Buy "design engineering" online - search for the best price - compare prices
Page (2 of 13)
1 2 3 4 5 6 |
Design Engineering Braided Hose - 080201
51.99
51.99
Product Features:14ft. 4an F x 4an F. Most Carbon Dioxide System Hoses products are available for in-store pickup from Advance Auto Parts.
Design Engineering Braided Hose - 080202
24.99
24.99
Product Features:2ft. 4an F x 1/8 npt male. Most Carbon Dioxide System Hoses products are available for in-store pickup from Advance Auto Parts.
Design Engineering Braided Hose - 080204
20.99
20.99
Stainless Steel braided lines with Teflon coreProduct Features:1ft. 4an F x 1/8 npt male4611 Working psi 12183 Burst psi. Most Carbon Dioxide System Hoses products are available for in-store pickup from Advance Auto Parts.
Design Engineering Braided Hose - 080205
29.99
29.99
Stainless Steel braided lines with Teflon coreProduct Features:3ft. 4an F x 1/8 npt male4611 Working psi 12183 Burst psi. Most Carbon Dioxide System Hoses products are available for in-store pickup from Advance Auto Parts.
Design Engineering Braided Hose - 080206
41.99
41.99
Stainless Steel braided lines with Teflon coreProduct Features:5ft. 4an F x 1/8 npt male4611 Working psi 12183 Burst psi. Most Carbon Dioxide System Hoses products are available for in-store pickup from Advance Auto Parts.
Design Engineering Cell Saver - Battery Insulation Kit - 010480
25.99
25.99
Batteries are very susceptible to heat and vibration that could cause premature failure and hazardous leaks. Cell Saver is very capable of damping vibration and will absorb and neutralize any damaging leaky battery acids. Cell Saver is easy to install and excess material can be trimmed to accommodate batteries of most sizes and shapes.Product Features:Protects batteries from harmful radiant heatMaterial withstands up to 2000? F radiant heatTraps and neutralizes harmful battery acidProtects environment and your vehicleCompletely safe to handle before and during installationProvides clean finished look with easy installationKit Includes: 40" long x 7" insulation material, 12" x 7" treated base mat, Edge sealing tape. Most Battery Accessories products are available for in-store pickup from Advance Auto Parts.
Design Engineering Chill Charger - 040208
10.99
10.99
Chill Charger for water-to-air intercoolers maximizes thermal transfer to lower air intake temperatures while also protecting core corrosion, electrolysis and harmful mineral build up. By effectively transferring water that circulates through the intercooler Chill Charger reduces liquid heat soak in high performance turbo and supercharger systems.Product Features:Prevents core corrosionPrevents electrolysisPrevents mineral build upMaximizes thermal transfer to lower air intake temperaturesSimply add to intercooler waterNon-toxic and environmentally friendly. Most Radiator Additives & Flushes products are available for in-store pickup from Advance Auto Parts.
Design Engineering Cool Cover - Air Tube Cover Kit - 010417
56.99
56.99
Cool Cover is designed to prevent air tubes from becoming heat sinks. Made of heat treated glass fiber with a reflective coating, Cool Cover will reflect radiant heat from air tubes and promotes a cooler, denser, more powerful air charge. With a unique full length hook & loop closure design, Cool Cover can be removed in seconds without the need of any hand tools!Product Features:Reflects heat from air tubesPromotes cooler air charge for added powerInstalls and removes in seconds for show or goFits up to 4-1/2" diameter tubingIncludes: 36" x 14" insulation material & 2" x 24" strip of heat reflective sealing tape. Most Heat & Sound Insulation products are available for in-store pickup from Advance Auto Parts.
Design Engineering Cool Tape 1-1/2inch x 15' - 010408
17.99
17.99
Cool Tape is a flexible and super strong self-adhesive thermal insulating tape capable of protecting up to 2000? F of radiant heat. Made of one mil aluminized material bonded to a woven glass fiber heat resistant matting, Cool Tape is a ultra light weight heat reflective solution for wrapping wires, cables, hoses, fuel lines, covering seams and many other uses.Product Features:Withstands direct heat up to 400? F and 2000? F radiant heatFlexible and easy to applyStrong self-adhesive backingUse to secure panels, seal air boxes, wrap wiring & more. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Cool Tape 1-1/2inch x 30' - 010416
29.99
29.99
Design Engineering Cool Tape 2inch x 60' - 010413
55.99
55.99
Design Engineering Cool Tube Extreme Black 1.25inch dia. X 3' - 010436
21.99
21.99
Able to reflect continuous heat up to 750? F while offering a quality profession look, Cool Tube Extreme is flexible enough to conform to tight bends and provide superior protection against extreme under hood temperatures, weather conditions and abrasions.Made from a special composite material with a spiral wire reinforced, Cool Tube Extreme is ultra-light that can be slit lengthwise to apply to cables, wires and hoses.Product Features:No need to remove wires, cables or hoses, Can be slit lengthwise for easy installReflects 750? F direct continuous heatEasily trim to lengthTough, durable with an easy to clean finishAvailable in 4 vivid colors5 available diameters. Most Exhaust Heat Shields products are available for in-store pickup from Advance Auto Parts.
Design Engineering Cool Tube Extreme Black 1.5inch dia. X 3' - 010440
24.99
24.99
Design Engineering Cool Tube Extreme Black 1/2inch dia. X 3' - 010424
18.99
18.99
Design Engineering Cool Tube Extreme Black 1/2inch dia. X 9' - 010444
38.99
38.99
Design Engineering Cool Tube Extreme Black 1inch dia. X 3' - 010432
18.99
18.99
Design Engineering Cool Tube Extreme Black 3/4inch dia. X 3' - 010428
15.99
15.99
Design Engineering Cool Tube Extreme Black 3/4inch dia. X 9' - 010448
47.99
47.99
Able to reflect continuous heat up to 750? F while offering a quality profession look, Cool Tube Extreme is flexible enough to conform to tight bends and provide superior protection against extreme under hood temperatures, weather conditions and abrasions.Made from a special composite material with a spiral wire reinforced, Cool Tube Extreme is ultra-light that can be slit lengthwise to apply to cables, wires and hoses.Product Features:No need to remove wires, cables or hoses, Can be slit lengthwise for easy installReflects 750? F direct continuous heatEasily trim to lengthTough, durable with an easy to clean finishAvailable in 4 vivid colors5 available diameters. Most Battery Accessories products are available for in-store pickup from Advance Auto Parts.
Design Engineering Cool Tube Extreme Blue 1.25inch dia. X 3' - 010435
24.99
24.99
Design Engineering Cool Tube Extreme Blue 1.5inch dia. X 3' - 010439
25.99
25.99
Design Engineering Cool Tube Extreme Blue 1/2inch dia. X 3' - 010423
19.99
19.99
Design Engineering Cool Tube Extreme Blue 1/2inch dia. X 9' - 010443
45.99
45.99
Design Engineering Cool Tube Extreme Blue 1inch dia. X 3' - 010431
25.99
25.99
Design Engineering Cool Tube Extreme Blue 3/4inch dia. X 3' - 010427
23.99
23.99
Design Engineering Cool Tube Extreme Blue 3/4inch dia. X 9' - 010447
47.99
47.99
Page (2 of 13)
1 2 3 4 5 6 |
