Buy "mechanics time saver" online - search for the best price - compare prices
Page (4 of 7)
1 2 3 4 5 6 7 |
Mechanics Time Saver 3/8 in. Drive Universal Green 11 Hole Impact Socket Holder 9-19mm - MTS985
19.99
19.99
985 11-Hole Socket Holder 9 thru 19 mm sizes This 11-hole design is intended for use with Metric swivel impact sockets: 9 thru 19 mm. One hole is designated for extensions. Neon Green. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Black Socket Holder 10-19mm - MTS388
16.29
16.29
388Black Universal Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, Phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Blue Socket Holder 10-19mm - MTS380
16.29
16.29
380Blue Universal Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Neon Blue. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Dark Green Socket Holder 10-19mm - MTS386
16.29
16.29
386Dark Green Universal Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, Phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Dark Green. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Green Socket Holder 10-19mm - MTS385
16.29
16.29
385Neon Green Universal Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Neon green. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Hot Pink Socket Holder 10-19mm - MTS382
16.29
16.29
382Hot Pink Universal Magnetic Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Hot pink. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Red Socket Holder 10-19mm - MTS381
16.29
16.29
381Red Magnetic Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Standard red. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Rocket Red Socket Holder 10-19mm - MTS387
15.49
15.49
387Rocket Red Universal Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, Phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Rocket Red. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Solar Orange Socket Holder 10-19mm - MTS384
16.29
16.29
384Solar Orange Universal Socket Holder Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, Phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Solar orange. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Magnetic Yellow Socket Holder 10-19mm - MTS383
16.29
16.29
383Yellow Magnetic Universal Socket Holders Originally designed to hold a standard 8-piece universal (swivel) socket set, this organizer will also store tools with the same style drive end. Use it to organize: long and short chrome flex sockets, hex heads, flat tips, phillips tips, torx heads with the same size drive ends, welding tips, A/C fittings, and extensions. Accommodates 3/8 thru 3/4 SAE and/or 10 thru 19 mm. Neon yellow. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Neon Blue 11 Hole Impact Socket Holder 9-19mm - MTS980
19.99
19.99
980 11-Hole Socket Holder 9 thru 19 mm sizes This 11-hole design is intended for use with Metric swivel impact sockets: 9 thru 19 mm. One hole is designated for extensions. Neon Blue. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Neon Blue 8 Hole Impact Socket Holder - MTS880
19.99
19.99
880 8-Hole Socket Holder This? 8-hole design is intended for use with English swivel impact sockets: 3/8 thru 3/4 SAE. One hole is designated for extensions. Neon Blue. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Neon Green 8 Hole Impact Socket Holder - MTS885
16.79
16.79
885 8-Hole Socket Holder This? 8-hole design is intended for use with English swivel impact sockets: 3/8 thru 3/4 SAE. One hole is designated for extensions. Neon Green. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Red 11 Hole Impact Socket Holder 9-19mm - MTS981
19.99
19.99
981 11-Hole Socket Holder 9 thru 19 mm sizes This 11-hole design is intended for use with Metric swivel impact sockets: 9 thru 19 mm. One hole is designated for extensions. Red. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Red 8 Hole Impact Socket Holder - MTS881
19.99
19.99
881 8-Hole Socket Holder This? 8-hole design is intended for use with English swivel impact sockets: 3/8 thru 3/4 SAE. One hole is designated for extensions. Red. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Rocket Red 11 Hole Impact Socket Holder 9-19mm - MTS987
19.99
19.99
987 11-Hole Socket Holder 9 thru 19 mm sizes This 11-hole design is intended for use with Metric swivel impact sockets: 9 thru 19 mm. One hole is designated for extensions. Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Rocket Red 8 Hole Impact Socket Holder - MTS887
19.99
19.99
887 8-Hole Socket Holder This? 8-hole design is intended for use with English swivel impact sockets: 3/8 thru 3/4 SAE. One hole is designated for extensions. Rocket Red. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Solar Orange 11 Hole Impact Socket Holder 9-19mm - MTS9
19.99
19.99
984 11-Hole Socket Holder 9 thru 19 mm sizes This 11-hole design is intended for use with Metric swivel impact sockets: 9 thru 19 mm. One hole is designated for extensions. Solar orange. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Solar Orange 8 Hole Impact Socket Holder - MTS884
19.99
19.99
884 8-Hole Socket Holder This? 8-hole design is intended for use with English swivel impact sockets: 3/8 thru 3/4 SAE. One hole is designated for extensions. Solar Orange. Most Wheel Weights products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Yellow 11 Hole Impact Socket Holder 9-19mm - MTS983
19.99
19.99
983 11-Hole Socket Holder 9 thru 19 mm sizes This 11-hole design is intended for use with Metric swivel impact sockets: 9 thru 19 mm. One hole is designated for extensions. Yellow Neon. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive Universal Yellow 8 Hole Impact Socket Holder - MTS883
19.99
19.99
883 8-Hole Socket Holder This? 8-hole design is intended for use with English swivel impact sockets: 3/8 thru 3/4 SAE. One hole is designated for extensions. Neon Yellow. Most Wheel Weights products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8in. Drive Deep 13 Hole Socket Holder - MTS776
19.99
19.99
776 3/8" Drive Deep Socket holder. 13 Holes. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8inch 14 Piece 18inch Long Lock-A-Socket - MTSLAS38
21.19
21.19
Will accommodate all types of sockets, swivels, impacts, shallows, deeps Locks sockets in place by a simple twist to the right Has a high energy magnetic strip on the back so it can be mounted to metal surfaces. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8inch Drive 12 Hole Dark Green Impact Socket Holder - MTS1386
20.29
20.29
A 12-hole design for semi-deep and deep chrome or impact socketsAccommodates 3/8" thru 3/4" SAE Sockets shown NOT included. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8inch Drive 12 Hole Green Impact Socket Holder - MTS1385
20.29
20.29
Page (4 of 7)
1 2 3 4 5 6 7 |
