Buy "makita" online - search for the best price - compare prices
Page (4 of 5)
1 2 3 4 5 |
Makita 7.2 V Lithium Ion Cordless Impact Screwdriver Kit - MAKTD020DSEW
125.00
125.00
Ultra compact impact mechanism yields 177 in./lbs. of torqueOperates in straight or pistol grip positionsWeighs only 1 lb. with true economic gripDelivers 3,000 rotational impacts/min. and 2,300 RPMBuilt-in LED light illuminates the work area via a separate switch This ultra compact cordless screwdriver kit runs on a Lithium-Ion battery with the best power to weight ratio at 177 in./lbs.? The batteries and charger provide 2 times more cycles and longer run time with 5 times lower self discharge.? This kit which contains (2) 7.2V Lithium-Ion batteries, a 30 minute charger, 2 phillips/one slotted fastening bits and one drill bit (1/8") with a tool case is great for mechanics, installers, fabricators and repair personnel.? Maita provides a 3 year warranty on tool and 1 year warranty on battery.?. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7.2 Volt 1.3 ah Ni Cd Stick Type Battery - MAKB7000
56.19
56.19
7.2 Volt1.3 amp hour 1 hour charge time"Stick" type batteryWorks in Makita 7.2 V tools This Ni-CD power tool battery is made from the finest cells and parts. It's sleek stick design will work in all 7.2 volt Makita tools. Also has a quick charge time, will meet or exceed any expectations!. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Makita 7.2V - 18V Charger - MAKDC1804
77.49
77.49
Suitable for the following battery types - 7.2, 9.6, 12, 14.4 and 18 Volt DCNiMH and NiCd Cell types1.3 - 3.0 AMP hour. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7.2V Flashlight Bulbs to fit ML700 and ML702 - MAK192240-5
5.99
5.99
Includes 2 bulbs. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7.2V Lithium Ion Battery - MAKBL7010
60.29
60.29
Charges in 20 minutesLithium Ion technology for longer run timeVery lightweight at only 1/2 lb. 1.0 amp hourSuper compact design Replacement battery for TW020DSEW impact screwdriver. Provides longer run time, 5 times lower self-discharge (for use any time). 1 year warranty. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7.2VDC 11-1/8inch Rechargeable Flashlight - MAKML702
40.29
40.29
4 position adjustable headProvides up to 120 minutes of continuous illuminationIncludes spare light bulb which stores inside casing for convenienceNickel Cadmium battery provides stable illuminationComes with a convenient carrying strapBattery and charger sold separately. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7" Hook & Loop Back-Up Pad
25.95
25.95
Padded - Use with hook & loop bonnets foam polishing pads 5/8-11 thread
Makita 7inch Electric Angle Grinder - MAKGA7001L
357.79
357.79
All ball and needle bearings for long lifeExtra heavy duty motor for high production and continuous use6,000 RPM for optimum material removalRemovable side handle can be mounted on either sideAC/DC switch for use with alternative power sourceRugged housing for long lifeSpindle lock for easy wheel changesStandard 5/8" - 11 UNC spindle for various accessories This model includes the following: Grinding wheel (741413-3), Wheel guard (I 64477-4), Flange (224111-9). Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7inch Hook and Loop Back-Up Pad - MAK743052-5
22.49
22.49
For quick changes of wool bonnetsFor use with MAK9227C polishing (743403-A) and compounding (192629-7) wool bonnets5/8 - 11 UNC spindle7" Hook and loop back up pad for use with MAK9227C polishing (743403-A) and compounding (192629-7) wool bonnets. 5/8 - 11 UNC spindle. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7inch Hook and Loop Compounding Bonnet - MAK192629-7
18.79
18.79
14.4 Volt BatteryPod Style2 AmpUse on DC1804, 24SA, 1822, 1439Used for Makita. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7inch Polisher Value Added Kit - MAK9227CX4
257.79
257.79
Powerful 10 amp Makita built motor for long lifePre-set speed dial 600-2300 rpm for varied applicationsElectronic speed control maintains rpm under loadSoft start feature for smooth start upsKit includes 10 amp electronic variable speed polisher, 1 wool bonnet, 1 hook and loop pad, 1 wrench, 1 pair of Mechanix Wear gloves, 1 double sided Miss Makita poster/calendar, all packaged in a heavy duty nylon tote bag.7" Polisher value kit contains: ? A 10 amp electronic variable speed polisher with both straight and loop handles, 1 wool bonnet, 1 hook and loop pad, 1 wrench, 1 pair of Mechanix Wear gloves, 1 double sided Miss Makita poster/calendar, all packaged in a heavy duty nylon tote bag. Pre-set speed setting dial (from 600-3,000 RPM) for maximum control Electronic speed control maintains constant speed under load Easily converts to a sander 3 prong plug to prevent static electricity accumulation Fast and powerful polishing for clearcoat finishes Lock-on button for continuous use at one speed Lightweight at only 6.6 lbs. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7inch Polisher Value Pack Kit with Tool Bag - MAK9227CX5
285.79
285.79
? ? Powerful 10 amp motor for continuous operation600-3000 rpmSoft start feature for smooth start-upsElectronic speed control maintains constant speed under loadLightweight at only 6.8 lbs. Kit includes 4 Micro fiber finish towels, 1 pair of Mechanix Wear gloves and 1 sponge pad. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 7inch Rubber Sanding Backing Pad - MAK192978-2
21.59
21.59
Fits all Makita 7" - 9" sander / grindersUses 7" alum oxide. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V 1.3ah Ni Cd Stick Type Battery - MAKB9000
63.19
63.19
9.6 Volts1.3 amp hour Ni CodCharges in 1 hourWorks in all Makita 9.6V tools that accept "stick" type batteries This 9.6V 1.3ah battery is made from the finest cells and parts. It's sleek stick design allows for a quick change. Also it has a quick charge time and will meet or exceed any expectations!. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V 1.3Ah Ni-CD Rechargeable Battery - MAK192019-4
62.40
62.40
MPN #MAK192019-4. Makita 9.6V 1.3Ah Ni-CD Rechargeable Battery. Most Motorcycle Batteries products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V 10inch Rechargeable Flashlight - MAKML903
44.99
44.99
Provides up to 120 minutes of strong continuous lightingFour position head for angling beam directionComes with carrying strap and extra bulbBattery (632007-4) and charger sold separately. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V 3/8inch Drive Impact Wrench Kit - MAK6991DWE
287.19
287.19
876 in./lbs. of torqueHigh performance Makita made D-28R motor with all ball bearing construction3,000 impacts per minute for maximum efficiencyLightweight, compact design with an overall length of only 6-5/8"Powerful 9.6V Ni-Mh battery runs up to 2 times longer than competitive brands Includes: Impact wrench, (2) 9.6V NiCd batteries, 1 hour charger and case. Most Torque & Impact Wrenches products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V Battery - MAK192321-5
69.99
69.99
192321-59.6 Volt Battery. Most Motorcycle Batteries products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V Battery for 6222 - MAK192638-6
61.89
61.89
9.6V rechargeable Battery (with side buttons)Used for MAK6222For all MAKPAK and SUPER MAKPAK tools. Most Motorcycle Batteries products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V Cordless 3/8inch Driver-Drill and Flashlight Kit - MAK6261DWPLE
160.99
160.99
Makita built motor delivers 200 in./lbs of torque2 speed transmission: 0 - 400 low and 0 - 1300 high, covers a wide range of drilling and driving applications16 torque settings plus drill mode for optimum torque control3/8" keyless chuck for fast and easy bit changesErgonomic shape fits like a glove with even pressure and easy control Soft grip handle provides increased comfort on the job. ML903 flashlight runs up to 2 hours per single charge. 9.6V Driver drill kit includes; drill, flashlight, 2 Ni Cd batteries, 1 hour charger and case. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Makita 9.6V Flashlight Bulbs fits ML900 - MAK192241-3
5.99
5.99
Makita 9.6VDC 12-13/16inch Rechargeable Flashlight - MAKML902
44.99
44.99
4 position adjustable headProvides up to 120 minutes of continuous illuminationIncludes spare light bulb which stores inside casing for convenienceNickel Cadmium battery provides stable illuminationComes with a convenient carrying strapBattery and charger sold separately? . Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita BAT 12V 6911DW - MAK632277-5
74.21
74.21
Features and Benefits: Powerful 6.5 AMP motor for heavy duty continuous workVariable speed (0-550 RPM) for controlled drillingHeavy duty 1/2" industrial quality drill chuckCompact and lightweight (4.8lbs)Large and conveniently located reversing switch and lock-on button Side handle can be attached to either side of the tool for better control. Other features include: convenient belt clip and double insulation. Includes the following: Drill chuck, Chuck Key and Side Handle. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Makita Battery Stick 7000 7.2V
55.95
55.95
Designed for Makita Rechargeable 7.2-volt tools Made with nickel-cadmium Fits Makita models 3700DW 6002D...
Makita Bit Driver/Finder - MAK784810-A
8.76
8.76
MPN #MAK784810-A. Makita Bit Driver/Finder. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Page (4 of 5)
1 2 3 4 5 |
