Buy "iwata" online - search for the best price - compare prices
Page (2 of 4)
1 2 3 4 |
Iwata LPH400-134LVX eXtreme Basecoat Spray Gun - IWA5660
586.89
586.89
LV technology for a 11.8 inch tulip pattern thus more material in pattern and less oversprayApplicable in solvent or waterborne productsLVX air cap designed for all midrange colors where productivity and speed are a mustAllows for no technique changeLow air consumption The LVX eXtreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is shipped with the gun only. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-134LVX eXtreme Basecoat Spray Gun with 1000ml Cup - IWA5663
653.89
653.89
LV Technology for less overspray and fine atomizationApplicable in solvent and waterborne productsLVX air cap for all mid range colors where productivity and speed are a mustNo technique change requiredLow air consumption The LVX eXtreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is shipped with the gun and 1000ml cup and has a 1.3 nozzle size. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-134LVX eXtreme Basecoat Spray Gun with 700 ml Cup - IWA5662
653.89
653.89
LV technology for a 11.8 inch tulip pattern thus more material in pattern and less oversprayApplicable in solvent or waterborne productsLow air consumptionSuperior atomizationCenter post gravity HVLP spray gun The LVX extreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is shipped with 700ml cup. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-144LV Center Post Gravity Feed HVLP Spray Gun - IWA5550
600.99
600.99
LV Technology for fine atomization and less oversprayLow air consumption, operates on 9.5 CFMSuperior atomizationApplicable in solvent or waterborne productsDesigned for Base and Clear coat, single stage products LPH400 high performance center post, gravity fed HVLP spray gun comes with 1.4 nozzle size. This spray gun comes with Iwata's patented LV technology providing fine atomization, less overspray and thus is environmentally friendly. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-144LV Center Post Gravity Feed HVLP Spray Gun with 700ml Aluminum Cup - IWA5552
653.89
653.89
Iwata LPH400-144LV W/ 1000ML CUP - IWA5553
653.89
653.89
Iwata LPH400-144LVX eXtreme Basecoat Spray Gun - IWA5670
586.89
586.89
LV Technology for less overspray and fine atomizationLVX cap designed for 95% of mid range colors where productivity and speed are a mustLow air consumptionApplicable in solvent or waterborne productsUltra smooth application with no technique change The LVX extreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is shipped with the gun only and has a 1.4 nozzle size. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-144LVX eXtreme Basecoat Spray Gun with 1000ml Cup - IWA5673
653.89
653.89
LV Technology for less overspray and fine atomizationLVX air cap designed for 95% of all base coats where productivity and speed are a mustApplicable in clear coat, solvent and waterborne productsLow air consumption, operates on 9.5 CFMUltra smooth application with no technique change The LVX extreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is shipped with the gun and 1000ml cup and has a 1.4 nozzle size. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-144LVX eXtreme Basecoat Spray Gun with 700ml Cup - IWA5672
653.89
653.89
LV technology for less overspray and fine atomizationLVX cap designed for 95% of mid range base coats where productivity and speed are a mustApplicable in clear coat, all solvent and waterborne productsLow air consumption, operates on 9.5 CFMUltra smooth application with no technique change The LVX eXtreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is shipped with the gun and 700ml cup and has a 1.4 nozzle size. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-154LV Center Post Gravity Feed HVLP Spray Gun with 1000ml Cup - IWA5538
653.89
653.89
LV Technology for fine atomization and less oversprayLow air consumption, operates on 9.5 CFMSuperior atomizationApplicable in solvent or waterborne productsDesigned for Base and Clear coat, single stage products LPH400 high performance center post, gravity fed HVLP spray gun comes with 1.5 nozzle size and 1000ml cup. This spray gun comes with Iwata's patented LV technology providing fine atomization, less overspray and thus is environmentally friendly. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-154LV Center Post Gravity Feed HVLP Spray Gun with 700ml Cup - IWA5537
677.79
677.79
LV Technology for fine atomization and less oversprayLow air consumption, operates on 9.5 CFMSuperior atomizationApplicable in solvent or waterborne productsDesigned for Base and Clear coat, single stage products LPH400 high performance center post, gravity fed HVLP spray gun comes with 1.5 nozzle size and 7000ml cup. This spray gun comes with Iwata's patented LV technology providing fine atomization, less overspray and thus is environmentally friendly. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400-LVX-154LV eXtreme Basecoat Spray Gun - IWA5680
600.99
600.99
LV Technology for less overspray and fine atomizationLVX air cap designed for 95% of all base coats where productivity and speed are a mustApplicable in clear coat, solvent and waterborne productsLow air consumption, operates on 9.5 CFMUltra smooth application with no technique change The LVX extreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is the gun only and has a 1.5 nozzle size. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH400LVX-154LV eXtreme Basecoat Spray Gun with 700ml Cup - IWA5682
677.79
677.79
LV Technology for less overspray and fine atomizationLVX air cap designed for 95% of all base coats where productivity and speed are a mustApplicable in clear coat, solvent and waterborne productsLow air consumption, operates on 9.5 CFMUltra smooth application with no technique change The LVX eXtreme basecoat technology was developed for use with 90-95% of basecoat colors and engineered to provide increased productivity in application with solvent or waterborne basecoats. The LPH400-LVX is much faster than the competition and has an ultra smooth application with no technique change. This model is the gun only and has a 1.5 nozzle size. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH440-161 HVLP Primer Spray Gun - IWA5725
339.49
339.49
Sharp edged pattern reduces over spray and minimizes maskingFine atomization creates an even film and saves sanding timeNozzle size: 1.6mmPattern width: 10.2"Soft atomization reduces overspray LPH440 gun designed specifically for spraying primers, sealers, and fillers. The LPH440 creates a sharp edged spray pattern designed for optimal overlap. This combined with the LPH440's fine soft atomization helps to reduce over spray and increase working speed. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH440-161 Spray Gun with 700ml Cup - IWA5727
410.09
410.09
Sharp edged spray pattern reduces oversprayMinimizes maskingFine atomization creates a even film and save sanding timeApplicable for all primers and sealersCenter post gravity fed spray gun The LPH440 is an HVLP primer spray gun is designed specifically for primers, sealers, and fillers. The LPH440 creates a sharp edge spray pattern designed for optimal overlap. This combined with the LPH440's fine soft atomization helps to reduce overspray and increase working speed. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH440-181 Primer Gravity Feed HVLP Spray Gun - IWA5730
339.49
339.49
Designed specifically for spraying primers, sealers and fillersThe sharp edged spray pattern creates optimal overlap increasing working speedFine atomization helps to minimize over spray, reduce sanding time and increase working speed1.8mm fluid tip. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH440-181 Primer Spray Gun with 700ml Cup - IWA5732
400.39
400.39
Designed specifically for primers, sealers, and fillersCreates a sharp edge spray pattern to reduce oversprayMinimizes maskingFine atomization creates an even film and saves sanding timeCenter post gravity fed spray gun This model comes with a nozzle size of 1.8 and a 700ml cup. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH440-251 Primer Gravity Feed HVLP Spary Gun with 700ml Cup - IWA5742
410.09
410.09
Designed specifically for spraying primers, sealers and fillersThe sharp edged spray pattern creates optimal overlap increasing working speedFine atomization helps to minimize over spray, reduce sanding time and increase working speed2.5mm fluid tip. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH50-102G HVLP Spray Gun with Side Mounted 130 ml Cup - IWA5276
439.39
439.39
Miniature spray gun adaptable to small touch up work or custom paintingSpray pattern can open to 3.9 inchesSide mounted cup for easy viewing of targetLow air consumption, operates on 1.8 CFMSuperior atomization The LPH50 is a high performance miniature HVLP spray gun with side mounted cup. This gun offers superior atomization with low air consumption for small touch up work and custom painting. This gun can also adapt to a side mounted airbrush bottle for custom work. Miniature high performance gravity feed (HVLP) spray gun provides ideal spray control when blending or shading. The compact lightweight gun is designed with side mounted gravity cup allowing 360? rotation giving the operator options to spray at a wide variety of angles. Featuring adjustable spray pattern from round to full-fan shape while producing spray patterns from 1/8" up to 4".". Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH80-082G GUN/ - IWA4911
442.79
442.79
Comes with AK-1B regulatorLV technology for more material in pattern and less oversprayApplicable in solvent and waterborne productsSuperior atomizationCenter post, gravity fed This gun kit comes with a 1000ml cup and also the AK-1B "swing and swivel" regulator. This regulator is designed to make handling bulky air hoses easy has it swings with the air hose rather than fighting it. The gun comes with 1.4 nozzle. The "LV" technology will produce a "tulip" pattern with fine atomization and less overspray thus being environmentally friendly. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH80-104G GUN - IWA4925
390.09
390.09
Iwata LPH80-104G HVLP Mini Spray Gun with 150 ml Cup - IWA4926
442.79
442.79
Miniature center post spray gunBoth round and fan spray patternLow air consumption at 1.8 cfmTwo different air caps availableUp to 5.5" fan pattern HVLP miniature center post spray gun. It's spray patterns range from 1.6" round pattern to a full 5.5" fan pattern, which makes it ideal for large backgrounds, spot repair, blending, shading and touch up. Low operating air pressure and low 1.8 CFM allow the LPH80 to run with small air compressors, perfect for mobile repair. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LPH80-124G GUN - IWA4930
390.09
390.09
Iwata LPH80-124G Spray Gun with 150ml Cup - IWA4931
442.79
442.79
New E4 air cap for a finer, wider, and flat patternOperates on 1.8 CFMPattern range from 1.6 inch round to 5.5 inch fan patternApplicable for solvent and waterborne productsCenter post, miniature gravity fed spray gun The LPH80 HVLP spray gun is designed for a variety of situations. The pattern ranges from 1.6in round to a full 5.5 inch fan pattern. The LPH 80 is ideal for large backgrounds, spot repair, blending and touch up. This modes features the new E4 air cap and creates a finer, wider, and flat pattern. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata LS400-1301 SUPER NOVA - Gun Only - IWA5800
685.59
685.59
Superior atomization control for basecoat applicationsProduction speed and ergonomically advancedConsistent droplet size when atomizingPerfect balance regardless of cup sizeErgonomic grip All SUPERNOVA guns are equipped with stainless fluid passages ideal for any type of material, solvent or waterborne. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Page (2 of 4)
1 2 3 4 |
