Buy "ken tool" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
Ken Tool Ironman Ergonomic Wheel Lifting Bar - KEN34950
49.99
49.99
? ? Easily and safely lift heavy, awkward truck tire and wheel assemblies? Extremely useful in outdoor conditions - when truck tire and wheel assemblies can become wet and slippery? Specially designed forged ends work from either side of the wheel assembly as it lays flat ? Lift all sizes and types of small and large heavy truck wheels? Length: 58" nominal This lifting bar reduces back strain and injury when lifting truck tire and wheel assemblies. Use the leverage created by the tool - not your back! Standard sizes including 22.5" and 24.5" wheels plus European (which have 1" lug holes), super wide and even the super single (a 340 lb. assembly) size. Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool K55 5-1/2inch Professional Workshop Vise - KEN64055
193.99
193.99
360 degree swivel baseMachined base plate - smooth swivelGear type locking system with double lock down boltsHeavy duty jaw beam covers screw"V" notched replaceable/reversible jaws made of carbon steel - V notches for vertical gripping; built in pipe jaws High quality construction for extra durability and full strength performance at any jaw opening, this vise is made for the professional - strong, durable and built to last. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool K65 6-1/2inch Professional Workshop Vise - KEN64065
249.99
249.99
360 degree swivel baseMachined base plate - smooth swivelGear type locking system with double lock down boltsBuilt in anvil - with built in pipe jaws"V" notched replaceable/reversible jaws made of carbon steel - V notches for vertical gripping High quality construction for extra durability and full strength performance at any jaw opening, this vise is made for the professional - strong, durable and built to last. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool KT4650 6-1/2inch Professional Reversible Mechanic's Vise - KEN64650
279.99
279.99
360 degree swivel baseMachined base plate - smooth swivelGear type locking system with double lock down boltsTwo Built in anvils provide more work surface area than any other vise"V" notched replaceable/reversible jaws made of carbon steel - V notches for vertical gripping High quality construction for extra durability and full strength performance at any jaw opening, this vise is made for the professional - strong, durable and built to last.? Jaw opening: 7" - 10"; throat depth: 3-3/4"; pipe jaw capacity: 1/2" - 3".? Weight: 50 lbs. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool Metric Heavy-Duty Cap Nut Wrench - KEN30619
47.09
47.09
Heavy duty design will not slip out of positionWrench rests snugly against the center hole, reducing the possibility of rim damageIdeal for aluminum wheelsFits nut size: 41mmMade In U.S.A. Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool New Super HubShark System - KEN7326
628.99
628.99
Updated HubShark has greater capacity to handle larger bearingsKit now includes a 3/4" Center Screw to accommodate smaller import axlesNow includes a thrust bearing to reduce friction between the main screw and the body, allowing smoother bearing removal and installationPer your request, HubShark has been updated to meet your most challenging bearing requirementsMade in U.S.A. Per your request, HubShark has been updated to meet your most challenging bearing requirements? Replace front wheel bearings on front wheel drive vehicles without removing the steering knuckle from the vehicle - in about 20 minutes per wheel. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool Porkchop Cap Nut Wrench - KEN30609
19.99
19.99
Wrenches hold outer cap nut on dual wheels while turning inner nutLip fits in hole to secure wrench in placeSize: 1-1/2". Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool Professional Four-Way Lug Wrench - 23inch - KEN35657
56.69
56.69
America's premier professional lug wrenches for cars, light trucks, SUVs, RVs and vansDrop forged centers for extra strengthKeep wrenches in trunk for emergencies or everyday useSocket sizes: 3/4", 13/16", 7/8" and 15/16"Length: 23". Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Ken Tool Professional Wheel Cover Puller and Replacer - KEN31567
40.59
40.59
Removes wheel covers quickly and easily without gouging or scratching themRubber head T11RH prevents damage to hub cap and is replaceable17-1/2" in lengthStock: 9/16". Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool SAE Heavy-Duty Cap Nut Wrench - KEN30618
47.09
47.09
Heavy duty design will not slip out of positionWrench rests snugly against the center hole, reducing the possibility of rim damageIdeal for aluminum wheelsFits nut size: 1-1/2"Made In U.S.A. Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool Standard Wheel Cover and Replacer - KEN31568
30.29
30.29
Removes wheel covers quickly and easily without gouging or scratching themRubber head T11RH prevents damage to hub cap and is replaceable14" in lengthStock: 7/16". Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool T5 Small Handled Tire Iron - KEN32115
19.29
19.29
Ideal for demounting small tiresSturdy, comfortable plastic handleRounded end will not pinch tubeUse in psirsMade In USA Professional tire changing tool for small tires. Sturdy, comfortable plastic handle. Ideal for? demounting motorcycle, ATV, lawn tractor, golf cart, and small tires by hand. Rounded ends will not pinch tube. Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool T8 Small Handled Tire Iron - KEN32118
19.29
19.29
Ideal for mounting small tiresSturdy, comfortable plastic handlesRounded ends will not pinch tubeUse in pairsMade In USA Pro tire changing tools for small tires. Sturdy, comfortable plastic handle. Ideal for mounting motorcycle, ATV, lawn tractor, golf cart, and small tires by hand. Rounded ends will not pinch tube. Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Ken Tool Universal Master TPMS Sensor Hardware and Tool Service Set - KEN30000
358.99
358.99
Versatile 152 piece assortment (15 unique kits) covers over 55 different OEM sensor models and 90% of all vehicles? Hardware kits contain valve core and cap, mounting nut, gasket(s), washer(s)? Includes the new rubber snap in valve stem kits with sensor screws used by GM? Plus 50 extra valve cores / 50 extra valve caps and complete Application and Torque Guide? TPMS service tools include: 1/4" drive ratcheting torque wrench with 11mm and 12mm deep sockets for mounting nuts; torque driver for valve cores; torque driver and T-10/T-15 Torx bits for rubber snap-in valve stem self-tapping screws. Kit comes in a 3" x 9" x 16" portable poly case. Most Tire & Wheel Tools products are available for in-store pickup from Advance Auto Parts.
Page (2 of 2)
1 2 |
