Buy "design engineering" online - search for the best price - compare prices
Page (7 of 13)
3 4 5 6 7 8 9 10 11 |
Design Engineering Heat Screen - 010401
62.99
62.99
Heat Screen offers an excellent way to reflect radiant heat away from a vehicle? s interior and because of its flexibility, can be trimmed-to-size to protect against excessive heat sources.Constructed of a high temperature resistant fiberglass material, and with a thickness of only .060", Heat Screen features a thermal barrier on one side made of a superior reflective aluminized mylar surface capable of withstanding direct heat up to 1200? F.Heat Screen can be used to protect areas where excessive heat can blister paint, where exhaust pipes run close to the fuel tank, and has many other applications including floorboards, body panels and under carpeting.A high temperature adhesive such as DEI? s Hi-Temp Spray Adhesive or Heat Resistant Sealant/Adhesive can be applied to secure Heat Screen or screws or rivets can be used. DEI? s Cool Tape is ideal for sealing and covering seams.Product Features:Aluminized surface reflects up to 2000? F radiant /1200? F direct /continuous heatMultitude of uses around race cars, boats, RV? s & trucksGreat protection for painted surfacesUsed in aviation and aerospace industry36" x 40" Aluminized Mylar Radiant Matting. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Heat Sheath - Aluminized Sleeving 1-1/2inch x 3' - 010420
21.99
21.99
Designed to slide over wires, cables and hoses, Heat Sheath provides the ultimate protection from extreme heat as well as chemical and oil spills, dirt, grease and road grime. Constructed from a high temperature fabric and bonded to an aluminized material to reflect heat. Heat Sheath is fireproof and withstands direct heat up to 500? F.Product Features:Pliable for tight bendsCapable of withstanding 500? F direct / 2000? F radiant heatTrim to desired lengthFive popular diameters to choose from. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Heat Sheath - Aluminized Sleeving 1-1/4inch x 3' - 010404
18.99
18.99
Designed to slide over wires, cables and hoses, Heat Sheath provides the ultimate protection from extreme heat as well as chemical and oil spills, dirt, grease and road grime. Constructed from a high temperature fabric and bonded to an aluminized material to reflect heat. Heat Sheath is fireproof and withstands direct heat up to 500? F.Product Features:Capable of withstanding 500? F direct / 2000? F radiant heatPliable for tight bendsTrim to desired lengthFive popular diameters to choose from. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Heat Sheath - Aluminized Sleeving 1/2inch x 3' - 010418
13.99
13.99
Design Engineering Heat Sheath - Aluminized Sleeving 1inch x 3' - 010419
17.99
17.99
Design Engineering Heat Sheath - Aluminized Sleeving 3/4inch x 3' - 010403
14.99
14.99
Design Engineering Heat Shroud - 010405
34.99
34.99
Heat Shroud is made from a high temperature rated glass fiber fabric with an aluminized outer facing. Same as Heat Sheath but with the added convenience of hook & loop closure design along the open edges. Without the need of removing one end of connected wires, cables and hoses, simply wrap Heat Shroud around whatever needs protection and close edges.Product Features:Versatility of fitting diameters ? " to 1-1/4"Convenient hook & loop designed edgesWithstands 500? F direct continuous/2000? F radiant heatNo need to remove wires and hosesEasily trimmed to lengthFireproof. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Heater Hotter - 040206
10.99
10.99
Heater Hotter formulated specifically to accelerate the transfer of heat from engine to cooling system in frigid climates that otherwise increase engine wear. Heater Hotter's unique formula allows your vehicle's heater to warm up 50% faster in even sub-zero temperatures and is safe to mix with all types of anti-freeze. Just simply add to your radiator.Product Features:Accelerates transfer of heat from engine to heaterImproves engine warm-up time by 50%Simply add to radiatorSafe with all types of anti-freezeHelps reduce engine wear. Most Radiator Additives & Flushes products are available for in-store pickup from Advance Auto Parts.
Design Engineering Hi-Temp Shrink Tubes - 9, 12, 18 & 24mm x 2' Each - 010836
23.99
23.99
Professional grade military spec flexible polyolefin tubing provides excellent electrical insulation, protection from dirt, dust, solvents, and foreign materials as well as providing strain relief. Over expanded tubing easily fits over the end of wires and connectors and shrinks down to 33% of it? s original diameter for a snug water-tight protective seal without a reduction in tube length.Hi-Temp Shrink Tubes can be used to insulate wires, wire splicing, connections, terminals and meets the material functional properties of Military Spec DTL-23053/5C.Product Features:Use to insulate wires, connections, terminals, wire splicing & more3:1 shrink ratioOperating temp range: -67? F to 275? FThick wall construction & remains flexibleMax Operating temp: 394? F for short duration (30 to 60 mins)Easy to install: Apply at 120 to 180? F using heat gunOffers clean professional lookMeets MIL Spec DTL-23053/5CFlame retardantAlternate to plastic ties & tape. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Hi-Temp Shrink Tubes - Wire Insulation - 12mm x 4' - 010833
11.99
11.99
Design Engineering Hi-Temp Shrink Tubes - Wire Insulation - 18mm x 4' - 010834
13.99
13.99
Design Engineering Hi-Temp Shrink Tubes - Wire Insulation - 24mm x 4' - 010835
14.99
14.99
Design Engineering Hi-Temp Shrink Tubes - Wire Insulation - 9mm x 4' - 010832
10.99
10.99
Design Engineering Hi-Temp Silicone Coating Spray - Aluminum - 010302
10.99
10.99
The High Temperature (HT) Silicone Coating provides lasting protection for any hot surface up to 1500 degrees. DEI recommend the use of this coating with their exhaust wrap because it seals the material and provides lasting protection from oil, dirt and road grime. Don't limit the use to exhaust header wrap, this products works well on headers, blocks, starters and even on your grill at home. HT Silicone Coating is VOC (Volatile Organic Compounds) compliant in all 50 states.Recommended for use with DEI non-Titanium exhaust wraps, HT Silicone Coating penetrates, seals and protects as well as helping to extend the lifespan of exhaust wrap.Product Features:Heat protection up to 1500? FPenetrates, seals, protects and prolongs the lifespan of exhaust wrap Protection from abrasions, hot oil spills & road grimeMany uses around the home and shop 12 oz. spray can. Most Paints & Enamels products are available for in-store pickup from Advance Auto Parts.
Design Engineering Hi-Temp Silicone Coating Spray - Black - 010301
10.99
10.99
Design Engineering Hub and Rotor Cover - 010485
53.99
53.99
Protection from hot brake drums and rotors.Product Features:Prevents potential of serious burns or cutsAluminized mylar adhered to fiberglass mattingWithstand 2000? F radiant / 500? F of direct continuous heatProtection against dirt, dust and airborne particles around track or shopMeasures 14" W x 7" D x 13" T. Most Brake Hardware products are available for in-store pickup from Advance Auto Parts.
Design Engineering INSLATR BOOT-TITANM - 010541
19.99
19.99
MPN #010541. Design Engineering INSLATR BOOT-TITANM. Most Spark Plug Boots & Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering INSLATR BOOT-TITANM - 010542
69.99
69.99
MPN #010542. Design Engineering INSLATR BOOT-TITANM. Most Spark Plug Boots & Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering INSULATOR BOOT-SLV - 010551
18.99
18.99
MPN #010551. Design Engineering INSULATOR BOOT-SLV. Most Spark Plug Boots & Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering INSULATOR BOOT-SLV - 010552
59.99
59.99
MPN #010552. Design Engineering INSULATOR BOOT-SLV. Most Spark Plug Boots & Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Leather Look Sound Barrier - 24inch X 48inch W (9 Sq. Ft.) - 050120
76.99
76.99
The new Leather Look Sound Barrier is an ideal way to reduce noise and have a premium leather appearance. Available in a moisture resistant, black leather embossed wear surface features a 1 lb./ft. 2 loaded barrier and is designed for insulating trunks, door panels, floors, speaker boxes and package shelves - any interior area of a vehicle where a leather appearance would provide a finishing touch. Can be permanently installed with Boom Mat Hi-Temp Spray Adhesive or used as temporary protection in trunk and floor areas.Function is equally important and the new Leather Look Sound Barrier is proven to significantly reduce incoming sounds caused by outside noise, troublesome rattles or squeaks, while providing a level of thermal insulation that lessens transfer of heat and cold in any climate.What's in it for you... Stylish finished appearance, Enhances stereo performance and sound, Maximum noise control, A quiet and comfortable interior, No mold or mildew issuesWhere to use: Headliner, Rear decks, Door skins, Trunk floors, Floor boards, Speaker boxes, Engine cover (dog house)Product Features:Embossed leather grainInsulate interior from unwanted heat & vibrationMoisture resistantFinishing touch for your interiorHeat resistant to 210? F5/16" thick. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Leather Look Sound Barrier - 48inch X 48inch W (18 Sq. Ft.) - 050121
155.99
155.99
Design Engineering Lite? N Boltz LED Accent Lighting - Amber - 030305
16.99
16.99
LED Lighted Button Head Bolts, with hex head opening, can be used anywhere accent lighting is desired. There are countless applications for accent lighting including hot rods, street rods, motorcycles, boats, ATVs, RVs, personal watercraft, pick up trucks, 4x4? s, 18-wheelers and even industrial applications.Map and gauge lights, indicator signals, step illumination, engine compartment lighting, running board, truck bed guard rails and dashboard accenting are just a few of the many uses for accent lighting.12-Volt Lighted Button Head Bolts contain two lights per package, measure 5/16" x 3/4" and are made from high grade stainless steel, polished to a mirror-like finish and available in six vibrant colors. 9/16" Outside diameter of button head. 4.5mm allen to install.Product Features:Made of high grade stainless steelEasy to install & unlimited uses!Use inside or outside vehicle. Most License Plate Frames products are available for in-store pickup from Advance Auto Parts.
Design Engineering Lite? N Boltz LED Accent Lighting - Blue - 030307
19.99
19.99
Design Engineering Lite? N Boltz LED Accent Lighting - Green - 030306
19.99
19.99
Page (7 of 13)
