Buy "litens" online - search for the best price - compare prices
Page (20 of 20)
16 17 18 19 20 |
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920905A
69.99
69.99
Litens Automotive is the original equipment supplier to Toyota for this decoupling alternator pulley. This replacement pulley is also designed and produced by Litens and is exact in all form, fit, and performance characteristics as the original equipment part (with the exception of not having the car manufacturer's logo or part number applied to the part). Decoupling pulleys are engine specific and should never be interchanged with other types of pulley technology. The Litens OAD type pulley is designed to free-wheel in one direction and, with an internal spring and damping device, softly engage in the opposite direction. The OAD is designed as a sacrificial part of the front-end accessory drive system, protecting other belt driven component as well as the alternator. The correct decoupler pulley ensures smooth, quiet performance as well as increasing vehicle gas mileage. Under normal driving conditions, the original pulley will require replacement in approx. 100,000 - 120,000 miles. Product Features:Patented Original Equipment Design Protects the alternator and other front-end accessory drive components.Installation instructions included.New plastic cap included with the OAD.Tools Required - Litens recommends using Miller Special Tools P/N 8433A and a torque wrench.Professional mechanics can install this replacement OAD in approximately 1 hour. During alternator replacement, belts, tensioners, and routing pulleys should be inspected. Most Alternator Pulleys products are available for in-store pickup from Advance Auto Parts.
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920906A
78.99
78.99
Litens Automotive is the original equipment supplier to Toyota for this decoupling alternator pulley. This replacement pulley is also designed and produced by Litens and is exact in all form, fit, and performance characteristics as the original equipment part (with the exception of not having the car manufacturer's logo or part number applied to the part). Decoupling pulleys are engine specific and should never be interchanged with other types of pulley technology. The Litens OAD type pulley is designed to free-wheel in one direction and, with an internal spring and damping device, softly engage in the opposite direction. The OAD is designed as a sacrificial part of the front-end accessory drive system, protecting other belt driven component as well as the alternator. The correct decoupler pulley ensures smooth, quiet performance as well as increasing vehicle gas mileage. Under normal driving conditions, the original pulley will require replacement in approx. 60,000 - 70,000 miles. Product Features:Patented Original Equipment Design Protects the alternator and other front-end accessory drive components.Installation instructions included.New plastic cap included with the OAD.Tools Required - Litens recommends using Miller Special Tools P/N 8433A and a torque wrench.Professional mechanics can install this replacement OAD in approximately 1 hour. During alternator replacement, belts, tensioners, and routing pulleys should be inspected. Most Alternator Pulleys products are available for in-store pickup from Advance Auto Parts.
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920907A
78.99
78.99
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920915A
86.99
86.99
Litens Automotive is the original equipment supplier to Chevrolet Camaro decoupling alternator pulley. This replacement pulley is also designed and produced by Litens and is exact in all form, fit, and performance characteristics as the original equipment part (with the exception of not having the car manufacturer's logo or part number applied to the part). Decoupling pulleys are engine specific and should never be interchanged with other types of pulley technology. The Litens OAD type pulley is designed to free-wheel in one direction and, with an internal spring and damping device and softly engage in the opposite direction. The OAD is designed as a sacrificial part of the front-end accessory drive system, protecting other belt driven component as well as the alternator. The correct decoupler pulley ensures smooth, quiet performance as well as increasing vehicle gas mileage. Under normal driving conditions, the original pulley will require replacement in approx. 60,000 - 100,000 miles. Specifically designed for 2010and newer Camaro's with a 3.6L engine and the Saturn Vue (2009 and newer). Supplied with a new protective cap. Under normal driving conditions, it is best to replace this alternator pulley at 80,000 miles Product Features:Patented Original Equipment Design. Manufactured by the original equipment part supplier to insure proper form, fit, and performance.Protects the alternator and other front-end accessory drive components.Installation instructions included.New plastic cap included with the OAD.Tools Required - Litens recommends using an extra long Torx 50 driver bit and a 17X20 spline tool such as a Miller Special Tools P/N 8823Professional mechanics can install this replacement OAD in approximately 1 hour. During alternator replacement, belts, tensioners, and routing pulleys should be inspected. Most Alternator Pulleys products are available for in-store pickup from Advance Auto Parts.
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920931A
107.99
107.99
Litens Automotive is the original equipment supplier to Chevrolet Camaro decoupling alternator pulley. This replacement pulley is also designed and produced by Litens and is exact in all form, fit, and performance characteristics as the original equipment part (with the exception of not having the car manufacturer's logo or part number applied to the part). Decoupling pulleys are engine specific and should never be interchanged with other types of pulley technology. The Litens OAD type pulley is designed to free-wheel in one direction and, with an internal spring and damping device and softly engage in the opposite direction. The OAD is designed as a sacrificial part of the front-end accessory drive system, protecting other belt driven component as well as the alternator. The correct decoupler pulley ensures smooth, quiet performance as well as increasing vehicle gas mileage. Under normal driving conditions, the original pulley will require replacement in approx. 60,000 - 100,000 miles. Specifically designed for 2010and newer Camaro's with a 6.2L engine and automatic transmission. Supplied with a new protective cap. Under normal driving conditions, it is best to replace this alternator pulley at 80,000 miles Product Features:Patented Original Equipment Design. Manufactured by the original equipment part supplier to insure proper form, fit, and performance.Protects the alternator and other front-end accessory drive components.Installation instructions included.New plastic cap included with the OAD.Tools Required - Litens recommends using an extra long Torx 50 driver bit and a 17X20 spline tool such as a Miller Special Tools P/N 8823Professional mechanics can install this replacement OAD in approximately 1 hour. During alternator replacement, belts, tensioners, and routing pulleys should be inspected. Most Alternator Pulleys products are available for in-store pickup from Advance Auto Parts.
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920954A
69.99
69.99
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920971A
114.99
114.99
Litens Automotive is the original equipment supplier to Chrysler for this Jeep/Dodge decoupling alternator pulley. This replacement pulley is also designed and produced by Litens and is exact in all form, fit, and performance characteristics as the original equipment part (with the exception of not having the car manufacturer's logo or part number applied to the part). Decoupling pulleys are engine specific and should never be interchanged with other types of pulley technology. The Litens OAD type pulley is designed to free-wheel in one direction and, with an internal spring and damping device, softly engage in the opposite direction. The OAD is designed as a sacrificial part of the front-end accessory drive system, protecting other belt driven component as well as the alternator. The correct decoupler pulley ensures smooth, quiet performance as well as increasing vehicle gas mileage. Under normal driving conditions, the original pulley will require replacement in approx. 60,000 - 100,000 miles. Product Features:Patented Original Equipment Design. Manufactured by the original equipment part supplier to insure proper form, fit, and performance.Protects the alternator and other front-end accessory drive components.Installation instructions included.New plastic cap included with the OAD.Tools Required - Litens recommends using Miller Special Tools P/N 8433A and a torque wrench.Professional mechanics can install this replacement OAD in approximately 1.5-2 hour. During alternator replacement, belts, tensioners, and routing pulleys should be inspected. Most Alternator Pulleys products are available for in-store pickup from Advance Auto Parts.
Litens Overrunning Alternator Decoupling (OAD) Pulley - Original Equipment Quality - 920993A
55.99
55.99
Litens Automotive is the original equipment supplier to Honda for this decoupling alternator pulley. This replacement pulley is also designed and produced by Litens? and is exact in all form, fit, and performance characteristics as the original equipment part (with the exception of not having the car manufacturer's logo or part number applied to the part). Decoupling pulleys are engine specific and should never be interchanged with other types of pulley technology. The Litens OAD type pulley is designed to free-wheel in one direction and, with an internal spring and damping device, softly engage in the opposite direction. The OAD is designed as a sacrificial part of the front-end accessory drive system, protecting other belt driven component as well as the alternator. The correct decoupler pulley ensures smooth, quiet performance as well as increasing vehicle gas mileage. Under normal driving conditions, the original pulley will require replacement in approx. 60,000 - 100,000 miles. Product Features:Patented Original Equipment Design. Manufactured by the original equipment part supplier to insure proper form, fit, and performance.Protects the alternator and other front-end accessory drive components.Installation instructions included.New plastic cap included with the OAD.Tools Required - Litens recommends using Miller Special Tools P/N 8433A and a torque wrench.Professional mechanics can install this replacement OAD in approximately 1.5-2 hour. During alternator replacement, belts, tensioners, and routing pulleys should be inspected. Most Alternator Pulleys products are available for in-store pickup from Advance Auto Parts.
Litens Tensioning Pulley -Original Equipment Quality - 900209A
100.99
100.99
This Litens belt-tensioning pulley is supplied by one of the largest automotive pulley suppliers in the world and meets all form, fit, and performance characteristics of the original equipment part . Like the Original Equipment (O.E.) pulley, the Litens replacement part is constructed of heavy duty steel for long life and trouble free performance. This pulley, is manufactured in Japan for both O.E. and aftermarket Suzuki applications.Product Features:Manufactured by one of the world's largest Original Equipment supplier of accessory drive tensioners and pulleys.Heavy Duty Steel PulleyPrecision steel stamping with close tolerance ball bearing pocket. Electro-deposited coating (e-coat) for superior corrosion resistance.Running surface designed and engineered for proper belt tracking. Most Belt Components products are available for in-store pickup from Advance Auto Parts.
Litens Tensioning Pulley Assembly - Original Equipment Quality - 900166A
53.99
53.99
This pulley is manufactured by Litens Automotive - inventor of the first automatic belt tensioner in 1979 and today the worlds largest supplier of Original Equipment (O.E.) belt tensioning and routing products. This pulley is produced for serpentine belt routing applications and as the pulley component on automatic tensioner applications. This pulley conforms to original equipment material, tolerances, and specifications. The part is made in Canada and meets all performance and durability requirements. Applications include Ford Ranger vehicles. Complete belt tensioning assembly - includes new bracket and pulley..Product Features:Manufactured by the world's largest Original Equipment supplier of accessory drive tensioners and pulleys.Complete assembly - pulley mounted to adjustable bracket. Pre-assembled pulleys save installation time and insure that all components are assembled to original specifications for both installation and performanceGlass Reinforced thermoplastic for optimized dimensional control and running surface durability.Precise dimensional tolerance for smooth operation and long lifeService free sealed ball bearing. Molded -in ball bearing for optimal fit and long life. Most Belt Components products are available for in-store pickup from Advance Auto Parts.
Litens Tensioning Pulley Assembly - Original Equipment Quality - 900485A
35.99
35.99
This pulley is supplied by Litens Automotive - inventor of the first automatic belt tensioner in 1979 and today the worlds largest supplier of Original Equipment (O.E.) belt tensioning and routing products. This pulley is produced for serpentine belt routing applications and as the pulley component on automatic tensioner applications. This pulley conforms to original equipment material, tolerances, and specifications. The part meets all performance and durability requirements. Fits automotive applications including Mazda6. Comes complete with new bolt, dust shield, and spacer. Product Features:Manufactured by one of the world's largest Original Equipment supplier of accessory drive tensioners and pulleys.Heavy Duty Steel PulleyPrecision steel stamping with close tolerance ball bearing pocket. Electro-deposited coating (e-coat) for superior corrosion resistance.Running surface designed and engineered for proper belt tracking. Most Belt Components products are available for in-store pickup from Advance Auto Parts.
Litens Tensioning Pulley Assembly - Original Equipment Quality - 900500A
73.99
73.99
This pulley is supplied by Litens Automotive - inventor of the first automatic belt tensioner in 1979 and today the worlds largest supplier of Original Equipment (O.E.) belt tensioning and routing products. This pulley is produced for serpentine belt routing applications and as the pulley component on automatic tensioner applications. This pulley conforms to original equipment material, tolerances, and specifications. The part meets all performance and durability requirements. Fits Infiniti G35 applications. Comes complete with new bolt, dustcover, and spacer.Product Features:Manufactured by one of the world's largest Original Equipment supplier of accessory drive tensioners and pulleys.Heavy Duty Steel PulleyPrecision steel stamping with close tolerance ball bearing pocket. Electro-deposited coating (e-coat) for superior corrosion resistance.Running surface designed and engineered for proper belt tracking. Most Belt Components products are available for in-store pickup from Advance Auto Parts.
Page (20 of 20)
16 17 18 19 20 |
