Buy "kleinn train horns" online - search for the best price - compare prices
Page (4 of 5)
1 2 3 4 5 |
Kleinn Train Horns Heavy Duty Onboard Air System 6450 Kleinn compressor kits
545.99
545.99
Heavy Duty Onboard Air System 150 PSI compressor;5.0 gallon air tank;110/145 PSI pressure switch;175 PSI safety valve;1/4" NPT drain cock;1/4" NPT compression fitting;35'' tire inflator coil hose w/ carrying case;Remote mount intake filter;Mounting brackets & hardware Kleinn Train Horns Heavy Duty Onboard Air System 6450 Kleinn compressor kits
545.99
545.99
545.99
545.99
Kleinn Train Horns JK Dual Air Horn Kit JEEPKIT-1 Kleinn Complete Kits
451.99
451.99
JK Dual Air Horn Kit JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2011 2012 3.6L (220) 3.8L (231) GAS Kleinn Train Horns JK Dual Air Horn Kit JEEPKIT-1 Kleinn Complete Kits
451.99
451.99
JK Dual Air Horn Kit Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;20 PSI air system;Super-loud black dual air horn;Custom designed mounting brackets JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2011 2012 3.6L (220) 3.8L (231) GAS Kleinn Train Horns JK Dual Air Horn Kit JEEPKIT-1 Kleinn Complete Kits
451.99
451.99
JK Dual Air Horn Kit Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;20 PSI air system;Super-loud black dual air horn;Custom designed mounting brackets Kleinn Train Horns JK Dual Air Horn Kit JEEPKIT-1 Kleinn Complete Kits
Kleinn Train Horns Quad Air Horn 141 Kleinn Train Horns
92.99
92.99
Train Horn by Kleinn Automotive for Jeep Kleinn Train Horns Quad Air Horn 141 Kleinn Train Horns
Kleinn Train Horns Sealed 120 psi compressor w/ 0.5 gallon tank 6260 Kleinn compressor kits
182.99
182.99
Sealed 120 psi compressor w/ 0.5 gallon tank Sealed 120 psi compressor w/ 0.5 gallon tank;Kit includes: Compressor, Air Tank, Pressure Switch, Safety Valve, Compression Fitting, Drain Cock, Remote Mount Intake Filter, Mounting Brackets & Hardware;Compressor Dims (in): 7.5 L, X 2.1 W, X 4.3 H; Tank Dims (in): 6.5 L, X 5.75 W, X 8 H; Capacity: 0.5 Gallons;Max Pressure (psi): 120; Pressure Switch Settings (on/off): 90/120; Duty Rating: 9%;CFM @ 0 psi: 1.03; Amp Draw: 10;Thermal Protection: No; Weight: 9 lbs. Kleinn Train Horns Sealed 120 psi compressor w/ 0.5 gallon tank 6260 Kleinn compressor kits
182.99
182.99
182.99
182.99
Kleinn Train Horns Sealed 130 psi compressor w/ 1 gallon air tank 6270 Kleinn compressor kits
231.99
231.99
Sealed 130 psi compressor w/ 1 gallon air tank Sealed 130 psi compressor w/ 1 gallon tank;Kit includes: Compressor, Air Tank, Pressure Switch, Safety Valve, Compression Fitting, Drain Cock, Remote Mount Intake Filter, Mounting Brackets & Hardware;Compressor Dims (in): 6.25 L, X 3.3 W, X 4.9 H; Tank Dims (in): 10.75 L, X 5.75 W, X 8 H; Capacity: 1.0 Gallons;Max Pressure (psi): 130; Pressure Switch Settings (on/off): 100/130; Duty Rating: 15%;CFM @ 0 psi: 1.17; Amp Draw: 14;Thermal Protection: Yes; Weight: 11 lbs. Kleinn Train Horns Sealed 130 psi compressor w/ 1 gallon air tank 6270 Kleinn compressor kits
231.99
231.99
Kleinn Train Horns Single Roof Mount Truck Horn 411 Truck Horns
94.99
94.99
Single Roof Mount Truck Horn Single 25" trumpet;Perfect for manual or hand pull valves;Roof mount design eliminates exposed tube and wiring;Chrome plated spun copper trumpets;Manual valve and fitting packs sold separately Kleinn Train Horns Single Roof Mount Truck Horn 411 Truck Horns
94.99
94.99
94.99
94.99
Kleinn Train Horns Train Horn 130 Kleinn Train Horns
76.99
76.99
Mini chrome plated zinc alloy triple train horn Chrome plated zinc alloy;Max Input (psi): 160;Output (db) @ 100 psi: 148.7;Output (db) @ 150 psi: 152.9;Solenoid: Vortex 4 12-volt DC;Compressor and air tank needed to operate horns Kleinn Train Horns Train Horn 130 Kleinn Train Horns
76.99
76.99
Train Horn by Kleinn Automotive Chrome plated zinc alloy;Max Input (psi): 160;Output (db) @ 100 psi: 148.7;Output (db) @ 150 psi: 152.9;Solenoid: Vortex 4 12-volt DC;Compressor and air tank needed to operate horns Kleinn Train Horns Train Horn 130 Kleinn Train Horns
76.99
76.99
Kleinn Train Horns Train Horn 141 Kleinn Train Horns
92.99
92.99
Chrome plated zinc alloy quad train horn Chrome plated zinc alloy;Max Input (psi): 160;Output (db) @ 100 psi: 149.2;Output (db) @ 150 psi: 150.3;Solenoid: Vortex 4 12-volt DC;Compressor and air tank needed to operate horns Kleinn Train Horns Train Horn 141 Kleinn Train Horns
92.99
92.99
Train Horn by Kleinn Automotive Chrome plated zinc alloy;Max Input (psi): 160;Output (db) @ 100 psi: 149.2;Output (db) @ 150 psi: 150.3;Solenoid: Vortex 4 12-volt DC;Compressor and air tank needed to operate horns Kleinn Train Horns Train Horn 141 Kleinn Train Horns
Kleinn Train Horns Train Horn 230 Kleinn Train Horns
213.99
213.99
Train Horn by Kleinn Automotive The Beast - Triple horn;Black ABS;Detachable trumpets;Construction: High Impact ABS;Max Input (psi): 175;Output (db) @ 100 psi: 150.6;Output (db) @ 150 psi: 153.3;Solenoid: Vortex 4 12-volt DC;Compressor and air tank needed to operate horns Kleinn Train Horns Train Horn 230 Kleinn Train Horns
213.99
213.99
Kleinn Train Horns Train Horn 500 Kleinn Train Horns
180.99
180.99
Train Horn by Kleinn Automotive Chrome plated high impact ABS;Max Input (psi): 175;Output (db) @ 100 psi: 149;Output (db) @ 150 psi: 151.7;Solenoid: Vortex 4 12-volt DC;Compressor and air tank needed to operate horns Kleinn Train Horns Train Horn 500 Kleinn Train Horns
180.99
180.99
180.99
180.99
Page (4 of 5)
1 2 3 4 5 |
