Buy "holley" online - search for the best price - compare prices
Page (2 of 34)
1 2 3 4 5 6 |
Holley Accelerator Pump; Discharge Nozzle - 121-228
9.99
9.99
A good selection of accelerator pump discharge nozzle sizes is indispensable to the proper tuning of the accelerator pump system. The nozzle hole size determines the rate of fuel discharge. A larger hole will shoot the fuel at a faster rate, and with less pressure, than a smaller hole. Sizes are stamped on each nozzle. For example, the number 31 indicates that the nozzle hole size is .031-inches. Various styles of nozzles are offered by Holley.Product Features:Includes 2 Gaskets. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Accelerator Pump; Discharge Nozzle - 121-231
9.99
9.99
Holley Accelerator Pump; Discharge Nozzle - 121-237
9.99
9.99
Holley Accelerator Pump; Discharge Nozzle - 121-240
14.99
14.99
Holley Accelerator Pump; Discharge Nozzle - 121-25
21.99
21.99
Holley Accelerator Pump; Discharge Nozzle - 121-28
21.99
21.99
Holley Accelerator Pump; Discharge Nozzle - 121-31
23.99
23.99
Holley Accelerator Pump; Discharge Nozzle - 121-325
10.99
10.99
Holley Accelerator Pump; Discharge Nozzle - 121-35
21.99
21.99
Holley Accelerator Pump; Discharge Nozzle - 121-37
22.99
22.99
Holley Accelerator Pump; Discharge Nozzle - 121-40
21.99
21.99
Holley Accelerator Pump; Discharge Nozzle - 121-42
21.99
21.99
Holley Accelerator Pump; Discharge Nozzle - 121-45
21.99
21.99
Holley Accelerator Pump; Pump Arm - 20-114
13.99
13.99
Product Features:Pump Arm. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Accelerator Pump; Pump Arm - 20-78
8.99
8.99
Holley Accelerator Pump; Pump Cover - 34-504
19.99
19.99
Mech, fuel pump mounting pad cover used to cover the hole in the block when mechanical fuel pump is removed to use an electric pump.Product Features:Chrome. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Accelerator Pump; Pump Cover - 34-505
21.99
21.99
Holley Accelerator Pump; Pump Cup/Stem - 135-1
9.99
9.99
Product Features:Pump Cup/Stem. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Accelerator Pump; Transfer Tube - 26-23
7.99
7.99
Product Features:Transfer Tube. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Accelerator Pump; Transfer Tube O-Ring - 26-38
6.99
6.99
Replacement Viton Seal. Fits new style transfer tube. 2 per packProduct Features:Transfer Tube O-Ring. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Accelerator Pump; Tuning Kit - 36-184
129.99
129.99
This tuning kit is composed of a selection of accelerator pump hardware components including pump diaphragms, pump nozzles, pump Cams and related parts. Contained in a convenient plastic parts case, this kit has all that is required to properly tune and calibrate the accelerator pump circuit(s) for your street, drag or circle track car or tow vehicle. A handy parts guide is affixed to the inside case cover to assist in reordering components when necessary. Accelerator Pump Tuning Kit For Holley 2 BBL And 4 BBL Performance CarburetorProduct Features:Includes Pump DiaphragmsPump NozzlesPump CamsRelated Parts. Most Carburetor Parts products are available for in-store pickup from Advance Auto Parts.
Holley Air Bleed Assortment Kit - 36-240
203.99
203.99
This air bleed kit is a must when track tuning a Holley 4500 DOMINATOR HP or Model 4150HP carburetor for maximum performance.Product Features:Including 4 Of Each Size #20-#79All Are #10-32 UNF ThreadContained In Plastic CaseSeparated And Easy Accessible. Most Fuel System Performance products are available for in-store pickup from Advance Auto Parts.
Holley Air Charge Sensor - 534-46
23.99
23.99
Air Charge Sensor For Commander 950 and 4Di TBI Pro-Jection SystemsProduct Features:Air Charge Sensor. Most Holley Jets products are available for in-store pickup from Advance Auto Parts.
Holley Air Cleaner Gasket - 108-4
7.99
7.99
Carburetor Air-Horn to Air Cleaner Gasket.Product Features:Throttle Body Gasket. Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Holley Air Cleaner Gasket - 108-62
10.99
10.99
Carburetor Air-Horn to Air Cleaner Gasket. Most Engine Gaskets products are available for in-store pickup from Advance Auto Parts.
Page (2 of 34)
1 2 3 4 5 6 |
