Buy "mechanics time saver" online - search for the best price - compare prices
Page (5 of 7)
1 2 3 4 5 6 7 |
Mechanics Time Saver 3/8inch Drive 12 Hole Hot Pink Impact Socket Holder - MTS1382
18.59
18.59
A 12-hole design for semi-deep and deep chrome or impact socketsAccommodates 3/8" thru 3/4" SAE Sockets shown NOT included. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8inch Drive 12 Hole Neon Yellow Impact Socket Holder - MTS1383
20.29
20.29
Mechanics Time Saver 3/8inch Drive 12 Hole Red Impact Socket Holder - MTS1381
20.29
20.29
Mechanics Time Saver 3/8inch Drive 12 Hole Rocket Red Impact Socket Holder - MTS1387
20.29
20.29
Mechanics Time Saver 3/8inch Drive 14 Hole Blue Impact Socket Holder - MTS1480
20.29
20.29
A 14-hole, 2-level socket organizer for 3/8" drive chrome metric. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8inch Drive 14 Hole Red Impact Socket Holder - MTS1481
20.29
20.29
Mechanics Time Saver 3/8inch Drive Vertical Lock A Socket - MTSVLAS38
33.49
33.49
Same locking technology as the famous Lock A SocketInterchangeable locking post2 strips of high powered magnetsGreat for the sides of service carts and tool boxesMakes socket sizes easy to read The vertical Lock A Socket accommodates all types of sockets; swivels, impacts, shallows, deeps, etc... Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 4 Piece Autobody Repair Kit with Fiberglass Handles - MTSPB44FK
92.59
92.59
Fiberglass handlesGreat starter kitThe most common body tools This 4 Piece Autobody repair tool set with fiberglass handles, includes: curved cross chisel hammer, general purpose pick hammer, toe dolly and a light dinging spoon. All packaged in a blow-molded case with graphic cover. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 4 Piece Fiberglass Body Hammer Set - MTSPBH44FK
108.59
108.59
The 4 most popular body hammersFiberglass handles for strength and shock absorbingFine polished facesPackaged in a blow-molded case with graphic cover. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 4-1/2inch 7.5 Amp Angle Grinder - MTS7115
55.99
55.99
71111-piece English or Metric Socket Organizer Our socket organizer is designed to hold a standard 11-piece English or metric set with 1 additional hole for extensions or universal joints. Accommodates 7/32 thru 7/8 SAE and/or 5.5 thru 22mm. Neon Blue. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 5 Row Lock-A-Socket Tray - MTSLASTRAY
58.79
58.79
76 Lock-A-Socket posts allow you to have 1/4", 3/8" and 1/2" drive Lock-A-SocketsHeavy duty powder coated steelSwiveling handles for easy transportingCarry 5 sets of sockets at one timeRubber feet for a non-skid grip This new design uses the same concept as the popular Lock-A-Socket. To lock the socket, just turn the socket to the right 90 degrees. To unlock it, simply turn the socket back to the left 90 degrees. The LAS TRAY is made form 16 gauge powder coated steel, for long-lasting durability. The LAS TRAY comes equipped with two swivel handles for easy carrying, and also rubber pegs on the bottom, to keep the tray from sliding and scratching painted surfaces. The LAS TRAY has two rows of 1/2" drive locking posts. Each row consisting of 14 posts. Two rows of 3/8" drive Locking posts, each row consisting 14 posts. One row of 1/4" drive Locking posts consisting of 20 posts. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 6in x 12in Magnetic Panel - MTS6X12
31.19
31.19
6X126 x 12 Magna Panel Magna Panel is the newest magnetic teal organization product! Designed by mechanics for mechanics, it tightly grips most tools in your toolbox and can be placed on the bottom of a toolbox drawer or on a vertical surface. It's simple! Just place the Magna Panel on the bottom of your tool box drawer (or any metal surface) and start organizing your tools today. No installation required. Magna Panel is easily removed and relocated to change your tool storage layout. Available in three convenient sizes (12" x 12", 6" x 12 & 12" x 6"). Magna Panel is designed to lay side-by-side checkerboard style to cover as much space as you desire. Low profile, only 3/16" thick Made from 16-gauge steel for long lasting durability and high-energy magnets to achieve maximum holding strength Tested and measured at 26 times below FAA in-flight regulations.. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 6inch Diameter Magnetic Parts Tray - MTS3510
6.49
6.49
Stainless steelCan be used horizontally, vertically, or upside downOne magnet This stainless steel parts tray allows you to store nuts, bolts, tools, and etc magnetically.? . Most Garage Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 7 Piece Autobody Repair Tool Kit - MTSPB47K
176.49
176.49
Wood hammer handlesThe major tools for the tradeProfessional quality kitPackaged in a blow-molded case with graphic cover This 7 piece autobody repair tool kit is for the professional.? Octagon shaped hickory handles, polished faces and dolly.? The right tools need for auto body repair packaged in a plastic blow-molded case with graphic cover. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 9.5inch x 5.5inch Stainless Steel Magnetic Parts Tray - MTS3520
12.49
12.49
Permanent magnet with rubber scratch guardCan be used horizontally, vertically, or upside downTray has two magnets This stainless steel parts tray allows you to store nuts, bolts, tools, and etc magnetically. Most Garage Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Black Magnetic Holder - MTS5018
21.99
21.99
5017Magnetic Holder - Black oil and fuel resistantNon-stick high impact plasticPowerful magnetic rubber basesWill NOT magnetize your toolsSecure your tools to any metal surface Comes in an Array of Colors: MTS5010 - Neon BlueMTS5011 - RedMTS5013 - Neon YellowMTS5014 - Solar OrangeMTS5015 - Neon GreenMTS5016 - Dark GreenMTS5017 - Rocket RedMTS5018 - Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Black Wrench Holder 10-19mm - MTS688
19.29
19.29
68810-Piece Wrench Organizer The 10-piece wrench organizer was designed to hang on the side of a tool box or work tray to provide easy accessibility to your combination wrenches. Mix and match your tools in this holder to best serve your particular needs. Organizer accommodates 3/8 thru 15/16 SAE and/or 10 thru 19 mm. Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Blue Lock-A-Wrench - MTSLAW12B
32.99
32.99
Twist one wrench to lock or unlock the entire setMagnetic backing will attach to most metal surfacesHolds up to 12 wrenchesHolds up to a 1" or 24mm wrenchGreat for roll carts This blue 12 piece wrench holder requires a simple twist of one wrench to lock or unlock the entire set. Magnetic backing allows this vertical organizer to conveniently attach to most metal surfaces. Designed to securely hold a variety of wrenches, SAE or Metric. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Blue Magnetic Screwdriver Holder - MTSSDH15-B
32.99
32.99
Magnetically attaches to most metal surfacesHolds up to 15 wrenches magneticallyGreat for service cartsAlso organizes wrenches. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Cross Chisel Shrinking Hammer - MTSPB153S
37.49
37.49
Serrated face for shrinking metalStrong hickory handle3-wedge assembly systemForged and heat-treated headStraight chisel. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Cross Chisel Shrinking Hammer with Fiberglass Handle - MTSPB153SF
37.89
37.89
Serrated face for shrinking metalStraight cross chisel for work in cornersFiberglass handle for strength and shock absorbCushion handleForged and heat treated head. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Curved Cross Chisel Finishing Hammer - MTSPB153B
35.89
35.89
#1 most popular Finishing hammerCurved cross chisel for better angle to cornersOctagon shaped hickory handle3-wedge assembly systemPolished face Bent chisel for work in low-clearance areas. Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Curved Cross Chisel Hammer with Fiberglass Hammer - MTSPB153BF
37.49
37.49
Fiberglass handle for less shock and strengthCurved chisel for work in low clearance areasPolished faceCushion handleDesigned for balance. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Dark Green Wrench Holder 10-19mm - MTS686
19.29
19.29
68610-Piece Wrench Organizer The 10-piece wrench organizer was designed to hang on the side of a tool box or work tray to provide easy accessibility to your combination wrenches. Mix and match your tools in this holder to best serve your particular needs. Organizer accommodates 3/8 thru 15/16 SAE and/or 10 thru 19 mm. Dark Green. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Door Skin Hammer - MTSPB170
44.99
44.99
For forming the door skinOne end angled and the other crowned straightStrong octagon shaped hickory handle3-wedge assembly system for a tight fitPolished faces Door skin hammer with two faces.? 45 degree angle on one end. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Page (5 of 7)
1 2 3 4 5 6 7 |
