Buy "holley" online - search for the best price - compare prices
Page (33 of 34)
29 30 31 32 33 34 |
Holley Throttle Body Wiring Harness - 534-47
40.99
40.99
Throttle Body Wiring Harness for 1 bbl & 2 bbl Pro-Jection SystemsProduct Features:Wiring Harness. Most Holley Jets products are available for in-store pickup from Advance Auto Parts.
Holley Throttle Body Wiring Harness - 534-48
46.99
46.99
Holley Throttle Body Wiring Harness - 534-56
19.99
19.99
Holley Trans Kickdown Lever Extension - 20-41
9.99
9.99
This handy part is used to extend the Ford O.E. transmission kick down lever when converting from a 2 bbl. to 4 bbl. carburetor.Product Features:Extends Kickdown LeverConverts 2 bbl To 4 bblVery Handy. Most Accelerator Cables products are available for in-store pickup from Advance Auto Parts.
Holley Trans Kickdown Spring & Bracket - 20-60
9.99
9.99
This is the hardware kit needed when installing a Holley universal carburetor with 1 mounting hole and locator pin to a Ford with automatic transmission.Product Features:One Locator PinCarbs w/30cc Accel. Pump. Most Accelerator Cables products are available for in-store pickup from Advance Auto Parts.
Holley Trans Kickdown Spring & Bracket - 20-91
11.99
11.99
Holley Transmission Cable Bracket - 20-113
19.99
19.99
Product Features:Transmission Cable Bracket. Most Accelerator Cables products are available for in-store pickup from Advance Auto Parts.
Holley Transmission Cable Bracket - 20-97
58.99
58.99
Holley Transmission Kickdown Throttle Linkage - 20-35
11.99
11.99
This part will bolt to the throttle lever of a Holley Model 4165/4175 carburetor. It will provide an effective mounting point for the transmission kick-down carburetor hookup.Product Features:Effective Mounting PointFor Transmission KickdownFor Carburetor Hookup. Most Accelerator Cables products are available for in-store pickup from Advance Auto Parts.
Holley Trick Kit; Carburetor Rebuild Kit - 37-933
109.99
109.99
Trick kit; Carburetor rebuild kit made of genuine holly quality parts and serves all Holley performance carburetors. Includes extra parts for perfect tuning, step-by-step instructions, detailed tuning guide, and packaging also parts tray. Designed as a master parts package for the serious tuner.Product Features:Serves All Holley Perf. CarburetorsGenuine Holley Quality PartsExtra Parts For Perf. TuningStep-By-Step InstructionsDetailed Tuning GuidePackaging Also Parts Tray. Most Carburetor Repair Kits products are available for in-store pickup from Advance Auto Parts.
Holley Truck Avenger Carburetor - 0-90470
440.99
440.99
The off-road truck avenger is designed specifically for off-road applications. The unique fuel metering block eliminates fuel spillover through the boosters at extreme angles allowing for 40 degree climbing, 30 degree side hill maneuvers and nose-down descents to avoid hesitations, stalling and flooding typically associated with carbs in an off road environment. The 470 CFM off-road truck avenger is the perfect carburetor for 4 cylinder, V-6, and inline 6 cylinder engines. Viton(R) is a registered trademark of DuPont Performance Elastomers.Product Features:Designed For Truck EnthusiastNo Trouble Metering BlockEliminates Fuel SpilloverFlood-Free At Extreme AnglesGreat Low and Mid-Range ThrottleGreat Low and Mid-Range TorqueBuilt For DurabilityOff-Road In Confidence. Most Carburetors products are available for in-store pickup from Advance Auto Parts.
Holley Truck Avenger Carburetor - 0-90670
417.99
417.99
Holley Truck Avenger Carburetor - 0-90770
451.99
451.99
Holley Tuning/Calibration Kit - 36-182
108.99
108.99
This tuning kit contains a selection of main jets, pump Nozzles and power valves, in popular sizes, all contained in a handy and durable, compartmentalized plastic case. Ideal for track-side tuning, this kit provides a quick and easy way to accomplish your carburetor tuning with the correct parts. In addition, the parts case allows you to keep parts organized and readily at hand. A handy parts guide is affixed to the inside case cover. Numbers referenced on the parts guide will assist in reordering components when necessary. Gaskets are included to facilitate carburetor reassembly.Product Features:4 Each - 8 Metering Jet Sizes4 Pump Nozzles3 Power Valves12 Metering Block Gaskets12 Fuel Bowl GasketsMisc. Pump NozzleMisc. Power ValveMisc. Fuel Bowl Screw Gaskets. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Two-Stage Power Valve - 125-206
46.99
46.99
Product Features:Includes Gasket. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Two-Stage Power Valve - 125-207
46.99
46.99
Holley Two-Stage Power Valve - 125-208
36.99
36.99
Holley Umbrella Check Valve - 26-41
13.99
13.99
Accelerator pump Umbrella Check ValveProduct Features:Umbrella Check ValveF135-5. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Universal Carburetor Installation Kit - 20-124
22.99
22.99
The kit contains all the hardware necessary for most installations of a new 4 bbl carburetor including: mounting studs (including an extra long one for securing throttle cable / kick down cable brackets), washers, nuts, air cleaner stud, vacuum caps, 3 different throttle cable balls, bushing Adapter for large hole of throttle lever, air cleaner gasket and base gaskets for square and spread bore carbs.Product Features:Universal Carburetor Installation Kit. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Universal Dashpot - 11-4
36.99
36.99
Universal Dashpot. Its purpose is to prevent engine stalling on sudden deceleration Designed to be used on manual-transmission equipped vehicles. 7/16-inch-20 thread.Product Features:Universal Dashpot. Most Accelerator Cables products are available for in-store pickup from Advance Auto Parts.
Holley VACUUM CAP ASST. - 26-105
10.99
10.99
A selection of different size vacuum tube caps. An indispensable addition to any professional tool kit.Product Features:Different Size Vacuum Tube Caps. Most Fasteners products are available for in-store pickup from Advance Auto Parts.
Holley Vacuum Gauge - 26-501
33.99
33.99
Product Features:2 in. Diameter0-30 in. HgChromed Steel Case0.125 in. NPT Brass FittingHose Fitting Included. Most Clocks & Compasses products are available for in-store pickup from Advance Auto Parts.
Holley Vacuum Passage Gasket - 108-67-20
17.99
17.99
Seals Vacuum Passages to Vacuum Secondary Housing and Automatic Choke Housing.Product Features:Seals Vacuum PassagesTo Vacuum SecondaryTo Automatic Choke Housing. Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Holley Vacuum Secondary Diaphragm - 135-2
15.99
15.99
Vacuum secondaries are activated by venturii velocity through the primary venturii and further aided by secondary venturii velocity. Engine/manifold vacuum is not related and has no effect on the operation of the carburetors secondary system.Product Features:Vacuum Secondary Diaphragm. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Vacuum Secondary Diaphragm - 135-3
15.99
15.99
Page (33 of 34)
29 30 31 32 33 34 |
