Buy "iwata" online - search for the best price - compare prices
Page (3 of 4)
1 2 3 4 |
Iwata LS400-1302 Spray Gun Only with 1.3 Nozzle - IWA5810
685.59
685.59
Superior atomization control for clearcoat applicationProduction speed and ergonomically advancedConsistent droplet size when atomizingPerfect balance regardless of cup sizeErgonomic grip All Super Nova guns are equipped with stainless steel fluid passages ideal for any type of material, solvent or waterborne. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Iwata LS400-1302 Spray Gun with 1000ML Cup and 1.3 Nozzle - IWA5813
751.29
751.29
Superior atomization controlProduction speed and ergonomically advancedConsistent droplet size when atomizingPerfect balance regardless of cup sizeErgonomic grip All Super Nova guns are equipped with stainless steel fluid passages ideal for any type of material, solvent or waterborne. For clearcoat/general purpose applications. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Iwata LS400-1302 Spray Gun with 700ML and 1.3 Nozzle - IWA5812
751.29
751.29
Iwata LS400-1302 Spray Gun With 700ML Cup - IWA5802
751.29
751.29
Superior atomization control for basecoat applicationsProduction speed and ergonomically advancedConsistent droplet size when atomizingPerfect balance regardless of cup sizeErgonomic grip All SUPERNOVA guns are equipped with stainless fluid passages ideal for any type of material, solvent or waterborne. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Iwata LS400-1401 Spray Gun with 1000ML Cup and 1.4 Nozzle - IWA5808
769.19
769.19
Iwata LS400-1401 Spray Gun with 700ML Cup and 1.4 Nozzle - IWA5807
769.19
769.19
Iwata LS400-1402 Spray Gun Only with 1.4 Nozzle - IWA5815
701.89
701.89
Superior atomization controlProduction speed and ergonomically advancedConsistent droplet size when atomizingPerfect balance regardless of cup sizeErgonomic grip All Super Nova guns are equipped with stainless steel fluid passages ideal for any type of material, solvent or waterborne. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Iwata LS400-1402 Spray Gun with 1000ML Cup and 1.3 Nozzle - IWA5818
760.19
760.19
Iwata LS400-1402 Spray Gun with 700ML Cup and 1.4 Nozzle - IWA5817
769.19
769.19
Iwata W101-102P 1.0mm Compact Pressure Feed Gun - IWA4403B
276.89
276.89
8.7" pattern widthHigh transfer efficiencyWorks well with medium to high viscosity enamels9.5 cfm, 35 psiCompact size The NEW W101-P pressure feed air-spray gun improves on the reliable reputation of the W100-P. The improved air cap design with increased pattern shape stability improves atomization and decreases mottling and blotching. The ergonomic gun body design combined with lighter weight helps to reduce painter fatigue. The new design also includes changing the fluid inlet from 1/4" to 3/8" common thread for seamless transition. Application: automotive, wood working, metal, plastic. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W101-132P 1.3mm Compact Pressure Feed Gun - IWA4405B
276.89
276.89
8.3" pattern widthHigh transfer efficiencyWorks well with medium to high viscosity enamels7.8 cfm, 35 psiCompact size The NEW W101-P pressure feed air-spray gun improves on the reliable reputation of the W100-P. The improved air cap design with increased pattern shape stability improves atomization and decreases mottling and blotching. The ergonomic gun body design combined with lighter weight helps to reduce painter fatigue. The new design also includes changing the fluid inlet from 1/4" to 3/8" common thread for seamless transition. Application: wood working, metal, medium viscosity. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W101-152P 1.5mm Compact Pressure Feed Gun - IWA4407B
269.89
269.89
Iwata W400-132G with 700ml cup - IWA4727T
539.59
539.59
High transfer efficiencySuperior atomizationTraditional spray patternApplicable in base coat, clear coat and single stageCenter post gravity fed This gun comes with a 1.4 nozzle and a 700ml cup. The W400 will produce a more traditional spray pattern with a conventional needle / nozzle. The gun will give high transfer efficiency control and superior atomization. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W400-142G GUN O - IWA4705
477.59
477.59
Lightweight full size pressure feed air spray gun with high transfer efficiency control and superior atomization19.8 cfm15.7" pattern width42 PSI. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W400-142G Spray Gun with 700 ml Cup - IWA4707T
539.59
539.59
Iwata W400LV-124G COM - IWA4830
600.99
600.99
LV technology for more material in pattern and less oversprayApplicable in solvent and waterborneSuperior AtomizationCompliant to HVLP standardsCenter post, gravity fed This gun comes with a 1.4 nozzle size. The W400 center post, gravity fed spray gun combines LV technology with high-TEC standard to give you high transfer efficiency control and superior atomization. The LV technology will produce a "tulip" pattern with fine atomization and less overspray. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W400LV-124G COM - IWA4832
677.79
677.79
Iwata W400LV-124G GUN - IWA4750
544.99
544.99
Iwata W400LV-124G GUN - IWA4751
609.29
609.29
Iwata W400LV-124G GUN - IWA4752
615.69
615.69
Iwata W400LV-134G Compliant Spray Gun with 1000ml Cup - IWA4758
592.99
592.99
LV technology for less overspray and more material in patternLess material use than competitors gunsLow air consumptionSuperior atomizationExcellent in waterborne applications The W400-LV High Performance center post gravity feed high transfer efficiency spray gun combines LV Technology with High-TEC standards and our tulip inspired spray pattern complies with regulations for the application of coatings within specific areas. High transfer efficiency control and superior atomization. LV technology will give the painter more material in the pattern and less overspray resulting in glass like finish. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W400LV-134G GUN - IWA4756
600.99
600.99
LV technology for less overspray on fine atomizationApplicable in solvent and waterborne productsHigh transfer efficiencyCenter post, gravity fed spray gunTraditional feel and set-up This gun comes with a 1.3 nozzle size. The W400 center post, gravity fed spray gun combines LV technology with high-TEC standard to give you high transfer efficiency control and superior atomization. The LV technology will produce a "tulip" pattern with fine atomization and less overspray. This model is shipped with the gun only, without a cup. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W400LV-134G Spray Gun Only - IWA4755
532.19
532.19
Iwata W400LV-134G Spray Gun with 700ml cup - IWA4757
592.99
592.99
LV technology, more material in pattern and less oversprayApplicable in both solvent and waterborne productsSuperior atomization10.2" patternCenter post gravity fed This gun comes with 1.3 nozzle and a 700ml cup. The W400LV is a center post gravity fed spray gun that combines "LV" technology with high-TEC standard to give high transfer efficiency control and superior atomization. The "LV" technology will produce "tulip" pattern, fine atomization and less overspray; which is environmentally friendly. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Iwata W400LV-134G with 1000ml cup AND AK-1B regulator - IWA4838
677.79
677.79
Page (3 of 4)
1 2 3 4 |
