Buy "mountain" online - search for the best price - compare prices
Page (8 of 18)
4 5 6 7 8 9 10 11 12 |
Mountain 3/8inch Keyless Chuck Reversible Air Drill - MTN7302KL
65.99
65.99
Lightweight compact size is easy to handleProvides full power in forward and reverseEquipped with a built-in muffler for noise reductionPlanetary gear system for long lifeAluminum body with rubber handle grip Specifications: Keyless chuck capacity: 3/8"Free speed: 1,800 rpmOverall length: 7-7/8"Net weight: 2-1/2 lbs.Motor: 1/2 hpAir inlet thread: 1/4" NPTAir hose I.D. size: 3/8"Avg. air consumption: 7cfmNoise level: 86.8 dBA @ 90 PSI. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 12' Blue Reinforced Poly Urethane Re-Coil Air Hose - MTN91009404
27.66
27.66
Coil retracts for easy storage of hose, keeping work area uncluttered6" pigtail on male swivel connection end, 18" pigtail on male solid tool endTails on tool and connection end for comfort and ease when using1/4" MPT M x MS reusable ends, allows for field repair or modification of hose length for application200 PSI working pressure. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 25' 300 lb. Red Rubber Air Hose 1/4inch MxM Coupled - MTN91003998
18.21
18.21
Multi purpose, heavy duty service hoseReinforced red rubber hose for durability and kink resistanceBlack vinyl bend restrictors on each end for longer hose life by couplingsAbrasion and ozone resistant. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 25' Blue Reinforced Poly Urethane Re-Coil Air Hose - MTN91009405
40.64
40.64
Mountain 3/8inch x 25' Extreme Flex Air Hose - MTN91009409
19.06
19.06
Specially formulated thermoplastic compounds provide extreme flexibility in severe cold temperaturesHose features the light weight of PVC and durability of rubber without cold temperature stiffness for easy handlingHighly abrasion resistant, non marking coverStronger wall and tighter fabric reinforcement improve hose kink resistance and working/burst pressures without sacrificing flexibilityTemperature: -40 to 150 degrees Coupled 1/4" MPT with bend restrictors at both ends. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 25' Yellow Nylon Recoil Air Hose plus Tails - MTN91009408
20.21
20.21
Reusable 1/4" MNPT swivel fitting, to allow field repair or modification of hose length for applicationWire spring guards to extend life of hose at coupling endsFittings come with thread sealant applied, no Teflon tape required for your convenienceTails at each end allow for comfort and ease during useCoil retracts for easy storage of hose, keeping work area uncluttered 200 PSI working pressure. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 3/4inch Cylinder Shape Carbide Bur - MTNSA3
19.59
19.59
3/4" Length of cut. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 3/4inch Cylinder Shape Carbide Bur w/Radius End - MTNSC3
21.84
21.84
Mountain 3/8inch x 3/4inch Tree Shape Carbide Bur w/Radius End - MTNSF3
22.54
22.54
Mountain 3/8inch x 35' Low Pressure Air, Water and Antifreeze Hose Reel - MTNHR335
235.00
235.00
300 lb. operating pressureWorks for air, water, anti-freeze, motor oil and ATFAll Brass main shaft and swivel5-1/4" width and 14-7/8" diameterOwner serviceableCartridge style springFully closed bead 1 year warranty on material and workmanship. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 5/16inch Ball Shape Carbide Bur - MTNSD3
15.39
15.39
5/16" Length of cut. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mountain 3/8inch x 50' 300 lb. Red Rubber Air Hose 1/4inch MxM Coupled - MTN91003999
28.89
28.89
Mountain 3/8inch x 50' Extreme - Flex Air Hose - MTN91009410
30.56
30.56
Mountain 30 LED Rechargable Work Light - MTN5830LED
49.99
49.99
Rugged 30 LED work light - drop it, kick it, throw it, ? and it still works? 7.4v Lithium Ion Battery for maximum versatility? External charger? Hand formed and strong PVC handle? Quick 3 hour charge time yields 3 hours plus work time Includes Rocker Switch for On / Off and a hook for hanging the light. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Mountain 36inch Creeper with 4 Casters - MTN3404
45.99
45.99
Powder coated black frameFrame dimensions: 36 in. x 17 in. x 3-1/2 in.Caster size: 2-1/2 in.Cushioned black vinyl cover. Most Creepers, Dollys & Ramps products are available for in-store pickup from Advance Auto Parts.
Mountain 3in Coarse Roloc Disc 25/box - MTN9485
36.00
36.00
Lightweight cleaning "wand" gets into tight spots to remove grease, grime and dirtSupplied with a 4-foot suction hose for solvents1/4" NPTOverall length approximately 16 inches. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mountain 3inch Cone Shaped Buffing Pad - MTN73503-WBC
9.09
9.09
Cone shaped pad for polishing and cleaning tight areasUsed for boats, wheel covers and motorcycles100% twisted woolMachine washablePatent pending3" cone shaped buffing pad made of 100% twisted wool with a 1-1/2" pile height.? 1/4" shaft for air electric or cordless drill.? (Drill not included). Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Mountain 3inch Cut Off Tool - MTN7326
49.99
49.99
Contoured lever throttle with positive self-locking action prevents accidental starting of motorChrome plated steel spark guardBuilt-in speed regulatorHeavy duty motor for tough cutting jobs Specifications: Wheel size: 3"Free speed: 22,000 RPMAir inlet thread: 1/4" NPTAir hose I.D. size: 3/8"Net weight: 1-1/2 lbs.Overall length: 7-1/2"Avg. air consumption: 4 cfmNoise level: 89 dBA @ 90 PSI. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 3inch Holder with 1/4inch in Shank - MTN8540
5.29
5.29
User capability to handle filters from 2-3/8" to 4-3/8" with one kitEasily interchangeable by removing and installing to detente pinsBuyers obtains four filter wrenches for the price of twoMade in the U.S.A. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mountain 3inch Medium Roloc Disc 25/box - MTN9486
36.00
36.00
Mountain 4 inch Plastic Spreaders 100 Pieces Per Box - MTN4526
24.49
24.49
Ideal for spreading body filler. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mountain 4 oz. Metal Chrome Polish for MTN4203 and MTN4204 Kits - MTN4203-2
4.29
4.29
? ? Polish is included in the MTN4203 Polishing Kit? Polish is included in the MTN4204 Polishing Kit? Polish can be used on metal surfaces? Polish can be used on plastic surfaces? Bottle size is 4 ounces Polish designed for use with all types of metal. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mountain 4 Pc. Long Reach Pliers Set - MTN1460
35.69
35.69
Made of S55 SteelDouble dipped rubber handles for added comfort and gripStorage pouch includedIncludes 16in. Needle Nose Pliers -Straight16in. Long Needle Nose Pliers - 20? ? Angle 16in. Long Needle Nose Pliers - 45? ? Angle 16in. Needle Nose Pliers - Cable Hose Gripper. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Mountain 4 Pc. Metric Chrome-Moly Steel Stud Puller Set - MTN1104M
29.50
29.50
Ideal for removing broken studs and screwsMade of Industrial grade chrome molybdenum (chrome-moly) steel alloyComes in blow molded caseIncludes sizes: 6mm, 8mm, 10mm, & 12mm. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Mountain 4 Piece Mini Pick and Awl Set - Neon Handles - MTN1801N
5.29
5.29
Heat treated, chrome plated, chrome vanadium steel shafts with magnetic tipsHigh visibility handle, easy to locateFour picks for removing/installing, aligning, probing and piercingIdeal to assist with O ring removalIncludes: offset 45o hook, straight pick, 90o hook, full hookSet comes in a plastic carrying trayNet weight: 1/3lbs. (.15kg). Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Page (8 of 18)
