Buy "firepower" online - search for the best price - compare prices
Page (5 of 8)
1 2 3 4 5 6 7 8 |
Firepower Grinding Wheel - FPW1423-2189
4.42
4.42
Firepower depressed center wheels are fully reinforced with resin bonded? aluminum oxide to ensure safety at high speed and to increase bonding and impact strength Designed for use on air or electric powered right angle or vertical shaft grinders Without hub. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Grinding Wheel - FPW1423-3203
8.51
8.51
Full reinforced with resin bonded aluminum oxide to ensure safety at high speed and to increase bonding and impact strengthDesigned for use on air or electric powered right angle or vertical shaft grindersWithout hubMax. RPM: 18,300Grade: A24R. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Hand Held Welding Shield 2inch x 4-1/4inch - FPW1423-4100
14.29
14.29
Streamlined, compact design allows welders to get into tight placesMeets or exceeds: ANSI Z87-1, CE and various International Standards. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Helmet Replacement Headgear for Eclipse - FPW1423-4110
18.46
18.46
Polycarbonate clear safety or cover plates, as components of welding goggles or helmets exceed the high velocity and high impact requirements of the ANSI Z87.1 - 1989 and Canadian CSA Z94.3 standardsFunctions as either cover or safety plateEliminates the accidental use of a cover plate in instances where a safety plate is necessary. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Knot-Type Wire Cup Brush, 4inch Diameter - FPW1423-2115
31.80
31.80
5/8" - 11 NC threaded arbor.020 wire size8,500 Max. RPMHeavy duty cup brushes with arbor adapters and threads to fit most grinders. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Knot-Type Wire Cup Brush, 6inch Diameter - FPW1423-2116
51.03
51.03
5/8" - 11 NC threaded arbor.020 wire size6,500 Max. RPMHeavy duty cup brushes with arbor adapters and threads to fit most grinders. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Knotted End Brush, 1-1/2inch Diameter - FPW1423-2118
14.99
14.99
1/4" shank, .020" wire size, 20,000 Max RPM.Designed for use in restricted or hard to reach areasExcellent for deburring, blending and cleaning of surfacesSmall diameter brushes are especially designed for use on portable air and electric tools Applications include deburring, blending, removal of rust, cleaning. End brushes are great for cylinder heads, pistons and valve ports, rubber and plastic flash removal, removal of rust, paint scale, tool polishing, and weld cleaning. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Knotted Type Wire Cup Brush, 3inch Diameter - FPW1423-2110
21.69
21.69
5/8" - 11 NC threaded arbor.020" wire size, 12,500 Max RPMHeavy duty cup brushes with arbor adapters and threads to fit most grinders. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Knotted Wheel Brush, 6inch - FPW1423-2119
26.04
26.04
Firepower Knotted Wheel Brush, 6inch Diameter - FPW1423-2120
30.48
30.48
Firepower Knotted Wire Cup Brush, 3inch - FPW1423-2126
28.99
28.99
ARBOR REDUCING ADAPTOR, 5/8_-11. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Long Handle Stainless Steel Scratch Brush - FPW1423-0082
5.80
5.80
Trim length: 1-3/16"3 x 19 rows. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Lug / Splicer Crimping Tool - FPW1423-1209
31.90
31.90
1/2" trim width; 3/4" trim length. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Malleable Iron C-Clamp - 4inch - FPW1423-1419
15.40
15.40
Steel spindles are copper plated for splatter protectionSwivel pads adjust freely to bear evenly on clamped partsLacquered finishThroat capacity: 0-4"; depth: 2-1/4"; spindle diameter: 7/16". Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Mandrel Set for 1/4inch and 3/8inch Arbor - FPW1423-2185
8.09
8.09
Made of high strength alloy steelIdeal for small diameter cut-off wheels with a thickness of 1/32" to 1/4". Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Mig Gun Nozzle 1/2inch Bore Fits All FP Mig Guns - FPW1444-0051
19.03
19.03
Uses standard 230 volt household currentAC welding outputInfinite amperage adjustmentThermostatic heat protectionPortable wheel and handle kit Other features include: professional dinse style cable connections; fan cooled transformer; illuminated power on indicator; illuminated thermal overload indicator; and thermostatic heat protection. 5-2-1 warranty. The FP235 offers powerful 235 Amp AC (SMAW) welding performance at an affordable price. The FP235 features infinite amperage adjustment, which provides precise welding control. This versatile unit is ideal for both light and heavy duty repairs. The FP 235? s rugged, portable design delivers the reliability and performance to make it an ideal unit for general fabrication as well as farm, ranch, automotive and light maintenance repairs. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Mig Welding Cart - FPW1444-0407
178.59
178.59
Heavy duty mig welder cartDouble re-enforced cross membersHeavy duty castersIndustrial coating resists chips and rustBuilt in cylinder rack and storage tray Works with FP90, FP120, FP130 or FP160. MIG WELDER NOT INCLUDED!!!!!!!!!. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Mounting Point, 7/8? x 2-3/4? x 1/4? - FPW1423-2202
3.37
3.37
Offer maximum performance for grinding of ferrous and non-ferrous and non-ferrous metalsFor use with horizontal or straight shaft, die and pencil grinders on jobs where larger cones and plugs won't fitExcellent for medium to heavy duty applications in metal fabrication, foundries, steel mills; used for grinding ferrous and non-ferrous metalsIdeal for rapid stock removal on high alloy steel, castings and special steel. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Multi Flame Heating Nozzle 8-MFA - FS - FPW0323-0272
62.72
62.72
For heating, straightening, bending and brazingHeat-resistant replaceable copper tipIndividual spiral mixer provides optimum flame characteristics. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Multi-Purpose Magnetic Holder - FPW1423-1424
11.38
11.38
Mag tool will hold both sheet and tube at angles of 45 degrees. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Multi-Purpose Magnetic Holder - FPW1423-1426
19.49
19.49
Mag Tool will hold both sheet and tube at angles of 45 degrees4.7" x 3.4" x 0.56". Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Multi-Purpose Magnetic Holder - Medium - FPW1423-1425
16.42
16.42
Firepower Optimax Safety Glasses, 58mm, Smoke Frame, Clear - FPW1441-3431
12.19
12.19
Meets or Exceeds ANSI Z87.1 and various International Standards. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Oxy-Acetylene Torch Kit - FPW0384-0990
474.99
474.99
Welds to 1/8", cuts to 1/2"This lightweight outfit lets you take the torch and gas to the job whether it is in the field or just around the yardIdeal for plumbing, construction, farming and HVAC applications2 year warranty Includes: WH260C Torch, 150 Series cutting attachment, #2 welding nozzle (1/8" welding capacity),#0 cutting tip (1/2" cut capacity), 150 series Oxy-Acetylene regulators, 3/16"x 12.5' Dual-line hose, goggles, striker, cylinder wrench, 10 cu/ft. "MC" acetylene cylinder and 20 cu/ft. "R" oxygen cylinder. Both shipped empty. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Oxygen Hose Union, 1Pk - FPW1423-1304
3.28
3.28
1/2" trim width; 3/4" trim length. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Page (5 of 8)
1 2 3 4 5 6 7 8 |
