Buy "equus" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
Equus Pro Vacuum Gauge
22.95
22.95
The Equus Pro Vacuum Gauge features a large easy-to-read 3 dial face with a dual-calibrated and color-coded...
Equus Scan Tool CanOBD 2 and 1 Kit - EPI3140
324.59
324.59
Provides SAE enhanced Live Data - views, records, and plays back live PCM data streamsDesigned to retrieve diagnostic codes in all OBD2 (1996 and newer) and some of the most popular OBD1 (1981 to 1995) vehiclesOBD1 (82-95) Coverage GM, Ford, Chrysler/Jeep and Toyota/LexusCommunicates with all OBD 2 protocols: C.A.N. (Controller Area Network), ISO 9141, J1850PWM, J1850VPW, KWP 2000 ISO 14230-4Displays Freeze Frame Data The Equus line of scan tools provide the most diagnostic data and power for the money than any other line of scan tools!? It's patented "All-in-One" display shows 25 vital pieces of information at one time, and all within 15 seconds.? The 3140 can diagnose all OBD II compliant vehicle and most OBD I vehicles as well. This feature-packed tool and software kit is designed to meet the needs of professional technicians who desire quick and easy access to diagnostic data essentials for a wide range of vehicles.? Features unique patented all-in-one screen display and LED display for quick emissions check.? Includes Spanish and French Interface and Definitions (selected by a menu command).? Retrieves OBD2 DTCs: Generic Codes (P0, P2, P3, and U0 B0, and C0) / Manufacturer Specific Codes (P1, P3, and U1).? Unit can be flash updated with a standard Windows PC (OBD-PC Link software required / included with tool).? Memory / Battery backup for off-car review and analysis. OBD1 Coverage: General Motors - 1982 to 1993 and some 1994 to 1995 models excludes Saturn vehicles; Ford, Lincoln, Mercury - 1983 to 1995 models with EEC-IV Systems Performs: KOEO, KOER, Timing Check, Cylinder Balance Test, Output State Test, Wiggle Test; Toyota / Lexus - 1991 to 1995. Most models Chrysler / Dodge / Plymouth/Jeep - 1984 to 1995. Diesel trucks 1992-1995. Most Tools & Testers products are available for in-store pickup from Advance Auto Parts.
Equus Voltmeter Gauge
12.95
12.95
This meter 8 to 18 volt range Back-Lit illumination for night use Rear twist-on ring mount design makes...
Equus Water Temperature Gauge
21.95
21.95
This Water Temperature Gauge has a 90 degree sweep 130-280 degrees F/60-140 degrees C range. It has a...
Fuel Injection Pressure Tester by Equus
44.95
44.95
The Fuel Injection Pressure Tester by Equus has a large easy to read 2-1/2 inch dial face with 0-100...
iEquus Performance 1.5" Triple Gauge Kit
39.95
39.95
This compact triple gauge kit with Water Temperature Voltmeter and Oil Pressure boasts peak performance...
iEquus Performance 2" Oil Pressure Gauge
22.95
22.95
2 diameter white dial face 270 sweep 0 to 100 PSI / 0 to 70 kPa range Aluminum bezel is lightweight...
iEquus Performance 2" Triple Gauge Kit
49.95
49.95
This triple gauge kit with Water Temperature Voltmeter and Oil Pressure boasts peak performance & features...
iEquus Performance 2" Voltmeter
22.95
22.95
2 diameter white dial face ranges from 8 to 18 volts Aluminum bezel is lightweight and anodized to...
iEquus Performance 3 - 3/8" Tachometer
79.95
79.95
Super lightweight 3-3/8 tach features popular white dial face and aluminum anodized bezel to accentuate...
iEquus Performance 5" Shift Light Tachometer
114.95
114.95
Super lightweight 5 tach features popular white dial face and aluminum anodized bezel and popular shift...
Page (2 of 2)
1 2 |
