Buy "firepower" online - search for the best price - compare prices
Page (8 of 8)
4 5 6 7 8 |
Firepower Type 1 Cut-Off Abrasive Wheel, 3? x 1/16? x 1/4? - FPW1423-3142
2.09
2.09
Firepower Double Reinforced Cut-Off Wheels are designed for heavy duty cut-off jobs using circular saws, chop saws and straight grinding machinesThey ensure optimum effectiveness for dry applications on a broad range of ferrous and non-ferrous metals, soft ceramics, masonry materials, reinforced plastic and fiberglassMax. RPM: 25,000Grade: A46T2FG. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Cut-Off Abrasive Wheel, 3? x 1/16? x 3/8? - FPW1423-3143
2.19
2.19
Firepower Double Reinforced Cut-Off Wheels are designed for heavy duty cut-off? jobs using circular saws, chop-saws and straight grinding machinesThey ensure? optimum effectiveness for dry applications on a broad range of ferrous and non-ferrous? metals, soft ceramics, masonry materials, reinforced plastic and fiberglassMax. RPM: 25,000Grade: A46T2FG. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Cut-Off Abrasive Wheel, 3? x 1/8? x 3/8? - FPW1423-3144
2.09
2.09
Firepower Type 27 Depressed Center Grinding Wheel, 4-1/2? x .045? x 7/8? - FPW1423-3186
3.12
3.12
Fully reinforced with resin bonded aluminum oxide to ensure safety at high speed and to increase bonding and impact strengthDesigned for use on air or electric powered right angle or vertical shaft grindersWithout hubMax. RPM: 13,300Grade: A36S. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 27 Depressed Center Grinding Wheel, 4-1/2? x 1/8? x 5/8? - 11NC - FPW1423-3201
5.68
5.68
Full reinforced with resin bonded aluminum oxide to ensure safety at high speed and to increase bonding and impact strengthDesigned for use on air or electric powered right angle or vertical shaft grindersWithout hubMax. RPM: 18,300Grade: A24R. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 27 Depressed Center Grinding Wheel, 4-1/2inch x 1/4inch x 7/8inch - FPW1423-3153
3.26
3.26
Fully reinforced with resin bonded aluminum oxide to ensure safety at high speed and to increase bonding and impact strengthDesigned for use on air or electric powered right angle or vertical shaft grindersWithout hubMax. RPM: 13,300Grade: A24R. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Vers-A Flame Burner - FPW0384-1260
90.59
90.59
500,000 BTU single unit displayFor use with propane tanks of 20 lbs. or largerSingle flint striker included in every outfit10' hose withstands temps from -104 degrees to +140 degrees F.2-year limited warranty Used for burning weeds, removing paint, melting ice, preheating asphalt/tar, removing road markings and preheating large castings for welding. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Victor Style Cutting Tip 2inch Cutting Capacity - FPW0330-0623
16.86
16.86
2" cutting capacity. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Welders Gloves with Thumb Strap, Russet - Brown - FPW1423-0051
16.77
16.77
Premium quality hose produced to stringent specificationsMeets or exceeds the requirement of RMA and CGAGrade "R" welding hose is recommended for use with Acetylene Gas only. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Weldflex Welding Blanket 38inch x 24inch - FPW1423-1404
128.99
128.99
Use this exclusive fabric to protect personal and equipment during welding, cutting, grinding and other potentially hazardous operationsService range up to 1000. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Wheel Brush - FPW1423-2123
56.29
56.29
5/8" - 1/2" arbor hole, .014 wire size, 6,000 Max. RPMCarbon steel wireWell suited for use in the welding and fabricating industriesUsed for surface preparation prior to welding and brazing and for removing weld scale and spatter after the welding operation. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Wire Cup Brush, 2-1/2inch Diameter - FPW1423-2107
6.03
6.03
1/4" shank, .014" wire size, 4500 Max RPMSmall diameter cup brushes are designed for use in restricted or hard to reach areasExcellent for carbon cleaning, polishing, removal of scale, slag, rust and paint. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Multi-Flame Rosebud Heating Tip - Size 6
67.95
67.95
Multi-flame heating tip for pre-heating straightening annealing bending forging etc. Uses heat resistant...
Portable Oxy-Acetylene Tote Outfit - 150 Series
439.95
439.95
Everything you need except the gas. These lightweight outfits allow you to take the torch to the job...
Page (8 of 8)
4 5 6 7 8 |
