Buy "mechanics time saver" online - search for the best price - compare prices
Page (6 of 7)
2 3 4 5 6 7 |
Mechanics Time Saver Door Skin Hammer with Fiberglass Handle - MTSPB170F
45.49
45.49
Double headed with one side at 45 DegreesHigh crownFiberglass handle for strength and anti-vibeFor folding flangesForged and heat-treated head Door skin hammer with fiberglass handle for folding flanges and applying the door skin. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Fender Bumping Hammer - MTSPB155
44.99
44.99
Large hickory handleForged and heat treated headUsed for inside-out hammering3-wedge assembly systemPolished surfaces Fender bumping hammer for inside-out hammering where clearance is an issue. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Fender Bumping Hammer with Fiberglass Handle - MTSPB155F
45.49
45.49
Fiberglass handle for strength and anti-shockFor inside-out hammeringLong reachCushion gripPolished faces. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver General Purpose Dolly - MTSPB2060
47.99
47.99
Comfortable gripDesigned to absorb heavy blowsForged and heat-treatedHigh polish finishCoated with anti-rust preventative General purpose "Rail" dolly.? Designed with a comfortable grip to absorb heavy blows. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Heel Dolly - MTSPB2059
39.99
39.99
Designed to reach into cornersHigh crown on one sideForged and heat-treatedPolishedCoated with anti-rust preventative Heel dolly designed to reach into corners.? Round side for high crown work and a flat side for flat panel straightening? and shrinking. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Hot Stop Paste - MTS7300EACH
19.99
19.99
HOT STOP Thermal Shield Paste is designed to stop heat from traveling through most metals as well as other materials. The beneficial effects cannot be underestimated. HOT STOP will help prevent distortion to metals and plastics caused by heat. Simply apply a bead of HOT STOP to the entire exposed surface to be protected and it will absorb the heat from welding, brazing or soldering. The one property that makes HOT STOP truly amazing is the ability to provide a heat barrier from direct open flame contact. HOT STOP will keep materials cool, even under contact with Map Gas and welding torches. The heat barrier is so efficient, HOT STOP can be applied to thin plastic or rubber and a direct flame from a Map Gas torch (3000? F) will not even distort the material. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Hot Stop Spray Gel - MTS7100EACH
15.00
15.00
HOT STOP Thermal Shield Gel is designed to stop heat from traveling through most metals as well as other materials. The beneficial effects cannot be underestimated. HOT STOP will help prevent distortion to metals and plastics caused by heat. Simply apply a bead of HOT STOP to the entire exposed surface to be protected and it will absorb the heat from welding, brazing or soldering. The one property that makes HOT STOP truly amazing is the ability to provide a heat barrier from direct open flame contact. HOT STOP will keep materials cool, even under contact with Map Gas and welding torches. The heat barrier is so efficient, HOT STOP can be applied to thin plastic or rubber and a direct flame from a Map Gas torch (3000? F) will not even distort the material. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Large Rubber Heel Dolly - MTSPB2055
34.99
34.99
Longer length rubber dollyGreat for working on door skinsFits in cornersRubber coated to reduce metal stretchingHigh crown for forming round panels Works great for door skins and flanges.? Rubber coating helps reduce the stretching. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Light Comma Dolly - MTSPB2065
39.99
39.99
Large crown faceComfortable gripHigh polish finishForged and heat treatedCoated with anti-rust preventative Lightweight comma dolly for low crown and high crown? work. Ergonomic grip helps hold itself to the palm when working. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Light Dinging Spoon - MTSPB3036
24.99
24.99
Thin spoon for light slapping and smoothing out high areas with a hammerLarge face spreads out the blow from a slap or hammer strikeGood for hood alignmentForged and heat-treatedCoated with an anti-rust preventative Light dinging spoon for leveling and smoothing our ridges. Can be used to align hoods but not for prying. Used for slapping and with a hammer to spread out the hammer blow. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Magnetic Holster - MTS100
9.99
9.99
100Holster A practical way of securing containers that need to be close to where you work. Adjustable strap allows a safe and secure fit for containers up to 3" in diameter. Available only in standard Red. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Magnetic Pliers Holder - MTSMPH10R
21.49
21.49
Magnetically holds toolsMagnetically attaches to most metal surfacesHolds up to 10 toolsAlso good for ratchets and extensionsPerfect for service carts and tools boxes The Magnetic Pliers organizer holds up to 10 pliers, ratchets, extensions, and etc. with the full force of high powered magnets in a compact, efficient design. The magnetic backing secures the Magnetic Pliers Organizer onto most any metal surface making it easily accessible whether at the toolbox or under the hood. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Magnetic Wrench Holder for Metric Sizes 8mm-21mm - MTSMWH14MB
33.49
33.49
Holds 14 wrenchesPowerful magnets pull the wrenches into the slotGreat for service carts2" x 12" x 2-1/8" This magnetic wrench holder with 14 graduated slots was engineered to pull and align wrenches into place horizontally using magnets.? Magnetic backing attaches this device inside a toolbox drawer and most metal surfaces. Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Magnetic Wrench Holder for SAE Sizes 1/4inch - 1inch - MTSMWH14SR
33.49
33.49
Magnetically holds 14 SAE wrenchesPowerful magnets pull the wrenches into the slotGreat for service carts2" x 12" x 2-1/8" This magnetic wrench holder with 14 graduated slots was engineered to pull and align wrenches into place horizontally using magnets. Magnetic backing attaches this device inside a toolbox drawer and most metal surfaces. Most Tool Organizers products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Neon Blue Magna-Rack - MTS1580
23.09
23.09
1580Neon Blue Magna Rack Use this rack for keeping a variety of tools at your fingertips-- anything from pens to pliers. The expandable loops will accommodate different socket handles as well as wrenches, screwdrivers, drill bits, scissors, clippers, and other tools. Most Wheel Weights products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Neon Blue Magnetic Holder - MTS5010
21.99
21.99
5010 Magnetic Holder - Neon Blue Oil and fuel resistantNon-stick high impact plasticPowerful magnetic rubber basesWill NOT magnetize your toolsSecure your tools to any metal surface. Comes in an Array of Colors: MTS5010 - Neon BlueMTS5011 - RedMTS5013 - Neon YellowMTS5014 - Solar OrangeMTS5015 - Neon GreenMTS5016 - Dark GreenMTS5017 - Rocket RedMTS5018 - Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Neon Blue Wrench Holder 10-19mm - MTS680
19.29
19.29
68010-Piece Wrench Organizer The 10-piece wrench organizer was designed to hang on the side of a tool box or work tray to provide easy accessibility to your combination wrenches. Mix and match your tools in this holder to best serve your particular needs. Organizer accommodates 3/8 thru 15/16 SAE and/or 10 thru 19 mm. Neon Blue. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Neon Green Magnetic Tool Holder - MTS5015
21.99
21.99
5015Magnetic Holder - Neon GreenOil and fuel resistantNon-stick high impact plasticPowerful magnetic rubber basesWill NOT magnetize your toolsSecure your tools to any metal surface Comes in an Array of Colors: MTS5010 - Neon BlueMTS5011 - RedMTS5013 - Neon YellowMTS5014 - Solar OrangeMTS5015 - Neon GreenMTS5016 - Dark GreenMTS5017 - Rocket RedMTS5018 - Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Neon Green Wrench Holder 10-19mm - MTS685
20.19
20.19
68410-Piece Wrench Organizer The 10-piece wrench organizer was designed to hang on the side of a tool box or work tray to provide easy accessibility to your combination wrenches. Mix and match your tools in this holder to best serve your particular needs. Organizer accommodates 3/8 thru 15/16 SAE and/or 10 thru 19 mm. Solar Orange. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Neon Yellow Magnetic Holder - MTS5013
21.99
21.99
5013Magnetic Holder - Neon Yellow Oil and fuel resistantNon-stick high impact plasticPowerful magnetic rubber basesWill NOT magnetize your toolsSecure your tools to any metal surface Comes in an Array of Colors: MTS5010 - Neon BlueMTS5011 - RedMTS5013 - Neon YellowMTS5014 - Solar OrangeMTS5015 - Neon GreenMTS5016 - Dark GreenMTS5017 - Rocket RedMTS5018 - Black. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Neon Yellow Wrench Holder 10-19mm - MTS683
19.29
19.29
68310-Piece Wrench Organizer The 10-piece wrench organizer was designed to hang on the side of a tool box or work tray to provide easy accessibility to your combination wrenches. Mix and match your tools in this holder to best serve your particular needs. Organizer accommodates 3/8 thru 15/16 SAE and/or 10 thru 19 mm. Neon Yellow. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Orange Wrench Holder 10-19mm - MTS684
19.29
19.29
Mechanics Time Saver Plastic Service Cart - MTS3917
199.99
199.99
3 trays for more storageFour heavy duty rubber castersDimensions: 39" x 17" x 33"550 lbs load capacityBuilt in organization tray. Most Benches, Tables, Carts & Stools products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Pro Body 4 Piece Body / Fender Tool Set - MTSPB44K
93.99
93.99
3 wedge assembly systemCoated with anti-rust preventativeHickory handlesHigh polished facesDesigned for balance This professional quality set includes Thin Toe Dolly, Light Dinging Spoon, Curved Cross Chisel Hammer and a General Purpose Pick Hammer. Packaged in a blow molded case with graphic cover. Most Repair Parts & Accessories products are available for in-store pickup from Advance Auto Parts.
Mechanics Time Saver Red Lock-A-Wrench - MTSLAW12R
32.99
32.99
Twist one wrench to lock or unlock the entire setMagnetic backing will attach to most metal surfacesHolds up to 12 wrenchesHolds up to a 1" or 24mm wrenchGreat for roll carts This red 12 piece wrench holder requires a simple twist of one wrench to lock or unlock the entire set. Magnetic backing allows this vertical organizer to conveniently attach to most metal surfaces. Designed to securely hold a variety of wrenches, SAE or Metric. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Page (6 of 7)
2 3 4 5 6 7 |
