Buy "lucas oil products" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
Lucas Oil Products Super Coolant - 10640
13.99
13.99
MPN #10640. Lucas Oil Products Super Coolant. Most Radiator Additives & Flushes products are available for in-store pickup from Advance Auto Parts.
Lucas Oil Products Synthetic SAE 75W-90 Transmission and Differential Lube (32 oz.) - 10047
14.99
14.99
Lucas Synthetic SAE 75W-90 Gear Oil is a pure-synthetic, non-foaming, super slick, long lasting lubricant designed especially for heavy-duty or high performance applications. High speed shock load and anti-wear performance have been significantly improved which provides the ultimate protection for gear components. Most Gear Oil products are available for in-store pickup from Advance Auto Parts.
Lucas Oil Products TB Zinc-Plus Engine Break-In Oil Additive (16 oz.) - 10063
15.49
15.49
Designed for race applications, Lucas TB Zinc-Plus Engine Break-In Oil Additive protects the camshaft lifters and valve train during the break-in period of a new motor.Product Features:Designed for race applications requiring additional extreme-pressure additives; not designed for passenger car useFormulated for flat tappet camshafts during break-in or as an additive to any motor oil to help prevent premature wearHelps seat new rings while providing an extreme-pressure additive to help protect the entire valve trainAdd 1 bottle with every oil change. Most Engine Oil Treatment & Additives products are available for in-store pickup from Advance Auto Parts.
Lucas Oil Products Transmision Fluid 1 Quart - 10418
7.99
7.99
MPN #10418. Lucas Oil Products Transmision Fluid 1 Quart. Most Transmission & Drivetrain products are available for in-store pickup from Advance Auto Parts.
Lucas Oil Products Transmission Fix 24 oz. - 10009
- Price: 12.99
- Price: 12.99
Lucas Transmission Fix stops slip, hesitation and rough shifting in worn transmissions. It completely eliminates most seal leaks and lowers operating temperatures in hard-working units. Ideal for motor homes and commercial vehicles, Lucas Transmission Fix is excellent for preventative maintenance and extends fluid life by up to four times. It also extends needed protection to planetary gears. Most Transmission & Drivetrain products are available for in-store pickup from Advance Auto Parts.
Lucas Oil Products X-Tra Heavy-Duty Grease 14.5 oz. - 10301
5.99
5.99
Lucas X-Tra Heavy-Duty Grease is a shear-stable product with enhanced extreme-pressure characteristics and water resistance. It has good mobility at low temperatures, is designed to last up to 3 times longer than ordinary grease, and is an excellent choice for use with high-speed bearings. Most Wheel Bearing Grease products are available for in-store pickup from Advance Auto Parts.
Page (2 of 2)
1 2 |
