Buy "jks manufacturing, inc." online - search for the best price - compare prices
Page (2 of 4)
1 2 3 4 |
JKS Front Adjustable Trackbar, 1-3.5" Lift
216.99
216.99
Special Notes: Install requires minor drilling Vehicles with Dana 30 front axle, aftermarket differential cover and less than 3" of lift may require bump stop adjustement to prevent interference with differential cover. JKS Front Adjustable Track Bar, 1-3.5" Lift Fits: 1997-2006 Jeep Wrangler TJ & Unlimited (Rubicon) - 1.0-3.5" Lift 1984-2001 Jeep Cherokee XJ - 1.0-3.5" Lift 1986-1992 Jeep Commanche MJ - 1.0-3.5" Lift 1993-1998 Jeep Grand Cherokee ZJ - 2.0-3.5" Lift. Product Information: Easily center your axle under your Jeep! One turn of the adjuster shifts the axle approximately 1/16 so you can fine tune your axle center very precisely. Made from 1-1/4 x 0.156 DOM tubing, this bar uses a greasable and rebuildable Johnny Joint at the frame end and a zinc plated adjuster using the factory OEM style rubber bushing on the axle end. Black powder coat finish. Product Details: With 1-3" of lift Properly aligns axle housing with chassis on coil sprung Jeeps Prevents undue stress on related components and centers swaybar for proper disconnect operation Ultra-strong, DOM tube construction features OE bends for correct geometry and clearance Zinc plated and powder coated for excellent protection from corrosion and debris
JKS Front Adjustable Trackbar, Over 4.0" Lift
216.99
216.99
Special Notes: Installation requires minor drilling JKS Front Adjustable Trackbar, Over 4.0" Lift Fits: 1997-2006 Jeep Wrangler TJ & Unlimited (Rubicon) - Over 4.0" Lift 1984-2001 Jeep Cherokee XJ- Over 4.0" Lift 1986-1992 Jeep Commanche MJ - Over 4.0" Lift 1993-1998 Jeep Grand Cherokee ZJ - Over 4.0" Lift Product Information: Easily center your axle under your Jeep! One turn of the adjuster shifts the axle approximately 1/16 so you can fine tune your axle center very precisely. Made from 1-1/4 x 0.156 DOM tubing, this bar uses a greasable and rebuildable Johnny Joint at the frame end and a zinc plated adjuster using the factory OEM style rubber bushing on the axle end. Black powder coat finish. Product Details: With 4" or more lift Properly aligns axle housing with chassis on coil sprung Jeeps Prevents undue stress on related components and centers swaybar for proper disconnect operation Ultra-strong, DOM tube construction features OE bends for correct geometry and clearance Zinc plated and powder coated for excellent protection from corrosion and debris
JKS Front Adjustable Upper Control Arm Kit, 0-6 Lift
337.99
337.99
Notes: Tightening The bolts with the vehicle raised may cause premature bushing wear due to preloading the bushings! JKS Front Adjustable Upper Control Arm Kit, 0-6 Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: These JKS Adjustable Control Arms are the heaviest duty units on the market today! With over 3 inches of adjustment, changing the length is as simple as removing one end of the arm and rotating it to the desired length. These arms also twist or rotate while driving to allow the axle to flex easily, and they use factory OEM bushings at both ends to reduce noise. The units are greasable, come pre-greased, and are sealed using a spring loaded crankshaft style seal. Black powdercoat and zinc plated. For use with any lift kit. Product Details: Sold in pairs. Front adjustable upper control arms. Lubricated threads and internal brass bearing for smooth operation and excellent longevity. Durable powdercoat finish and zinc plating provide excellent protection. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
JKS Front Adjustable Upper Control Arm Kit, 0-6" Lift
297.99
297.99
Notes: Tightening The bolts with the vehicle raised may cause premature bushing wear due to preloading the bushings! Compatible with Rubicon and Unlimited models JKS Front Adjustable Upper Control Arm Kit, 0-6" Lift Fits: 1997-2006 Jeep Wrangler TJ 1984-2001 Jeep Cherokee XJ 1999-2004 Jeep Grand Cherokee WJ 1986-1992 Comanche MJ 1993-1998 Grand Cherokee ZJ Product Information: These JKS Adjustable Control Arms are the heaviest duty units on the market today! With over 3 inches of adjustment, changing the length is as simple as removing one end of the arm and rotating it to the desired length. These arms also twist or rotate while driving to allow the axle to flex easily, and they use factory OEM bushings at both ends to reduce noise. The units are greasable, come pre-greased, and are sealed using a spring loaded crankshaft style seal. Black powder coat and zinc plated. For use with any lift kit. Sold in pairs. Product Details: Sold as a pair. Lubricated threads and internal brass bearing for smooth operation and excellent longevity. Spring-loaded, crankshaft type seal prevents moisture and debris contamination. Heavy duty construction is far stronger than the thin gauge stamped metal OE suspension arm. Threaded body utilizes superior 18 threads-per-inch. Durable powdercoat finish and zinc plating provide excellent protection.
JKS Front Bottom Bar Pin Eliminators
40.99
40.99
Special Notes: Compatible with Rubicon and Unlimited modelsNOTE: Not compatible with Old Man Emu shock absorbers. JKS Front Bottom Bar Pin Eliminators Fits: 1997-2006 Wrangler TJ 1984-2001 Cherokee XJ 1986-1992 Comanche MJ 1999-2004 Grand Cherokee WJ 1993-1998 Grand Cherokee ZJ Product Information: Bar Pin Eliminators utilize a cleverly constructed system of blocks and pins machined from premium grade, zinc plated steel. When installed, the blocks actually squeeze the bushing to create the recommended amount of crush specified by bushing manufacturers, thus providing the ideal environment for proper bushing operation. The smooth, machined surfaces of the Bar Pin Eliminator reduce friction at the bushing surface, unlike the porous and corrosion prone, substandard metals used for most bar pins. And unlike other designs on the market, JKS Bar Bin Eliminators mount to the vehicle in alignment with suspension movement, taking advantage of bushing rotation and reducing stress on the shock absorber and bushings. Protective zinc plating, corrosion resistance and JKS Bar Pin Eliminators prevent distortion of the shock absorber bushings by adding lateral compression, or preload. This ensures the bushings maintain their shape and deflect suspension impact forces to the shock absorbers, thus preventing the annoying noises and premature bushing failure common with standard bar pins. Product Details: Sold as a pair Converts front upper stud type shock mount to accept traditional EB1 hourglass type bushings. Provides necessary mounting type for extreme-travel aftermarket shock absorbers. Replaces original 3/8 threaded mounting stem with larger 7/8 bolt for greater strength and security. Relocates upper shock mount 1.10 lower for easy bolt access and additional droop.
JKS Front Mini Skid Kit
22.99
22.99
Special Notes: Not compatible with OE suspension arms (except for Wrangler JK) Compatible with Wranger TJ Rubicon and Unlimited models. JKS Front Mini Skid Kit Fits: 2007-2013 Jeep Wrangler JK 1997-2006 Jeep Wrangler TJ 1984-2001 Jeep Cherokee XJ 1986-1992 Jeep Comanche MJ 1993-1998 Grand Cherokee ZJ Product Information: JKS MiniSkids are essentially miniature skid plates for the lower suspension arm brackets on the front axle. The clever design spans the front of each bracket to create a boxed structure for increased strength and integrity. When properly welded to the axel and OE brackets, our MiniSkids prevent damage and deformation, and provide much-needed protection of the caster adjustment bolts and suspension arm bushings. Product Details: Laser cut from 1/4" steel Folded for increased rigidity Prevent damage and deformation of lower control arm bracketsSold as a pair Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
JKS Front or Rear Shackle Kit
99.99
99.99
Special Notes: Installation on Wagoneer SJ models require minor product modification. JKS Rear Shackle Kit Fits: 1984-2001 Jeep Cherokee XJ (Rear - 1" Lift) 1986-1992 Jeep Comanche MJ (Rear - no change in lift) 1973-1991 Jeep Wagoneer SJ (Front - 1.5" Lift) Product Information: Our XJ Shackle is specifically designed to optimize rear suspension travel on Jeep Cherokees. The extended length and boomerang design allows full compression and extension of the leaf springs, in addition to increasing rear ride height by approximately 1". Product Details: Durable powdercoat finish provides long-lasting protection. Prevents binding and bushing fatigue commonly associated with OE and inferior shackle designs. Increases rear ride height for improved tire clearance.
JKS Front Swaybar Quick Disconnect System, 0-2.0 Lift
108.99
108.99
JKS Front Swaybar Quick Disconnect System, 0-2.0 Lift Fits: 1976-1986 CJ5, CJ7 and CJ8 Product Information: Disconnecting your sway bar with a stock suspension allows 3-5 of greater wheel travel! Simply pull the lynch pin and swing the sway bar out of the way, and you're ready for the off-road. The Quick Disconnects are machined from 7/8 solid stock and include grade 5 lynch pins and polyurethane bushings. Gloss black powder coat. Made in the USA! Product Details: For Jeeps with 0-2.0 Lift. Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Costs far less than lockers, tires, lift kits, and other accessories with comparable performance benefits. Heavy gauge steel construction ensure unsurpassed strength and quality. Durable powdercoat finish and stainless steel lynch pins provide excellent corrosion resistance.
JKS Front Swaybar Quick Disconnect System, 0-2.5 Lift
108.99
108.99
JKS Front Swaybar Quick Disconnect System, 0-2.5 Lift Fits: 1987-1995 Jeep Wrangler YJ (Rubicon) Product Overview: Disconnecting your sway bar with a stock suspension allows 3-5 of greater wheel travel! Simply pull the lynch pin and swing the sway bar out of the way, and you're ready for the off-road. The Quick Disconnects are machined from 7/8 solid stock and include grade 5 lynch pins and polyurethane bushings. Gloss black powder coat. Made in the USA! Product Details: For Jeeps with 0-2.5 Lift. Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Costs far less than lockers, tires, lift kits, and other accessories with comparable performance benefits. Heavy gauge steel construction ensure unsurpassed strength and quality. Durable powdercoat finish and stainless steel lynch pins provide excellent corrosion resistance.
JKS Front Swaybar Quick Disconnect System, 2.5-6 Lift
108.99
108.99
JKS Front Swaybar Quick Disconnect System, 2.5-6 Lift Fits: 1987-1995 Jeep Wrangler YJ (Rubicon) Product Information: Disconnecting your sway bar with a stock suspension allows 3-5 of greater wheel travel! Simply pull the lynch pin and swing the sway bar out of the way, and you're ready for the off-road. The Quick Disconnects are machined from 7/8 solid stock and include grade 5 lynch pins and polyurethane bushings. Gloss black powder coat. Made in the USA! Fits noted YJs with 2-1/2 to 6 suspension lift. Product Details: For Jeeps with 2.5-6 Lift. Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Costs far less than lockers, tires, lift kits, and other accessories with comparable performance benefits. Heavy gauge steel construction ensure unsurpassed strength and quality. Durable powdercoat finish and stainless steel lynch pins provide excellent corrosion resistance.
JKS Front Swaybar Quick Disconnect System, 2.5-6.0 Lift
108.99
108.99
JKS Front Swaybar Quick Disconnect System, 2.5-6.0 Lift Fits: 1976-1986 Jeep CJ5, CJ7, CJ8 Scrambler Product Information: Disconnecting your sway bar with a stock suspension allows 3-5 of greater wheel travel! Simply pull the lynch pin and swing the sway bar out of the way, and you're ready for the off-road. The Quick Disconnects are machined from 7/8 solid stock and include grade 5 lynch pins and polyurethane bushings. Gloss black powder coat. Made in the USA! Product Details: For Jeeps with 2.5-6.0 Lift. Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Costs far less than lockers, tires, lift kits, and other accessories with comparable performance benefits. Heavy gauge steel construction ensure unsurpassed strength and quality. Durable powdercoat finish and stainless steel lynch pins provide excellent corrosion resistance.
JKS Front Swaybar Quicker Disconnect System
157.99
157.99
Special Notes: Requires welding bottom tab to axle tube for lower disconnect to mount. JKS Front Swaybar Quicker Disconnect System Fits: 1987-1995 Wrangler YJ 1976-1986 Jeep CJ5, CJ7, CJ8 Scrambler Product Information: To disconnect the Quicker Disconnects, simply remove the click pin and slide the bottom floating bushing off the axle mounted stainless steel pin. These disconnects are also length adjustable to accommodate different sized lifts or unleveled Jeeps. A single grease zerk fitting greases both bushings at the same time. Gloss black powder coat. Made in the USA. Product Details: Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Greasable QuadZerk design allows each bushing to receive lubrication independently. Heavy gauge steel construction ensures unsurpassed strength and quality. JKS exclusive Dura-Thane fluted bushings distribute grease evenly.
JKS Front Swaybar Quicker Disconnect System, 0-1.5" Lift
157.99
157.99
Special Notes: Requires welding bottom tab to axle tube for lower disconnect to mount. JKS Front Swaybar Quicker Disconnect System, 0-1.5" Lift Fits: 1984-2001 Jeep Cherokee XJ 1993-1998 Jeep Grand Cherokee ZJ Product Information: To disconnect the Quicker Disconnects, simply remove the click pin and slide the bottom floating bushing off the axle mounted stainless steel pin. These disconnects are also length adjustable to accommodate different sized lifts or unleveled Jeeps. A single grease zerk fitting greases both bushings at the same time. Gloss black powdercoat. Made in the USA. Product Details: Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Greasable QuadZerk design allows each bushing to receive lubrication independently. Heavy gauge steel construction ensures unsurpassed strength and quality. JKS exclusive Dura-Thane fluted bushings distribute grease evenly.
JKS Front Swaybar Quicker Disconnect System, 0-2 Lift
157.99
157.99
JKS Front Swaybar Quicker Disconnect System, 0-2 Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: To disconnect the Quicker Disconnects, simply remove the click pin and slide the bottom floating bushing off the axle mounted stainless steel pin. These disconnects are also length adjustable to accommodate different sized lifts or unleveled Jeeps. A single grease zerk fitting greases both bushings at the same time. Gloss black powdercoat. Made in the USA. Product Details: Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Greasable QuadZerk design allows each bushing to receive lubrication independently Heavy gauge steel construction ensures unsurpassed strength and quality JKS exclusive Dura-Thane fluted bushings distribute grease evenly Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
JKS Front Swaybar Quicker Disconnect System, 0-3.5 Lift
157.99
157.99
JKS Front Swaybar Quicker Disconnect System, 0-3.5 Lift Fits: 1999-2004 Jeep Grand Cherokee WJ Product Information: JKS has revolutionized the Quick Disconnect System again! These Quicker Disconnects are length adjustable so you can now adjust the length of each drop link to accommodate different size lifts and/or unleveled Jeeps. To disconnect them, simply remove the click pin and slide the bottom floating bushing off the axle mounted stainless steel pin. A single grease zerk fitting greases both bushings at the same time. Gloss black powder coated finish over zinc plating and robotically MIG welded for superior strength and quality. Product Details: For Jeeps with 0-3.5 lift. Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Greasable QuadZerk design allows each bushing to receive lubrication independently. Heavy gauge steel construction ensures unsurpassed strength and quality. JKS exclusive Dura-Thane fluted bushings distribute grease evenly. Zinc plated and powder coated for protection against.
JKS Front Swaybar Quicker Disconnect System, 2.5-6 Lift
157.99
157.99
JKS Front Swaybar Quicker Disconnect System, 2.5-6 Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: To disconnect the Quicker Disconnects, simply remove the click pin and slide the bottom floating bushing off the axle mounted stainless steel pin. These disconnects are also length adjustable to accommodate different sized lifts or unleveled Jeeps. A single grease zerk fitting greases both bushings at the same time. Gloss black powdercoat. Made in the USA. Product Details: Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Greasable QuadZerk design allows each bushing to receive lubrication independentlyHeavy gauge steel construction ensures unsurpassed strength and quality JKS exclusive Dura-Thane fluted bushings distribute grease evenly Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
JKS Front Swaybar Quicker Disconnect System, 4-6 Lift
157.99
157.99
JKS Front Swaybar Quicker Disconnect System, 4-6 Lift. Fits: 1999-2004 Jeep Grand Cherokee WJ Product Information: JKS has revolutionized the Quick Disconnect System again! These Quicker Disconnects are length adjustable so you can now adjust the length of each drop link to accommodate different size lifts and/or unleveled jeeps. To disconnect them, simply remove the click pin and slide the bottom floating bushing off the axle mounted stainless steel pin. A single grease zerk fitting greases both bushings at the same time. Gloss black powder coated finish over zinc plating and robotically MIG welded for superior strength and quality. Product Details: For Jeeps with 4-6 lift. Dramatically increases suspension travel and improves off-road performance on stock or modified Jeeps. Greasable QuadZerk design allows each bushing to receive lubrication independently. Heavy gauge steel construction ensures unsurpassed strength and quality. JKS exclusive Dura-Thane fluted bushings distribute grease evenly. Zinc plated and powder coated for protection against.
JKS Front Trackbar Skid-Brace & Relocate Bracket Kit, 3+ Lift
126.99
126.99
JKS Front Trackbar Skid-Brace & Relocation Bracket Kit, 3+ Lift Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: In spite of all its improvements over previous models, the 2007+ Jeep Wrangler JK is not entirely without fault. One particularly troublesome problem involves inadequate bracing of the factory track bar brackets. A startling number of vehicles have been disabled on the trail when the factory track bar bracket separated from the axle housing without notice. Vehicle owners have reported this problem on both axle housings, and although it occurs more commonly on modified applications, it can also affect stock vehicles.To eliminate this threat, JKS Manufacturing has developed the Front Trackbar Brace. This ingenious product reinforces the factory bracket and ensures your track bar mount will never fail. It welds directly to the original bracket and axle housing at multiple points, providing an extremely strong and permanent solution. As a side benefit, the Front Trackbar Brace relocates the steering damper to a more effective position that improves clearance and protects the damper from impact off-road. A secondary mounting location for the track bar is also provided to accommodate high-clearance steering conversions. When combined with the JKS Rear Trackbar Brace, Wrangler JK owners can take comfort in knowing that both track bar mounts are solid, safe and secure. Of course, these products should always be installed before damage occurs to the factory brackets. Waiting for failure to occur is far more difficult and expensive to repair, not to mention dangerous if you're miles from home. Product Details: Weld on installation 3 inch or higher lifts Reinforces factory unit Offers secondary trackbar mounting point. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
JKS Front Upper Shock Mount Conversion Kit
45.99
45.99
JKS Front Upper Shock Mount Conversion Kit Fits: 1987-1995 YJ Wrangler 1984-2001 XJ Cherokee 1986-1992 MJ Comanche Product Information: JKS Shock Conversions provide a smart solution to the problem many Jeep owners face when shopping for front shock absorbers that utilize the OE upper stud mount. By converting the factory upper shock mounts to accept common eye ring or hourglass style bushings, the selection of compatible shock absorbers greatly increases. JKS Shock Conversion bolts to the original shock mount using a massive 7/8 threaded stud and locking nut for an extremely secure fit. It also relocates the upper shock mount 1.10 lower in the wheel opening with a much stronger double-shear mounting configuration. A traditional 1/2 shock mounting bolt is used to accommodate any EB1 type bushing with 5/8 OD sleeve and allows easy access for convenient removal and installation. Product Details: Sold as a pair. Converts front upper stud type shock mount to accept traditional EB1 hourglass type bushings. Provides necessary mounting type for extreme-travel aftermarket shock absorbers. Replaces original 3/8 threaded mounting stem with larger 7/8 bolt for greater strength and security. Relocates upper shock mount 1.10 lower for easy bolt access and additional droop. Protective zinc plating, corrosion resistance and long lasting protection.
45.99
45.99
Special Notes: Compatible with TJ Rubicon and Unlimited models. JKS Front Upper Shock Mount Conversion Kit Fits: 1997-2006 Jeep Wrangler TJ 2007-2013 Jeep Wrangler JK 1993-2004 Grand Cherokee ZJ / WJ Product Information: JKS Shock Conversions provide a smart solution to the problem many Jeep owners face when shopping for front shock absorbers that utilize the OE upper stud mount. By converting the factory upper shock mounts to accept common eye ring or hourglass style bushings, the selection of compatible shock absorbers greatly increases. JKS Shock Conversion bolts to the original shock mount using a massive 7/8 threaded stud and locking nut for an extremely secure fit. It also relocates the upper shock mount 1.10 lower in the wheel opening with a much stronger double-shear mounting configuration. A traditional 1/2 shock mounting bolt is used to accommodate any EB1 type bushing with 5/8 OD sleeve and allows easy access for convenient removal and installation. Product Details: Converts front upper stud type shock mount to accept traditional EB1 hourglass type bushings. Provides necessary mounting type for extreme-travel aftermarket shock absorbers. Replaces original 3/8 threaded mounting stem with larger 7/8 bolt for greater strength and security. Relocates upper shock mount 1.10 lower for easy bolt access and additional droop. Protective zinc plating, corrosion resistance and long lasting protection. Sold as a pair. Jeep Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012 and 2013
JKS HD Extended Brake Lines Front, 4-6" Lift
117.99
117.99
Special Notes: For installation on vehicles with lower ride height, refer to installation instructions. For CJ5, CJ7 and CJ8 this is compatible with 3/8" brake hose bolt at caliper only - will not fit 7/16" bolt. Please measure before ordering. JKS HD Extended Brake Lines Front, 4-6" Lift Fits: 1987-95 Jeep Wrangler YJ 1982-86 CJ5, CJ7 and CJ8 Product Information: JKS now offers Jeep owners a solution to their vehicles' most vulnerable brake system component. HD Extended Brake Lines are direct replacements for the factory rubber brake hoses, and designed to exceed the demands of extreme Jeep applications. The heavy duty, 22" hoses virtually eliminate volumetric expansion to provide immediate brake pedal response and improved performance regardless of fluid pressure or temperature. Product Details: 4-6" of lift Front two lines only Kevlar and stainless steel raided construction Complies with federal D.O.T. regulations and is legal for all street and com
JKS HD Front Extended Brake Lines 22", 4-6" Lift
117.99
117.99
Special Notes: For installation on vehicles with lower ride height, refer to installation instructions. JKS HD Front Extended Brake Lines 22", 4-6" Lift Fits: 1997-2006 Jeep Wrangler TJ Unlimited (Rubicon) 1984-2001 Jeep Cherokee XJ 1986-1992 Jeep Comanche MJ 1993-1998 Jeep Grand Cherokee ZJ Product Information: Complies with federal D.O.T. regulations and is legal for all street and competition applicationsJKS now offers Jeep owners a solution to their vehicles' most vulnerable brake system component. HD Extended Brake Lines are direct replacements for the factory rubber brake hoses, and designed to exceed the demands of extreme Jeep applications. The heavy duty, 22" hoses virtually eliminate volumetric expansion to provide immediate brake pedal response and improved performance regardless of fluid pressure or temperature. Product Details: 4-6" of lift 22" Heavy Duty Hoses Front two lines only Kevlar and stainless steel braided construction
JKS Heavy Duty Steering Drag Link
121.99
121.99
JKS Heavy Duty Steering Drag Link 1999-2004 Jeep Grand Cherokee WJ Product Information: JKS introduced the HD Tie Rod as a heavy duty replacement for the inferior OE part. Constructed of incredibly strong DOM seamless tubing, the JKS HD Tie Rod is 1.25" in diameter with a 0.375" wall thickness. Each end is correctly threaded to accept the OE tie rod ends for a perfect fit and easy adjustability. Unlike the OE part, our HD Tie Rod is strong enough to withstand minor impacts on the trail. In addition, the rigid construction provides greater sensitivity to the driver for improved feel and control through the steering wheel. Supplied with right-hand and left-hand jam nuts and powdercoated black. Features: Heavy duty construction resists impacts and bending much better than OE tie rod Easy, bolt-on replacement for one of the most frequently damaged factory components Incredibly strong 1.25" x 0.375" seamless tubing for excellent durability Provides improved steering sensitivity and feedback to driver Properly threaded to accept OE tie rod ends for convenient installation Years Covered: 1999, 2000, 2001, 2002, 2003 and 2004
JKS Heavy Duty Tie Rod Kit
162.99
162.99
Special Notes: XJ Cherokee models require tie rod ends from 1992-01 models Comanchee MJ models require tie rod ends from 1992-01 Cherokee XJ JKS Heavy Duty Tie Rod Kit Fits: 1997-2006 Jeep Wrangler TJ Unlimited (Rubicon) 1984-2001 Jeep Cherokee XJ 1993-1998 Jeep Grand Cherokee ZJ 1986-1992 MJ Comanche Product Information: Unlike the OE part, our HD Tie Rod is strong enough to withstand minor impacts on the trail. In addition, the rigid construction provides greater sensitivity to the driver for improved feel and control through the steering wheel. Supplied with right-hand and left-hand jam nuts and powdercoated black. Product Details: Requires tie rod ends from 1992-01 Cherokee XJ. Bolt-on replacement for one of the most frequently damaged factory components. Incredibly strong 1.25" x 0.375" Seamless tubing for excellent durability. Properly threaded to accept OE tie rod ends for convenient installation.
JKS Heavy-Duty Tie Rod Kit
184.99
184.99
JKS Heavy-Duty Tie Rod Kit Fits: 1999-2004 Jeep Grand Cherokee WJ Product Information: Unlike the OE part, our HD Tie Rod is strong enough to withstand minor impacts on the trail. In addition, the rigid construction provides greater sensitivity to the driver for improved feel and control through the steering wheel. Supplied with right-hand and left-hand jam nuts and powdercoated black. Product Details: Easy, bolt-on replacement for one of the most frequently damaged factory components. Incredibly strong 1.25" x 0.375" seamless tubing for excellent durability. Properly threaded to accept OE tie rod ends for convenient installation.
Page (2 of 4)
1 2 3 4 |
