Buy "fowler" online - search for the best price - compare prices
Page (2 of 4)
1 2 3 4 |
Fowler DIAL INDICATOR - FOW72-520-110
25.21
25.21
1 Universal Handle, 2 Adapters2 Deburring Blades1 Countersink for 20mm/.47" diameter1 Countersink for 30mm/1.18" diameter4 Cleaner Blades, for sheet metal, small ridges, relieving corners and for narrow slots A complete kit for the Auto Repair Professional. In a compact molded case. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler DIAL INDICATOR and MAGNETIC BASE SET
77.95
77.95
1 travel - continuous reading AGD group 2; 2-1/4 dial diameter Revolution counter Lug back mountMagnetic...
Fowler Dial Indicator Gage Set with Flexible Arm and Magnetic Base
75.95
75.95
Multipurpose tool with 12-1/2 flexible arm which can be set in any desired plane Great for precision...
Fowler Dial Indicator Set with Magnetic Base - 1" Range
78.95
78.95
Includes 1 range indicator Magnetic base Rods Swivel clamp Wooden case. Indicator features 2 dial face...
Fowler Diamond File and Deburring Set - FOW72-483-666
66.99
66.99
Diamond impregnated for use on even the hardest alloys1 handle, providing maximum grip comfort5 piece set of diamond impregnated files consisting of a round, flat, square, triangle and half-round file, 5-1/2" long with 2-1/2" length of cut2 triangular scraper/deburring tools (single and double ended)Fitted storage case Diamond File and Deburring Set, a must for the auto shop.? . Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Digi-Pro 12" Electronic Protractor
91.95
91.95
Includes embedded magnets for easy measuring of ferrous metal surfaces On/Off Zero Hold and Reverse...
Fowler Digi-Pro Electronic Protractor - FOW74-440-775
92.99
92.99
Embedded 25 lb. pull magnetsFull, 360? measuring rangeAccuracy: 2? +/-, Repeatability: .05? +/-, Resolution: .05? +/-Invertible display featureVoltage: Standard 3V lithium battery The Digi-Pro 12"/300mm electronic protractor includes embedded magnets for unique measurement areas.? On/Off, Zero, Hold and Reverse feature to invert the display for easier reading in certain situations.? Ideal for fabrication applications.? Use the Digi-Pro to make fast and accurate angular measurements. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Digit Counter Micrometer with Insulated Frames-0-25mm
54.95
54.95
Digit Counter Carbite tipped measuring faces Rachet thimble and locking nut Complete in shop-hardened...
Fowler Digit Micrometer 0-1 - FOW72-224-001
46.97
46.97
Graduations: .001"/.02mmHardened stainless steel constructionInside, outside, step and depth measurementDepth rodIncludes fitted case. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Digit Reading Depth Micrometer 0-6in. - FOW72-225-226
142.89
142.89
Easy to read digit counter.001in. graduation4in. base, hardened and groundSatin chrome finishRatchet thimble Features a locking clamp. Furnished with shop hardened case. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Disc and Rotor / Ball Joint Gage - FOW72-520-730
125.39
125.39
Checks ball joint wear and disc rotor runoutChecks tire and wheel runout, gear backlash, valve guide wear, etc.Meets state inspection requirementsIndicator features 0-1 in./25mm travel, .001 in./.01mm graduations and adjustable tolerance limit markersFlexarm can be rigidly locked in any position up to 12 in.Locking pliers provide a secure, convenient clamp to any objectIncludes shop hardened caseInch/metric reading dial indicator makes this set ideal for both foreign and domestic applications. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Disc and Rotor Combo Kit - FOW72-520-222
144.39
144.39
Consists of Disc Rotor/Ball Joint Gage and Digit Disc Brake MicrometerThe Disc Rotor/Ball Joint Gage checks ball joint wear, disc rotor run out, tire and wheel run out, gear backlash, valve guide wear, etc.12 Flex arm can be set to almost any measuring positionDigit Disc Brake Micrometer measures thickness, thickness variation, and score depthMeasuring range is .300-1.300 .001 graduations, jaw depth 3.5 Other features: 0-1 in. indicator .001 graduations; Carbide tipped anvil faces; Includes measuring standard; positive locking nut on spindle. Both tools provided in a shop hardened case. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Disc Brake Rotor and Ball Joint Gauge Set - FOW72-520-717
196.99
196.99
Checks ball joint wear and disc rotor run outChecks tire and wheel run out, gear backlash, valve guide wear, etc.Meets state inspection requirementsIndicator features 0-1" travel, and .001" graduationsIncludes shop-hardened case. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Disposable Deburring Tool - FOW52-483-125
5.89
5.89
Includes S-10 blade for steel, aluminum and plasticRounded head on blade for safe deburringMounted in an aluminum handleComes with Pocket ClipEconomical deburring tool that can be thrown away when it becomes dull. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Economy Disc Brake Rotor & Ball Joint Gauge Set - FOW72-520-757
84.49
84.49
Checks ball joint wear and disc rotor run-out Meets requirements of all state inspection stations Can also be used to check tire and wheel run-out, gear backlash and valve guide and camshaft wear. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Electronic Caliper and E-Z Read Micrometer Set - FOW74-004-201
132.99
132.99
Set includes: 6"/150mm Electronic Caliper; .0005"/.01mm resolution, absolute/incremental measurements, direct inch/metric conversion and 4 way measurement0-1" EZ-Read Digit Counter Micrometer, insulated frame, carbide measuring faces and direct reading to .0001" without a vernierIncludes shop-hardened case. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Electronic Disc Brake Micrometer - FOW74-860-234
157.39
157.39
Dust, water and oil resistantJaw depth: 3.5"Range: 0.3" - 1.3"Resolution: .00005"/.001mmDirect inch/metric conversion Carbide tipped measuring faces. Includes measuring standard. Includes case. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Electronic Extended Range Disc Brake Micrometer - FOW74-860-434
204.99
204.99
Range: 0.3 in. -1.7 in./7-44mm, resolution: .00005 in./.001mmJaw depth: 3.5 in.Water, oil and dust resistantFriction ThimbleCarbide tipped measuring faces This Electronic Extended Range Disc Brake Micrometer, with a range of 0.3 in. - 1.7 in., fits most popular range of disc brake sizes. It is water, oil and dust resistant and features auto-shutoff, ABS/INC measurement, preset recall and direct inch/metric conversion. Micrometer includes a case and measuring standard. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Electronic Micrometer - FOW74-850-001
83.49
83.49
Range: 0.3" - 1.7"Resolution: .00005"IP54: Water, oil and dust resistantAuto-shutoff with no loss of measurementDirect inch/metric conversion Carbide tipped measuring faces. Includes measuring standard. Includes case. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Electronic Rotorcal Rotor Gauge w/Twin Conical Anvils
76.95
76.95
Range 5.5140mm Reads in inch metric and fractions Direct inch/metric/fraction conversion ...
Fowler Extended Range Digit Disc Brake Micrometer - FOW72-234-422
75.29
75.29
Fast, easy to read digit counterRange: 0.3" - 1.7" / 10-45mmDigital counter reads .001" / 0.01mm; sleeve reads .0001"/0.01mmRatchet thimbleCarbide tipped measuring faces Includes case and measuring standard. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Extended Range Disc Brake Micrometer - FOW74-815-434
183.59
183.59
Range: 0.3" - 1.7"Resolution: .00005"IP54: Water, oil and dust resistantAuto-shutoff with no loss of measurementDirect inch/metric conversion Carbide tipped measuring faces. Includes measuring standard. Includes case. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Fowler Extended Range Vernier Disc Brake Micrometer - FOW72-234-402
59.39
59.39
Sharp black graduations on satin chrome finishRange: 0.3" - 1.7"Graduation: .001"Jaw depth: 3.5"Ratchet thimble Carbide tipped measuring faces. Includes measuring standard. Includes shop-hardened case. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler EZ-Drum Electronic Brake Drum Gage - FOW74-150-020
185.69
185.69
4" to 20"/100 to 500mm capacityInch/Metric/Fraction conversion4" Drum preset, Zero Set, Hold functionPreset depth at 1" and 1.5"Resolution: .0005"/.01mm (fractions in 1/64" increments) Protected to IP54 specifications. Beam has Vernier scale to double check reading. Can be used to check some disc measurements. Other features include thumb lock and RS 232 capability. Includes wooden case. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Fowler Flex Arm Base and Dial Indicator Combo - FOW72-641-300
74.39
74.39
Flex arm mag base features 85 lb. pull and holds rigidly in any position desiredIndicator features 1" travel2-1/4" dial diameterReading: .001"; continuous reading: 0-100Revolution counter. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Page (2 of 4)
1 2 3 4 |
