Buy "lisle" online - search for the best price - compare prices
Page (3 of 35)
1 2 3 4 5 6 7 |
Individual Torx Bit Socket - T40 - 3/8" Drive
6.95
6.95
Made of tough heat-treated alloy steel By Lisle.
Individual Torx Bit Socket - T47 -3/8" Drive
5.95
5.95
Individual Torx Bit Socket - T50 - 3/8" Drive
6.95
6.95
Large Magnetic 1/2" Socket Tray- Green
32.95
32.95
Twenty-two seperate socket compartments allow you to keep your 1/2 drive standard and deep sockets in...
Large Magnetic 1/2" Socket Tray- Red
32.95
32.95
Large Magnetic 1/4" Socket Tray- Red
19.95
19.95
Twenty-six seperate socket compartments allow you to keep your 1/4 drive standard and deep sockets in...
Large Magnetic 3/8" Socket Tray- Green
25.95
25.95
Holds 28 Sockets up to 1 or 24mmBy Lisle.
Large Magnetic 3/8" Socket Tray- Red
25.95
25.95
Large Wheel Creeper
94.95
Large Wheel Creeper
94.95
Creeper Yellow 4 Inch Large Wheels Ergonomic design Low profile Resists solvents and grease. Metal compression...
Lisle ? Side Winder? Hose Reel - LIS50350
85.79
85.79
Versatile installation means the reel can be fastened in any direction, on a bench, under a bench, on a wall, from the ceiling, on a compressor or on a service truckBase has a six hole pattern for bench mounting and a center line pattern for mounting on a stud wallSupplies 28 CFM at 90 PSI. Reel holds 150 feet of 5/8" OD hose or 100 feet of 3/4" OD hoseDimensions: Diameter 17 3/4", Width 11", Height 19" Coil and uncoil your air hose neatly and quickly to prevent damage.? The Side Winder air hose reel provides a large 10" diameter reel to prevent tight coils in your air hose.? Two built-in tool hangers keep your air chuck, blow gun or other air tools handy.? The constant supply 1/4" NPT brass swivel keeps air flowing freely and handles up to 250 PSI. even when dispensing or winding air hose.? A coil spring brake keeps reel from unrolling, yet allows easy dispersion. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Lisle #1 Philip Screwdriver Bit - LIS29630
1.87
1.87
29600Antenna Nut Socket. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Lisle #1 Phillips 1/4in. Hex Screwdriver Bit - LIS25410
1.39
1.39
Prevents damage to flare nuts and other soft metal fittings. Skin-packed. Shipping wt. 4 oz. Most Screwdrivers & Sets products are available for in-store pickup from Advance Auto Parts.
Lisle #2 Philip Screwdriver Bit - LIS30180
1.87
1.87
301703/8 Slotted / 5/16 Hex Screwdriver Bit. Most Screwdrivers & Sets products are available for in-store pickup from Advance Auto Parts.
Lisle #3 Philips Screwdriver Bit - LIS29550
1.89
1.89
Checks both low voltage and spark plug wiresThe low-side checks AC and DC current up to 28 volts with an power onThe high-side checks spark plug wires without piercingComplete with insulated clip Skin-packed. Shipping wt. 3 oz. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Lisle #4 Philip Screwdriver Bit - LIS30190
2.09
2.09
Lisle 0-300 PSI 14mm and 18mm Compression Tester - LIS20250
39.69
39.69
Gauge registers 0 - 300 P.S.I. and 0 - 2100 kpa Fits 14mm and 18mm thread sizes Compression tester is made to quickly and accurately check compression on gasoline engines. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Lisle 1 Quart Spray Bottle - LIS19772
6.89
6.89
Industrial sprayer for use with light oils, solvents, and detergentsThe durable polyethylene bottle is impervious to high and low temperaturesThe trigger mechanism is resistant to damage caused by caustic materials. Most Water Containers products are available for in-store pickup from Advance Auto Parts.
Lisle 1-1/2in. Blade for LIS51000 6/Pk - LIS51130
4.69
4.69
Sharp steel blade quickly peels off carbon, sludgeSharp, hardened steel blades remove carbon, old gasket material, adhesives, sludge and other hard-to-clean substances from blocks, heads, etc.Comes with three blades. 1", 1-1/2"' and 2" widthsTool will hold single edge razor blade for bumper stickers and decalsSkin-packed. Shipping wt. 6 oz. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Lisle 1-1/2inch Rear Disc Brake Caliper Adapter - LIS25080
9.59
9.59
Adapters are individually skin-packed for do-it-yourselfersUse with a ratchet and 3/8" drive extensionPress downward and turn to compress piston 1-1/2" adapter (narrow pins) for most Hondas, Mazdas, Dodge Conquests, Mitsubishi Starions and 1 1/2" GMs (wide pins) for most Fords, Toyotas and Fieros. Most Brake Tools products are available for in-store pickup from Advance Auto Parts.
Lisle 1-1/2inch to 3inch Pipe Shaper - LIS32000
38.49
38.49
Rounds out exhaust pipes that are crushed or bentReshapes pipes bent or flared out by placing big end over pipeRange is 1 1/2" - 3 5/8" (38.1 - 92mm)Boxed when delivered Pipe End Shaper rounds pipes in or out.? Brought to you by Lisle.?. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Lisle 1-1/2inch to 3inch Small Engine Piston Ring Compressor - LIS18500
15.69
15.69
For small cylinders: 1-1/2" to 3" (38.1-76.2mm)Quality tool at a low priceTakes all the rings at one setting. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Lisle 1-1/8inch and 1-3/8inch Large Valve Lapper - LIS21100
6.96
6.96
For hand lapping valvesThick, hardwood handles for easy lapping1-1/8" and 1-3/8" diameter cups for larger valvesSkin-packed. Shipping wt. 2 oz. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Lisle 1-5/8inch to 2-7/16inch Exhaust / Tailpipe Expander - LIS34400
119.09
119.09
Use with an impact wrench to quickly stretch pipes for connection. Two collet sets fit pipes from 1 5/8" to 2 7/16"Can be used while the pipe is on the carThe pipe stretcher is a convenient, inexpensive alternative to hydraulic pipe expandersClam shell packageShipping wt. 4 lb. 6 oz. Exhaust and Tailpipe Stretcher stretches all pipes including stainless steel.? Useful for removing the crimp left by the pipe clamp. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Lisle 1/2 in. Square Drive Adapter - LIS57560
5.03
5.03
57560Adapter 1/2 inch Square Drive. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Lisle 1/2in. Drive External Torx Socket E-18 - LIS26860
9.02
9.02
For external torx boltsSeven sizes E-6 thru E-16The three smaller sizes are 1/4" drive; the four larger sizes are 3/8" driveMade of heat-treated alloy steelSockets are kept in a convenient vinyl holder Fits Ford under body cross members, rear wheel brakes on Thunderbirds and Cougars, and dual wheel Ford trucks. Use with 1/2" drive. 26750 Torx Socket Set. Skin-packed. Shipping wt. 10 oz. Most Socket Sets products are available for in-store pickup from Advance Auto Parts.
Page (3 of 35)
1 2 3 4 5 6 7 |
