Buy "lock technology" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
Lock Technology Super Multi-Piece Easy Access and Inflate-A-Wedge Kit - LTI145
79.86
79.86
New 4 piece easy access tool collapses for each storageScrews together without a coupler for easier accessIncludes a middle extension piece (135-2D1) to go across the car and for long reach applications; also includes a shorter tip (135-2C) for easier use with lock buttons135-2B and 135-2C now come with glow-in-the dark tipsRigid design for easy through-the-window reach This kit allows you to open the vehicle with the door handle, lock button or electric lock switch. Also includes a Plastic Slip Jim (LT-100), 2 plastic door wedges (LT-271) and Inflate-A-Wedge (LT-275). Most AC Valves & Tubing products are available for in-store pickup from Advance Auto Parts.
Lock Technology Supreme Master Automotive Lock Out Kit - LTI1000
163.29
163.29
Contains 18 pieces and is the ultimate product available today to handle emergency lock outsThis kit is packaged in a custom heavy duty blow molded carrying with vinyl insertsIncludes a fully illustrated instruction manualNow includes the LT-275 Inflate-A-Wedge. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Lock Technology Timing Gear Pliers - LTI995
90.29
90.29
Aids in removal and replacement of timing gears and serpentine belt pulleysInterchangeable composite inserts safely grip timing gear teethPerforms timing gear removal by preventing rotation of timing gear sprocket while retaining nut or bolt are removedPrevents camshaft rotation during timing gear removal eliminating valve/piston interference and subsequent damageSecurely grips all serpentine belt pulleys Patented - US7,077,036B1. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Lock Technology Tire Valve Tool - LTI950
10.69
10.69
Easily removes and replaces tire valve stem caps and valve stem cores for all tire and wheel applications. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Lock Technology Truck Brake Spring Installer - LTI880
10.96
10.96
A must have tool for 3/4 ton and heavier trucksThe rotating pivot point adjustable head allows the mechanic to clear obstacles around assemblies in rear brake systemsDesigned with a T-handle to provide the mechanic maximum torque when compressing and twisting stiff springs which hold down pins protruding through rear of break backing plate. Most Brake Tools products are available for in-store pickup from Advance Auto Parts.
Lock Technology Universal Piston Brake Press - LTI770
32.99
32.99
Universal application on cars, light and heavy trucksSingle piece operation eliminates nuts and bolts to assemble and disassemble on brake assemblies This tool is used to press in dual brake pistons.? Also works on single pistons.? Its rugged design allows for a long and stronger tool life.? Simple to use!. Most Brake Tools products are available for in-store pickup from Advance Auto Parts.
Lock Technology Wet Sanding Block System - LTI250
22.39
22.39
? Eliminate water buckets and hoses when wet sanding vehicles at your shopWet sanding block has an integrated 25 ft. plastic water hose with flow regulator valveHose connects to any standard water faucet or tapFast, easy clean-up reduces mess on or around the vehicle. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Page (2 of 2)
1 2 |
