Buy "klein tools" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
Klein Tools Large Compound-Action Crimp Tool - KLE2006
239.79
239.79
Crimps 6-4/0 awg lugs and terminalsAll-in-one, integral crimp nest- no removable parts or rotating dies!High leverage handles and compound-action mechanism for superior mechanical advantageUltra-comfortable hand grips for easy useAdjustment screw allows user to control crimp depth. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Klein Tools Long-Nose Multi-Purpose Tool - KLE1010
27.69
27.69
Easily cuts and strips wireNarrow, serrated plier nose to pull, loop and bend wireLong, curved cutting bladeCutters and strippers are in front of the pivot for maximum ease-of-use in reaching into tight placesCrimps insulated and non-insulated terminals and 7 to 8 mm ignition terminals Cleanly shears bolts. Plastic-covered cushioned handles for comfort. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Klein Tools Multi-Purpose Electrician's Tool - 8-22 AWG - KLE1001
31.99
31.99
Two wire cutters - one at tip, the other halfway back near stripping holes - double the utility of this toolCrimps 7-8mm insulated and non-insulated terminals, lugs and splicesCuts and strips 8-22 AWG solid and 10-26 AWG stranded wireCleanly shears boltsPivot nut adjusts tension Left and right hand wire looping holes near tip. Full-sized, plastic-covered cushioned handles for comfort. Wire cutter in nose and below pivot. Crimping dies color-coded for easy identification. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Klein Tools Multi-Purpose Tool - 10-22 AWG Solid - KLE1002
29.94
29.94
Crimps insulated and non insulated terminals, lugs and splicesCrimps 7mm ignition and distributor terminalsEasily cuts and strips wireCleanly shears boltsWire cutter in nose Plastic covered cushioned handles for comfort. 8-1/2" in length. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Klein Tools Wire Stripper-Cutter - Solid and Stranded Wire - KLE1011
15.19
15.19
Easily cuts and strips wireNarrow, serrated plier nose to pull, loop and bend wireLong, curved cutting bladeCutters and strippers are in front of the pivot for maximum ease-of-use in reaching into tight placesCrimps insulated and non-insulated terminals and 7 to 8 mm ignition terminals Cleanly shears bolts. Plastic-covered cushioned handles for comfort. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Page (2 of 2)
1 2 |
