Buy "mechanics time saver" online - search for the best price - compare prices
Page (2 of 7)
1 2 3 4 5 6 |
Mechanics Time Saver 1/4 in. Magnetic Neon Green 37 Piece Bit Holder - MTS585
16.29
16.29
5851/4" Hex Bit Organizer The 1/4" hex bit organizer holds 37 pieces of your favorite 1/4" hex bits for quick bit changes when used with electric drill or screw gun. Neon Green. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4 in. Magnetic Orange 37 Piece Bit Holder - MTS584
16.29
16.29
5841/4" Hex Bit Organizer The 1/4" hex bit organizer holds 37 pieces of your favorite 1/4" hex bits for quick bit changes when used with electric drill or screw gun. Solar Orange. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4 in. Magnetic Red 37 Piece Bit Holder - MTS581
16.29
16.29
5811/4" Hex Bit Organizer The 1/4" hex bit organizer holds 37 pieces of your favorite 1/4" hex bits for quick bit changes when used with electric drill or screw gun.? Red. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4 in. Magnetic Red 37 Piece Bit Holder - MTS587
16.29
16.29
587 1/4" Hex Bit Organizer 1/4" hex bit organizer holds 37 pieces of your favorite 1/4" hex bits for quick bit changes when used with electric drill or screw gun. Red Rocket. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4 in. Magnetic Yellow 37 Piece Bit Holder - MTS583
16.29
16.29
5831/4" Hex Bit Organizer The 1/4" hex bit organizer holds 37 pieces of your favorite 1/4" hex bits for quick bit changes when used with electric drill or screw gun. Neon Yellow. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4in. Drive Deep Rocket Red Socket Holder 4-14mm - MTS727
19.99
19.99
7271/4" Drive Shallow & Deep Socket Holder26 HolesColor: Rocket RedOur bi-level organizer allows you to store your 1/4" shallow and deep drive sockets into one space-saving unit. Accommodates 1/4 thru 9/16 SAE and / or 4 thru 14 mm. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4in. Drive Shallow / Deep Neon Blue Socket Holder 4-14mm - MTS720
19.99
19.99
7201/4" Drive Shallow & Deep Socket Holder 26 Holes Color: Neon Blue Our bi-level organizer allows you to store your 1/4" shallow and deep drive sockets into one space-saving unit. Accommodates 1/4 thru 9/16 SAE and / or 4 thru 14 mm. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4inch 13 Piece 14inch Long Lock-A-Socket - MTSLAS25
19.50
19.50
LAS251/4" Lock-A-Socket 13 Piece/ 14" LongWill accommodate all types of sockets, swivels, impacts, shallows, deeps Locks sockets in place by a simple twist to the right Has a high energy magnetic strip on the back so it can be mounted to metal surfaces. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 1/4inch Drive Vertical Lock A Socket - MTSVLAS25
33.49
33.49
Same locking technology as the famous Lock A SocketInterchangeable locking post2 strips of high powered magnetGreat for the sides of service carts and tool boxesMakes socket sizes easy to read The Vertical Lock A Socket accommodates all types of sockets; swivels, impacts, shallows, deeps, and etc. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 11inch x 11inch Stainless Steel Magnetic Parts Tray - MTS3540
26.49
26.49
Permanent magnet with rubber scratch guardCan be used horizontally, vertically, or upside downTray has four magnets This stainless steel parts tray allows you to store nuts, bolts, tools, and etc magnetically. Most Garage Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 12 Piece Black Wrench Holder - MTSWH12BK
7.89
7.89
Holds 12 wrenchesCan be mounted on a wall or used in a drawerHas a handle for carrying your wrenchesDurable, high impact plasticFuel and solvent resistant Allows you to store up to 12 wrenches in a drawer or mounted on a vertical surface. Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 12 Piece Blue Wrench Holder - MTSWH12B
7.89
7.89
Mechanics Time Saver 12 Piece Red Wrench Holder - MTSWH12R
7.89
7.89
Mechanics Time Saver 12 x 12 Magnetic Panel --CLEARANCE PRICED-- - MTS12X12
58.99
58.99
Our 1/2" Drive Organizer will store both shallow and deep sockets, SAE and metric sizesAccommodates 3/8" thru 7/8" SAE and/or 10mm thru 19mm Sockets shown NOT included. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 12in Magna Rail - MTSMRM200R
24.19
24.19
MRM200R12 Magna Rail Magna-Rail comes with a flexible magnetic strip on the back to allow mounting on any surface or without the magnetic strip on the back if desired. Magna-Rail is the first product that contains the all new technology of the millennium with superior magnetic power so strong that many tools may have to be slid off of the rail to release them. Magna-Rail is designed to hold a variety of your most used tools-- screwdrivers, wrenches, sockets, pliers, not to mention those nuts and bolts. Magna-Rail measures 12" in length x 2-1/4" in width x 7/8" in height with mounting holes in the product. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 12in x 6in Magnetic Panel - MTS12X6
35.49
35.49
Magna Panel is the newest magnetic tool organization product!Designed by mechanics for mechanics. It tightly grips most tools in your toolbox and can be placed on the bottom of a toolbox drawer or on a vertical surface.It's simple! Just place the Magna Panel on the bottom of your tool box drawer (or any metal surface) and start organizing your tools today. No installation required.Magna Panel is easily removed and relocated to change your tool storage layout.Magna Panel is designed to lay side-by-side checkerboard style to cover as much space as you desire.Low profile, only 3/16" thickMade from 16-gauge steel for long lasting durability and high-energy magnets to achieve maximum holding strengthTested and measured at 26 times below FAA in-flight regulations.. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 12inch X 12inch Magna-Panel and 12inch X 6inch Magna-Panel INCLUDED FREE! - MTS
57.79
57.79
400% stronger when placed on a metal surfaceSafe for computers and other sensitive electronic equipmentWill not magnetize your toolsEliminate the loss of valuable hand toolsGreat for vertical tool storage Magna-Panel is the answer to tool control.? Create the most efficient and organized tool storage space? whether you are using drawers or vertical surfaces.? Simply place the Magna-Panel on the bottom of your toolbox drawer (or any metal surface) and start organizing your tools today.? Magna-Panel is easily removed and relocated to change your tool storage layout.? Magna-Panel is designed to lay side-by-side, checkerboard style to cover as much or as little space needed.?. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 17inch Magna Tray for Metal Service Carts - MTSMR714
21.41
21.41
The Magna Tray's strong magnetic power gives mechanics the ability to organize a wide variety of toolsMade from 16 gauge powder coated steel for long lasting durabilityTired of chasing your tools around as they fall through the cracks of your latest project?. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3 Row 1/2inch Drive Lock-A-Socket Tray - MTSLASTRAY50
45.99
45.99
Features the famous Lock-A-Socket technologyMade of 16 gauge powder coated steel for extra strengthAccommodates 36, 1/2" drive socketsOverall size is 17-1/2" long x 5-1/4" wideRubber pegs located underneath for surface grip and protection The 1/2" drive Lock-A-Socket Tray allows you to securely organize all of your 1/2" drive sockets on one heavy duty tray. This allows you to take your sockets with you to the work area. Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3 Row 1/4inch Drive Lock-A-Socket Tray - MTSLASTRAY25
45.99
45.99
Features the famous Lock-A-Socket technologyMade of 16 gauge powder coated steel for extra strengthAccommodates 51, 1/4" drive socketsOverall size is 17-1/2" long x 5-1/4" wideRubber pegs located underneath for surface protection The 1/4" drive Lock-A-Socket Tray allows you to securely organize all of your 1/4" drive sockets on one heavy duty tray.? This allows you to take your sockets with you to the work area. Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3 Row 3/8inch Drive Lock-A-Socket Tray - MTSLASTRAY38
45.99
45.99
Features the famous Lock-A-Socket technologyMade of 16 gauge powder coated steel for extra strengthAccommodates 36, 3/8" drive socketsOverall size is 17-1/2" x 5-1/4" wideRubber pegs located underneath for surface grip and protection The 3/8" drive Lock-A-Socket Tray allows you to securely organize all of your 3/8" drive sockets on one heavy duty tray. This allows you to take your sockets with you to the work area. Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive 12 Hole Neon Blue Impact Socket Holder - MTS1380
20.29
20.29
1380Neon Blue Impact Socket Holder 3/8" Drive A 12-hole design for semi-deep and deep chrome or impact sockets. Accommodates 3/8 thru 3/4 SAE. Neon Blue. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive 12 Hole Solar Orange Impact Socket Holder - MTS1384
20.29
20.29
A 12-hole design for semi-deep and deep chrome or impact socketsAccommodates 3/8" thru 3/4" SAE Sockets shown NOT included. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive 14 Hole Black Impact Socket Holder - MTS1488
20.29
20.29
1488 Shown above is our 14-hole, 2-level socket organizer for 3/8" drive chrome metric. Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver 3/8 in. Drive 14 Hole Dark Green Impact Socket Holder - MTS1486
20.29
20.29
1486 Shown above is our 14-hole, 2-level socket organizer for 3/8" drive chrome metric. Dark Green. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Page (2 of 7)
1 2 3 4 5 6 |
