Chisel - OLD1980
9.03
9.03
Use for preening and crimping bodies, driving rivets and hinge pins1/2" tip. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Old Forge Stud Remover - OLD2526
33.16
33.16
Here is a compact, powerful Stud Remover that will fit into hard to reach areas and loosen hard to turn studs The tighter the stud, the more firmly the tool grips The Stud Remover is made of high grade, heat treated, alloy steel The finish is bright luster plateHeight: 2". Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Old Forge Tailpipe Cutoff Tool Air Chisel - OLD1968
12.13
12.13
Black oxide finishUse with .401 Parker shankThe sharp concave edge on the thin blade will cut off the tailpipe with ease8-1/4" in length. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Old Forge Tapered Punch Air Chisel - OLD1997
11.00
11.00
The 1/8" diameter point will drive out pins and rivets6-1/2" in lengthWeight: .34 lbs. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Old Forge Upholstery Clip Remover - OLD1001
9.83
9.83
8" in lengthQuickly removes the upholstery clip from the car door.? It fits many different sized clips, including the larger onesHandle is made of sturdy, fluted? plastic and the finish is black oxide. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Old Forge Wide Blade Scraper - OLD1970
16.47
16.47
Blade width is 2"Black oxide finishUse with .401 Parker shankLength: 8.5"Made In U.S.A. Remove gaskets, rust, undercoating, paint, floor tile face area. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Page (2 of 2)
1 2 |
