Buy "mountain" online - search for the best price - compare prices
Page (3 of 18)
1 2 3 4 5 6 7 |
Mountain 10 Ton Capacity Porta-Ram Set - MTN5410
301.99
301.99
Lift capacity: 20,000 lbs.Hydraulic safety bypass valveUser can bleed the unitPowder coatingASME/PALD certified Includes: hand pump, hose, cylinder ram, spreader ram, rubber head, rubber faced flat base, ram toe, plunger toe, 1/2 ton wedge head, 90? V-base, serrated saddle, male thread adapter, and assorted extension tubes: 27", 18", 10" and 5". Packaged in a blow molded case. Shipping weight: 83 lbs. Freight delivery only. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Mountain 100 Pcs. Metric Grease Fitting Kit - MTNGFM100
20.38
20.38
(20) of each of the following: 5, 10, 15, 20, 25 and 30 ampRegular blade style fuses. Most Grease Fittings products are available for in-store pickup from Advance Auto Parts.
Mountain 100' Heavy Duty 14/3 SJTW Extension Cord with Lighted Plug - MTN58100EC
46.40
46.40
Cord shield material: PVCCord voltage rating: 125VCord operating safe temperature: -40 degrees F - 140 degrees FGrounded outlet1 outlet Extension cord is cUL and UL approved. Most Extension Cords products are available for in-store pickup from Advance Auto Parts.
Mountain 1000cc Aluminum Cup for 1L Gravity Feed Gun - MTN4010A
17.99
17.99
Screw on lid for secure containment when spraying at an angleThread size: BSP 3/8" x 18. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mountain 10in. Groove Joint Pliers - MTN14310
5.59
5.59
Right angle teeth allows grip from all directions Undercut tongue and groove eliminates slipping Flush rivet design Made of brushed chrome vanadium steel Double dipped rubber handles for added comfort and grip. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 10inch Adjustable Wrench - MTN11210
19.49
19.49
Ergonomic anti-slip, rubber grip handleMade of professional level chrome vanadium steelPatented Sure Grip jaws grab the flat surface of the fasteners avoiding slippage and damageLaser-etched measurements in inch and millimeter incrementsPatented designed heat treated jaws. Patent # 6,089,130. Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 10inch Crocodile Water Pump Pliers - MTN14910
6.19
6.19
Self gripping design grabs tight and will not releaseSpecial design allows adjustment and retaining of jaw openingDouble dipped rubber handles for added comfort and gripMade of brushed finished chrome vanadium steelLightweight Lifetime warranty - does not cover abuse. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 10inch Indexing / Ratcheting Pry Bar - MTN1803S
4.69
4.69
Indexing head locks into 8 incremental anglesThumb lever for quick and easy lock and release of pry headChrome molybdenum blade tipIdeal for prying seals, bearings, manifolds, oil pans and many other applications 1 year warranty on material and workmanship. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 11 in. Long Reach 20 Degree or Offset Bent Nose Pliers - MTN14120
4.20
4.20
Features and Benefits: Long design allows user to reach into tight placesMade of brushed finished S55 SteelDouble dipped rubber handles for added comfort and grip. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 11in. Long Reach Curved Heavy Duty Diagonal Cutters Pliers Set - MTN14160
10.79
10.79
Features and Benefits: Curved diagonal allows for maximum pulling leverage Made of brushed finish chrome vanadium Pliers are heat treated which provides longer edge life Double dipped rubber handles for added comfort and grip. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 11in. Long Reach Hose Gripper Pliers 1/2in. - MTN14168
5.87
5.87
Features and Benefits: Pliers allow for many applications including removing/replacing hoses, headlights, bulbs, etc. Made of brushed finished S55 Steel Cushioned handles for added comfort and grip. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 11in. Long Reach Hose Gripper Pliers 3/4in. - MTN14169
5.87
5.87
Mountain 11in. Long Reach Hose Gripper Pliers 5/16in. - MTN14167
5.87
5.87
Mountain 11inch Long Reach 45 Degree Bent Nose Pliers - MTN14145
5.19
5.19
Mountain 11inch Long Reach Heavy Duty Slip Joint Long Nose Pliers - MTN14165
3.29
3.29
Mountain 11inch Long Reach Heavy Duty Slip Joint Long Nose Pliers - MTN14166
7.79
7.79
3/4" - 1-1/4" Hose Gripper PliersPliers allow for many applications including removing/replacing hoses, headlights, bulbs, etc.Made of brushed finished S55 SteelCushioned handles for added comfort and grip. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 11inch Straight Nose Long Reach Pliers - MTN14100
5.19
5.19
Mountain 12 Piece Master Spray Gun Cleaning Kit - MTN6112
9.19
9.19
Designed to keep spray guns clean and in good conditionUse with any thinners or solventsHelps clean away paint residual and sludgeSpecially designed for use with HVLP system Kit Includes: 1-Body cleaning brush with wooden handle1-External brush with a twisted metal wire handle3-Fluid tube brushes with twisted metal wire handles1-Straight line wire5-Picks1-Jar of lubricant. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 12 Ton Air / Hydraulic Bottle Jack - MTN5612AH2
177.99
177.99
This unit designed for operating either manually or pneumaticallyThe air hose can swivel in any direction of connection from air sourceThe unit is? fitted with a safety valve against overloading and the 3 piece long handle allows ease of pumpingThe extension screw gives added height when necessaryThe unit is speedy and versatile, air/hydraulic bottle jack is far quicker than using conventional hand operated hydraulic equipmentSafer, since air power permits one-handed operation and enables user to watch load more closelyThe heavy duty design makes them ideal for a wide variety of automotive, truck, industrial and construction work Specifications: Capacity: 12 Ton; ASME certifiedMaximum height: 19-1/2"Minimum height: 10"Hydraulic lift: 9-1/2"Additional screw adjustment: 3"Steel base: 5-1/4" x 7-3/4"Minimum air pressure required: 115 PSINet weight: 26-1/2 lbs. Most Tire Repair products are available for in-store pickup from Advance Auto Parts.
Mountain 12 Ton Capacity Bottle Jack - MTN5612
50.97
50.97
Lift capacity: 24,000 lbs.; ASME certifiedMinimum height: 9.1"; maximum height: 18.5"; hydraulic lift: 9.4", additional screw adjustment: 3.5"Electrostatic painted to prevent corrosionHeat-treated, large diameter extension screwSteel base: 4.5" x 5.25" Shipping weight: 16.4 lbs. Most Tire Repair products are available for in-store pickup from Advance Auto Parts.
Mountain 120 Piece Car Fuse Assortment - MTNFA170
7.06
7.06
(20) of each of the following: 5, 10, 15, 20, 25 and 30 ampRegular blade style fuses. Most Fuses products are available for in-store pickup from Advance Auto Parts.
Mountain 125cc Mini Gravity Feed Plastic Cup - MTN4012
8.00
8.00
Mountain 12inch Adjustable Wrench - MTN11212
25.57
25.57
Mountain 12inch Crocodile Water Pump Pliers - MTN14912
7.69
7.69
Mountain 12inch Groove Joint Pliers - MTN14312
3.29
3.29
Right angle teeth allows grip from all directionsUndercut tongue and groove eliminates slippingFlush rivet designMade of brushed chrome vanadium steelDouble dipped rubber handles for added comfort and grip Lifetime warranty - does not cover abuse. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Page (3 of 18)
1 2 3 4 5 6 7 |
