Buy "hays" online - search for the best price - compare prices
Page (3 of 5)
1 2 3 4 5 |
Hays Performance; Flywheel - 20-130
499.99
499.99
Hays aluminum flywheels are manufactured from certified billet material that will not break up under the stress of high RPM and severe punishment of racing. Features replaceable steel surface insert. Precision balanced to either neutral (internal) or Detroit (external) specifications. Meets SFI specification 1.1 for racing.Product Features:Certified Billet MaterialBorg and Beck Clutch PatternLong-Style Clutch PatternRing Gear Securely Mounted To Prevent Spinning. Most Manual Transmissions products are available for in-store pickup from Advance Auto Parts.
Hays Performance; Flywheel - 23-130
499.99
499.99
Hays Pressure Plate 30-012 Clutch Covers (Pressure Plates)
302.99
302.99
Pressure Plate by Hays for Jeep 10.5" diameter;2750 static pressure;Sold each Hays Pressure Plate 30-012 Clutch Covers (Pressure Plates)
Hays Standard Shift Flywheel 10-330 Clutch Flywheels
363.99
363.99
Standard Shift Flywheel Fits 1963 to 1985 V8 305-350 small block chevy engines except 400 cubic inch;Certified billet material;153 gear teeth Hays Standard Shift Flywheel 10-330 Clutch Flywheels
363.99
363.99
Hays Standard Shift Flywheel 16-130 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays Fits 1972 to 1991 YJ Wrangler and CJ;Fits 1974 to 1991 SJ Full Size and J-series truck;Billet steel;AMC 360 V8 engine;This flywheel will accept 10-1/2" or 11" clutch assembly JEEP CHEROKEE J10 J20 S 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 5.9L (360) GAS Hays Standard Shift Flywheel 16-130 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays Fits 1972 to 1991 YJ Wrangler and CJ;Fits 1974 to 1991 SJ Full Size and J-series truck;Billet steel;AMC 360 V8 engine;This flywheel will accept 10-1/2" or 11" clutch assembly Hays Standard Shift Flywheel 16-130 Clutch Flywheels
Hays Standard Shift Flywheel 16-132 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays Fits 1972 to 1983 CJ;Made of billet steel;AMC 304 V8 engine;Will accept 10-1/2" or 11" clutch assembly;SFI approved 37 lb. JEEP CJ5 CJ7 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 5L (304) GAS Hays Standard Shift Flywheel 16-132 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays Fits 1972 to 1983 CJ;Made of billet steel;AMC 304 V8 engine;Will accept 10-1/2" or 11" clutch assembly;SFI approved 37 lb. Hays Standard Shift Flywheel 16-132 Clutch Flywheels
Hays Standard Shift Flywheel 16-134 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays Fits 1972 to 1979 CJ;Fits 1974 to 1979 SJ Full Size and J-series truck;AMC 401 V8 engine;Billet steel,This flywheel will accept 10-1/2" or 11" clutch assembly JEEP CHEROKEE CJ5 J10 J20 S 1972 1973 1974 1975 3.8L (232) 4.2L (258) 5.9L (360) 5L (304) 6.6L (401) GAS Hays Standard Shift Flywheel 16-134 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays Fits 1972 to 1979 CJ;Fits 1974 to 1979 SJ Full Size and J-series truck;AMC 401 V8 engine;Billet steel,This flywheel will accept 10-1/2" or 11" clutch assembly Hays Standard Shift Flywheel 16-134 Clutch Flywheels
363.99
363.99
Hays Standard Shift Flywheel 10-530 Clutch Flywheels
399.99
399.99
Standard Shift Flywheel by Hays for Jeep Fits all small block Chevy engines 1986-96 except 400 cubic inch;153 teeth and provisions for 10.5" clutch cover Hays Standard Shift Flywheel 10-530 Clutch Flywheels
399.99
399.99
Standard Shift Flywheel by Hays Fits all small block Chevy engines 1986-96 except 400 cubic inch;153 teeth and provisions for 10.5" clutch cover Hays Standard Shift Flywheel 10-530 Clutch Flywheels
399.99
399.99
Hays Standard Shift Flywheel 10-630 Clutch Flywheels
399.99
399.99
Standard Shift Flywheel Hays Standard Shift Flywheel 10-630 Clutch Flywheels
399.99
399.99
Standard Shift Flywheel Fits 1986 to 1996 V8 305-350 engines;168 gear teeth;Certified billet material Hays Standard Shift Flywheel 10-630 Clutch Flywheels
399.99
399.99
494.99
494.99
Standard Shift Flywheel by Hays for Jeep Fits 1972 to 1991 YJ Wrangler and CJ;Fits 1974 to 1991 SJ Full Size and J-series truck;Billet steel;AMC 360 V8 engine;This flywheel will accept 10-1/2" or 11" clutch assembly JEEP CHEROKEE J10 J20 S 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 5.9L (360) GAS Hays Standard Shift Flywheel 16-130 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays for Jeep Fits 1972 to 1983 CJ;Made of billet steel;AMC 304 V8 engine;Will accept 10-1/2" or 11" clutch assembly;SFI approved 37 lb. JEEP CJ5 CJ7 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 5L (304) GAS Hays Standard Shift Flywheel 16-132 Clutch Flywheels
494.99
494.99
Standard Shift Flywheel by Hays for Jeep Fits 1972 to 1979 CJ;Fits 1974 to 1979 SJ Full Size and J-series truck;AMC 401 V8 engine;Billet steel,This flywheel will accept 10-1/2" or 11" clutch assembly JEEP CHEROKEE CJ5 J10 J20 S 1972 1973 1974 1975 3.8L (232) 4.2L (258) 5.9L (360) 5L (304) 6.6L (401) GAS Hays Standard Shift Flywheel 16-134 Clutch Flywheels
Hays Street Clutch; Pressure Plate - 40-160
150.99
150.99
12 heavy-duty coil springs to exert maximum pressure on the disc. Heavy-duty eye bolts and levers ensure strength against breakage. 2400 pounds static pressure.Product Features:Exceeds OE SpecificationsQuick Release For Precise Gear ChangesClean Release For Precise Gear ChangesLight Pedal Pressure. Most Manual Transmissions products are available for in-store pickup from Advance Auto Parts.
Hays Street; Clutch Kit - 85-100
381.99
381.99
Matched assembly for maximum reliability. An excellent choice for high performance street applications.Product Features:Built As Matched AssemblyExceptional PerformanceExceptional DurabilityLong Term DependabilityDesigned for Street And Street Strip Applications. Most Manual Transmissions products are available for in-store pickup from Advance Auto Parts.
Hays Street; Clutch Kit - 85-101
399.99
399.99
Hays Street; Clutch Kit - 85-102
359.99
359.99
Page (3 of 5)
1 2 3 4 5 |
