Buy "firepower" online - search for the best price - compare prices
Page (7 of 8)
3 4 5 6 7 8 |
Firepower Solder, Rosin Flux Core, 30/70, 3/32inch x 1/2 lb - FPW1423-1113
7.74
7.74
1/2" trim width; 3/4" trim length. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Solder, Rosin Flux Core, 40/60, 3/32inch x 1/4 lb - FPW1423-1112
5.51
5.51
Firepower Soldering Flux, Liquid, 2oz. - FPW1423-1111
4.08
4.08
Firepower SS SHOE HANDLE - FPW1423-1442
5.11
5.11
SS SHOE HANDLE BRUSH. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Firepower Standard Tip Cleaners - FPW1423-0016
9.79
9.79
Premium quality hose produced to stringent specificationsMeets or exceeds the requirement of RMA and CGAGrade "R" welding hose is recommended for use with Acetylene Gas only. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Standard Twist Wire Wheel Brush, 4inch Diameter - FPW1423-2113
16.66
16.66
5/8" - 11 NC arbor hole.020 wire size, 12,500 Max. RPMCarbon steel and stainless steel wireFirepower brushes are well suited for use in the welding and fabricating industriesUsed for surface preparation prior to welding and brazing and for removing weld scale and spatter after the welding operation. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Steel Rotary - FPW1423-2224
10.22
10.22
Firepower flap discs durability over the conventional fibre disc results in reduction of both labor and material costsDesigned to wear away evenly and present a constantly fresh work surfaceNo backing pad required - comes with fiberglass backing plate with higher RPM rating than resin fiber discsNo loading up, as new sharp abrasive particles are constantly exposedMaximum RPM: 13,300 Cut and finish at the same time with consistent finish - for coarse and intermediate grinding and machining of welds, deburring, rust removal, snagging, removal of paint, etc. This means fewer change-overs. Suitable for almost all materials: ferrous and non-ferrous metals, wood, leather, glass, marble and plastics. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Steel Rotary - FPW1423-2226
10.26
10.26
Firepower flap discs durability over the conventional fiber disc results in reduction of both labor and material costsDesigned to wear away evenly and present a constantly fresh work surfaceNo backing pad required - comes with fiberglass backing plate with higher RPM rating than resin fiber discsNo loading up, as new sharp abrasive particles are constantly exposedMaximum RPM: 13,300 Cut and finish at the same time with consistent finish - for coarse and intermediate grinding and machining of welds, deburring, rust removal, snagging, removal of paint, etc. This means fewer change-overs. Suitable for almost all materials: ferrous and non-ferrous metals, wood, leather, glass, marble and plastics. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Steel Rotary - FPW1423-3177
5.66
5.66
5/8" - 11 NC threaded arbor.014" wire size, 8,500 Max RPMHeavy duty cup brushes with arbor adapters and threads to fit most grindersMade with high quality tempered wireProvide fast cutting action for removal of light encrustation of scale, rust, paint or weld splatter The relative high flexibility of Firepower wire cup brushes allows cleaning on irregular surfaces as well as flat surfaces. These brushes are designed for use on portable power tools. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Stringer Bead Wire Wheel Brush, 4inch Diameter - FPW1423-2111
17.74
17.74
5/8" - 11 NC arbor hole.020" wire size, 12,500 Max RPMCarbon steel and stainless steel wireWell suited for use in the welding and fabricating industriesUsed for surface preparation prior to welding and brazing and for removing weld scale and spatter after the welding operation. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Thermal Dynamics C-35A Air Plasma Cutting System - FPW1-1635-1
1474.99
1474.99
Precision-engineered consumable parts are easy to change and require no toolsEasy-to-use torch trigger release and ergonomic handle provide comfort during long cutting sessionsTwo modes of operation available - standoff cutting and drag cuttingLightweight, flexible 20 ft (6.1m) torch leadsLatch feature allows the cutting arc to remain active with constantly depressing the torch switch Designed for the 1/2" cutting market, this economical plasma cutter is a favorite for auto body repair, light duty maintenance, and sheet metal fabrication, and it is also very useful around the farm or ranch. It cuts quickly through stainless steel, aluminum, mild steel, copper or brass, with minimum heat input and distortion of metal and it also cuts through rusted, painted or coated surfaces without prior surface preparation. This inverter-based system operates on standard 230VAC single phase input power and provides adjustable current from 15 to 35 amps. Weighing just 44 lbs. (20 kg), the C-35A is easy to move from location to location. Connect to an air compressor or other air source, and this simple-to-use system is ready to cut. Precise, reliable cutting is what you can expect from the SL60 1Torch, and the excellent front end parts visibility lets you see what you cut, while you cut. Starts without high-frequency so it will not interfere with controls or computers. Surelock electrode eliminated tip wobble. Protective interlock circuitry disables the power supply if torch consumable parts are incorrectly assembled. Full 1-year warranty on repair parts and labor. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Firepower Thermal Dynamics C-70A Air Plasma Cutting System - FPW1-1670-1
2183.69
2183.69
Protective interlock circuitry disables the power supply if torch consumable parts are incorrectly assembledSurlock electrode eliminates tip wobbleTwo modes of operation available - standoff cutting or drag cuttingEasy-to-use torch trigger release and ergonomic handle provide comfort during long cutting sessionsLatch feature allows the cutting arc to remain active without constantly depressing the torch switch A favorite for use in heavy maintenance, fabrication and scrap metal. This machine delivers clean cuts on most 3/4" (19mm) metals including stainless steel, aluminum, mild steel, copper or brass, with minimum heat input and distortion of metal. Is also cuts through rusted, painted or coated surfaces without prior surface preparation. This inverter-based system operates on standard 230 volt, single or 3-phase power. Simply connect to an air compressor or other air source, and this system is ready to cut. Torch for excellent cutting results: this state-of-the-art torch provides the level of performance and features you would expect from a more expensive torch. Starts without high-frequency so it will not interfere with controls or computers. Precision-engineered consumable parts are easy to change and require no tools. Lightweight, flexible 20' (6.1m) torch leads. Full 1-year warranty on repair parts and labor. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Toothbrush Style Brass Brush - FPW1423-0084
3.26
3.26
Trim length: 1/2"3 x 7 rows. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Firepower Toothbrush Style Stainless Steel Brush - FPW1423-0081
4.97
4.97
Firepower Type 1 Bench Grinding Wheel, 6inch x 3/4inch , 36 Grit - FPW1423-2311
13.34
13.34
Wheels are individually precision balanced, trued and faced for smooth operationEach wheel is individually boxed so they stay clean and undamaged until useDesigned for versatile? off-hand grinding in deburring bar stock after cutting and touching up, reconditioning and sharpening tools where precision grinding is not requiredGrinding is done on the wheel periphery onlyAluminum oxide wheel grinds metal of high tensile strength, like steel and steel alloy. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Bench Grinding Wheel, 6inch x 3/4inch , 60 Grit - FPW1423-2310
14.11
14.11
Wheels are individually precision balanced, trued and faced for smooth operationEach wheel is individually boxed so they stay clean and undamaged until useDesigned for versatile? off-hand grinding in deburring barstock after cutting and touching up, reconditioning and sharpening tools where precision grinding is not requiredGrinding is done on the wheel periphery onlyAluminum oxide wheel grinds metal of high tensile strength, like steel and steel alloy. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Bench Grinding Wheel, 6inch x 3/4inch , 80 Grit - FPW1423-2312
14.11
14.11
Firepower Type 1 Chop Saw Abrasive Wheel, 12inch x 5/32inch x 1inch - FPW1423-3191
12.22
12.22
For portable high speed chop saws7" diameter wheels are equipped with Diamond Center hole for easy mounting on portable circular sawsMax. RPM: 6,300Grade: A36S 2.5FG. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Chop Saw Abrasive Wheel, 12inch x 5/32inch x 1inch - FPW1423-3193
15.06
15.06
For portable high speed chop saws7" diameter wheels are equipped with Diamond Center hole for easy mounting on portable circular sawsMax. RPM: 5,400Grade: A36S 2.5FG. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Cut Off Abrasive Wheels, 3? x 1/16? x 3/8? (5 Per Pack) - FPW1423-3155
10.78
10.78
Firepower Double Reinforced Cut-Off Wheels are designed for heavy duty cut-off jobs using circular saws, chop saws and straight grinding machinesThey ensure optimum effectiveness for dry applications on a broad range of ferrous and non-ferrous metals, soft ceramics, masonry materials, reinforced plastic and fiberglassMax. RPM: 25,000Grade: A46T2FG. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Cut Off Abrasive Wheels, 3? x 1/32? x 3/8? - FPW1423-3149
2.09
2.09
Firepower Double Reinforced Cut-Off Wheels are designed for heavy duty cut-off jobs using circular saws, chop saws and straight grinding machinesThey ensure optimum effectiveness for dry applications on a broad range of ferrous and non-ferrous metals, soft ceramics, masonry materials, reinforced plastic and fiberglassMax. RPM: 25,000Grade: A60T2FG. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Firepower Type 1 Cut Off Abrasive Wheels, 3? x 1/32? x 3/8? (10 per pack) - FPW1423-2230
19.33
19.33
Firepower Type 1 Cut Off Abrasive Wheels, 3? x 1/32? x 3/8? (5 per pack) - FPW1423-3181
10.69
10.69
Firepower Type 1 Cut Off Abrasive Wheels, 4? x 1/16? x 5/8? - FPW1423-3147
2.31
2.31
Firepower Type 1 Cut Off Abrasive Wheels, 4? x 1/32? x 3/8? - FPW1423-3150
2.39
2.39
Firepower Double Reinforced Cut-Off Wheels are designed for heavy duty cut-off jobs using circular saws, chop saws and straight grinding machinesThey ensure optimum effectiveness for dry applications on a broad range of ferrous and non-ferrous metals, soft ceramics, masonry materials, reinforced plastic and fiberglassMax. RPM: 18,000Grade: A60T2FG. Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Page (7 of 8)
3 4 5 6 7 8 |
