Buy "currie" online - search for the best price - compare prices
Page (17 of 21)
13 14 15 16 17 18 19 20 21 |
Currie Rear Bump Stop Kit CE-9122R Bump Stops
95.99
95.99
Rear Bump Stop Kit by Currie Enterprises Fits 1997 to 2006 TJ Wrangler, Rubicon and Unlimited;Urethane pucks;Billet aluminum spacers;For 4 lift Currie Rear Bump Stop Kit CE-9122R Bump Stops
Currie Rear Bump Stop Kit CE-9807RBSK Bump Stops
58.99
58.99
Rear Bump Stop Kit by Currie Enterprises for Jeep Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;For 4 inch suspension lift;2 billet aluminum spacers and hardware JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Bump Stop Kit CE-9807RBSK Bump Stops
58.99
58.99
Rear Bump Stop Kit by Currie Enterprises Bump Stop Kit; Rear; Incl. Billet Aluminum Spacers; Urethane Bump Stops; Hardware JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Bump Stop Kit CE-9807RBSK Bump Stops
58.99
58.99
Rear Bump Stop Kit Bump Stop Kit; Rear; Incl. Billet Aluminum Spacers; Urethane Bump Stops; Hardware Currie Rear Bump Stop Kit CE-9807RBSK Bump Stops
Currie Rear Coil Spring Retainer Kit CE-9807RRK Coil Spring Retainer
74.99
74.99
Rear Coil Spring Retainer Kit by Currie Enterprises for Jeep Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Prevents springs from popping out while off-road;Clamps springs to frame and housing JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Coil Spring Retainer Kit CE-9807RRK Coil Spring Retainer
74.99
74.99
Currie Enterprises Rear Coil Spring Retainer Kit Fits 2007 to 2012 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Prevents springs from popping out while off-road;Clamps springs to frame and housing JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Coil Spring Retainer Kit CE-9807RRK Coil Spring Retainer
74.99
74.99
Rear Coil Spring Retainer Kit by Currie Enterprises Fits 2007 to 2012 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Prevents springs from popping out while off-road;Clamps springs to frame and housing Currie Rear Coil Spring Retainer Kit CE-9807RRK Coil Spring Retainer
Currie Rear Long Travel Kit CE-9802R Complete Suspension Systems and Lift Kits
309.99
309.99
Rock Jock Rear Long Travel Kit by Currie Enterprises CE-9802R Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Semi-gloss black powder coat;2-1/4 coil spring spacers;Lower bump stop extensions;Stainless extended brake hose kit;Shocks sold separately;Max Tire Size: 33x12.50 JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Long Travel Kit CE-9802R Complete Suspension Systems and Lift Kits
Currie Rear Long Travel Kit CE-9802RE Complete Suspension Systems and Lift Kits
239.99
239.99
Rear Long Travel Kit by Currie Enterprises for Jeep Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Rear Lift Method:Top and Bottom Coil Spring Retainers;Kit includes: Lower bumpstop extentions,adjustable sway bar links with heim joints and jam nuts;Includes brake line extention brackets all necessary hardware and instructions;Max tire size 33";Requires long travel shocks (not included) JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Long Travel Kit CE-9802RE Complete Suspension Systems and Lift Kits
Currie Rear Lower Control Arms CE-9807RLA Control Arm
329.99
329.99
Rear Lower Control Arms by Currie Enterprises for Jeep Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Black powder coat;.625" o.d. x .250" wall d.o.m. control arms;2-1/2 Johnny Joint;Arms used in RockJock kits JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Lower Control Arms CE-9807RLA Control Arm
329.99
329.99
Rear Lower Control Arms by Currie Enterprises Fits 2007 to 2012 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Black powder coat;.625" o.d. x .250" wall d.o.m. control arms;2-1/2 Johnny Joint;Arms used in RockJock kits JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Lower Control Arms CE-9807RLA Control Arm
329.99
329.99
Rear Lower Control Arms by Currie Enterprises Fits 2007 to 2012 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Black powder coat;.625" o.d. x .250" wall d.o.m. control arms;2-1/2 Johnny Joint;Arms used in RockJock kits Currie Rear Lower Control Arms CE-9807RLA Control Arm
Currie Rear Lower Shock Mount Extensions CE-9601 Shock Absorber Relocation Bracket
34.99
34.99
Rear Lower Shock Mount Extensions by Currie Enterprises for Jeep Fits 1997 to 2006 TJ Wrangler, Rubicon and Unlimited;Black powder coat;Works on the rear of the Jeep;Moves shock away from coil spring cup;Sold as a pair JEEP WRANGLER (97-06LJ) WRANGLER (97-06TJ) 65TH ANNIVERSARY EDITION RUBICON SAHARA SE SPORT UNLIMITED UNLIMITED RUBICON X 1997 1998 1999 2000 2001 2002 2003 2004 2005 2006 2.4L Power-Tech (148) 2.5L (150) 4L Power Tech (242) GAS Currie Rear Lower Shock Mount Extensions CE-9601 Shock Absorber Relocation Bracket
34.99
34.99
Currie Enterprises Rear Lower Shock Mount Extensions Fits 1997 to 2006 TJ Wrangler, Rubicon and Unlimited;Black powder coat;Works on the rear of the Jeep;Moves shock away from coil spring cup;Sold as a pair JEEP WRANGLER (97-06LJ) WRANGLER (97-06TJ) 65TH ANNIVERSARY EDITION RUBICON SAHARA SE SPORT UNLIMITED UNLIMITED RUBICON X 1997 1998 1999 2000 2001 2002 2003 2004 2005 2006 2.4L Power-Tech (148) 2.5L (150) 4L Power Tech (242) GAS Currie Rear Lower Shock Mount Extensions CE-9601 Shock Absorber Relocation Bracket
34.99
34.99
Rear Lower Shock Mount Extensions by Currie Enterprises Fits 1997 to 2006 TJ Wrangler, Rubicon and Unlimited;Black powder coat;Works on the rear of the Jeep;Moves shock away from coil spring cup;Sold as a pair Currie Rear Lower Shock Mount Extensions CE-9601 Shock Absorber Relocation Bracket
Currie Rear Shackles CE-9034 Leaf Spring Shackle Kit
79.99
79.99
Rear Shackles by Currie Enterprises for Jeep Fits 1976 to 1986 CJ;1/4" thick steel side plates;Grade 8 1/2" greasable bolts;Urethane bushings;Center bar for added rigidity JEEP CJ5 CJ7 SCRAMBLER 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 2.5L (150) 2.5L Iron Duke LX8 (151) 3.8L (232) 4.2L (258) 5L (304) GAS Currie Rear Shackles CE-9034 Leaf Spring Shackle Kit
79.99
79.99
Rear Shackles by Currie Enterprises Fits 1976 to 1986 CJ;1/4" thick steel side plates;Grade 8 1/2" greasable bolts;Urethane bushings;Center bar for added rigidity JEEP CJ5 CJ7 SCRAMBLER 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 2.5L (150) 2.5L Iron Duke LX8 (151) 3.8L (232) 4.2L (258) 5L (304) GAS Currie Rear Shackles CE-9034 Leaf Spring Shackle Kit
79.99
79.99
Rear Shackles by Currie Enterprises Fits 1976 to 1986 CJ;1/4" thick steel side plates;Grade 8 1/2" greasable bolts;Urethane bushings;Center bar for added rigidity Currie Rear Shackles CE-9034 Leaf Spring Shackle Kit
Currie Rear Shackles CE-9039 Leaf Spring Shackle Kit
79.99
79.99
Rear Shackles by Currie Enterprises for Jeep Fits 1987 to 1995 YJ Wrangler;1/4" thick steel side plates;Grade 8 1/2" greasable bolts;Urethane bushings JEEP WRANGLER (87-95YJ) ISLANDER LAREDO RENEGADE RIO GRANDE S SAHARA SE SPORT 1987 1988 1989 1990 1991 1992 1993 1994 1995 2.5L (150) 4.2L (258) 4L Power Tech (242) GAS Currie Rear Shackles CE-9039 Leaf Spring Shackle Kit
79.99
79.99
Currie Enterprises Heavy Duty Rear Shackles Fits 1987 to 1995 YJ Wrangler;1/4" thick steel side plates;Grade 8 1/2" greasable bolts;Urethane bushings JEEP WRANGLER (87-95YJ) ISLANDER LAREDO RENEGADE RIO GRANDE S SAHARA SE SPORT 1987 1988 1989 1990 1991 1992 1993 1994 1995 2.5L (150) 4.2L (258) 4L Power Tech (242) GAS Currie Rear Shackles CE-9039 Leaf Spring Shackle Kit
79.99
79.99
Rear Shackles by Currie Enterprises Fits 1987 to 1995 YJ Wrangler;1/4" thick steel side plates;Grade 8 1/2" greasable bolts;Urethane bushings Currie Rear Shackles CE-9039 Leaf Spring Shackle Kit
Currie Rear Shackles for Pro Comp Springs CE-9039P Leaf Spring Shackle Kit
79.99
79.99
Rear Shackles for Pro Comp Springs by Currie Enterprises for Jeep Fits 1987 to 1995 YJ Wrangler;1/4" thick steel side plates;Grade 8, 1/2" greasable bolts;Urethane bushings for Pro Comp springs JEEP WRANGLER (87-95YJ) ISLANDER LAREDO RENEGADE RIO GRANDE S SAHARA SE SPORT 1987 1988 1989 1990 1991 1992 1993 1994 1995 2.5L (150) 4.2L (258) 4L Power Tech (242) GAS Currie Rear Shackles for Pro Comp Springs CE-9039P Leaf Spring Shackle Kit
79.99
79.99
Standard Rear Shackles For Pro Comp Springs Fits 1987 to 1995 YJ Wrangler;1/4" thick steel side plates;Grade 8, 1/2" greasable bolts;Urethane bushings for Pro Comp springs JEEP WRANGLER (87-95YJ) ISLANDER LAREDO RENEGADE RIO GRANDE S SAHARA SE SPORT 1987 1988 1989 1990 1991 1992 1993 1994 1995 2.5L (150) 4.2L (258) 4L Power Tech (242) GAS Currie Rear Shackles for Pro Comp Springs CE-9039P Leaf Spring Shackle Kit
79.99
79.99
Rear Shackles for Pro Comp Springs by Currie Enterprises Fits 1987 to 1995 YJ Wrangler;1/4" thick steel side plates;Grade 8, 1/2" greasable bolts;Urethane bushings for Pro Comp springs Currie Rear Shackles for Pro Comp Springs CE-9039P Leaf Spring Shackle Kit
Currie Rear Shock Relocator Kit CE-9807RSRK Shock Absorber Relocation Bracket
26.99
26.99
Rear Shock Relocator Kit by Currie Enterprises for Jeep Fits 2007 to 2013 JK Wrangler, Rubicon and Unlimited;2 and 4-door models;Relocates rear shocks outboard of original location;Kit includes: Spacers for shock relocation, all necessary grade 8 hardware,complete instructions;Sold as a pair JEEP WRANGLER (07-13JK) ISLANDER MOUNTAIN RUBICON SAHARA SPORT UNLIMITED ISLANDER UNLIMITED MOUNTAIN UNLIMITED RUBICON UNLIMITED SAHARA UNLIMITED SPORT UNLIMITED X X 2007 2008 2009 2010 2013 3.6L (220) 3.8L (231) GAS Currie Rear Shock Relocator Kit CE-9807RSRK Shock Absorber Relocation Bracket
Page (17 of 21)
