Buy "holley" online - search for the best price - compare prices
Page (31 of 34)
27 28 29 30 31 32 33 34 |
Holley Strip Dominator; Intake Manifold - 300-25
210.99
210.99
Strip Dominator intake manifold square bore carburetor mounting flange. Single plane with isolated plenum. Isolated water cross-over.Product Features:4500-7600 RPM Power BandSingle PlaneOpen Deep Plenum DesignSquare Flange Carb. MountingFront Height 5.11 in.Rear Height 5.97 in.No Exhaust Heat Crossover ProvisionIdeal For Drag Cars w/Auto Trans. Most Intake Manifold Hardware products are available for in-store pickup from Advance Auto Parts.
Holley STUD KIT - 20-40
8.99
8.99
MPN #20-40. Holley STUD KIT. Most Accelerator Cables products are available for in-store pickup from Advance Auto Parts.
Holley Supercharger Carburetor - 0-80572S
549.99
549.99
These carburetors that are intended for use with superchargers, and have a unique capability that allows their power Valves to reference the intake Manifold vacuum below the supercharger. This allows the power valve to operate as it should, based off intake manifold vacuum. A power valve provides further enrichment to the main metering system under load (low vacuum) conditions. Without this external referencing, the power valve would be reading the Supercharger boost pressure, which has no bearing on the engine load.Product Features:Specifically Designed For Roots Style Blown Eng.100 Per Cent Wet-Flow Tested And CalibratedFour Corner Idle SystemReplaceable Air BleedsDual Metering BlocksDual Feed Fuel InletsCenter Hung Float BowlsShiny Finish. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Supercharger Carburetor - 0-80573S
613.99
613.99
Holley Supercharger Carburetor - 0-80592S
472.99
472.99
These carburetors that are intended for use with superchargers, and have a unique capability that allows their power Valves to reference the intake Manifold vacuum below the supercharger. This allows the power valve to operate as it should, based off intake manifold vacuum. A power valve provides further enrichment to the main metering system under load (low vacuum) conditions. Without this external referencing, the power valve would be reading the Supercharger boost pressure, which has no bearing on the engine load.Product Features:Specifically Designed For Roots Style Blown Eng.100 Per Cent Wet-Flow Tested And CalibratedFour Corner Idle SystemReplaceable Air BleedsDual Metering BlocksDual Feed Fuel InletsCenter Hung Float BowlsShiny Finish. Most Carburetors products are available for in-store pickup from Advance Auto Parts.
Holley Swivel Fitting - 26-25
21.99
21.99
Product Features:0.3125 in. Hose0.5625 - 24 Thread. Most Carburetor Fuel Parts products are available for in-store pickup from Advance Auto Parts.
Holley SysteMAX; Intake Manifold Gasket - 108-80
31.99
31.99
Kormetal gasket used between the SysteMax II Ford 5.0 liter upper and lower manifolds.Product Features:SysteMAX II Upper/Lower Manifold. Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Holley TBI Adapter - 17-41
52.99
52.99
Product Features:TBI Adapter. Most Carburetor Adapter Plates products are available for in-store pickup from Advance Auto Parts.
Holley TBI Adapter - 17-45
56.99
56.99
Product Features:TBI Adapter. Most Air Cleaner Assemblies products are available for in-store pickup from Advance Auto Parts.
Holley TBI Adapter - 17-47
104.99
104.99
Holley TBI Adapter - 17-6
57.99
57.99
Holley Throttle Body - 9925-103
15.99
15.99
Does your engine seem like it is out of breath? You can increase engine breathing with a Holley high-air -flow throttle body! Fully CNC machined from 6061 billet aluminum, these new Holley throttle bodies are designed to use the stock TPS and IAC to simplify installation. They are bright dipped clear anodized for long lasting good looks and corrosion protection. They also include all the necessary vacuum ports and linkage to facilitate installation. Do not get left in the dust. New Holley high-flow throttle bodies are the ticket to ride.Product Features:Includes 4 Plates and 8 Screws. Most Holley Jets products are available for in-store pickup from Advance Auto Parts.
Holley Throttle Body Gasket - 108-116
11.99
11.99
Product Features:Throttle Body Gasket. Most Fuel Injection Gaskets products are available for in-store pickup from Advance Auto Parts.
Holley Throttle Body Gasket - 108-3
5.99
5.99
Product Features:Throttle Body Gasket. Most Carburetor Gaskets & Spacers products are available for in-store pickup from Advance Auto Parts.
Holley Throttle Body Gasket - 108-40
10.99
10.99
Holley Throttle Body Gasket - 108-5
5.99
5.99
Holley Throttle Body Gasket - 108-57
8.99
8.99
Holley Throttle Body Gasket - 108-61
9.99
9.99
Holley Throttle Body Gasket - 108-7
5.99
5.99
Holley Throttle Body Gasket - 108-74
9.99
9.99
Holley Throttle Body Gasket - 508-1
9.99
9.99
Product Features:Throttle Body Gasket. Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Holley Throttle Body Gasket - 508-11
24.99
24.99
Holley Throttle Body Gasket - 508-14
7.99
7.99
Holley Throttle Body Gasket - 508-15
8.99
8.99
Holley Throttle Body Gasket - 508-2
19.99
19.99
Page (31 of 34)
