Buy "chicago pneumatic" online - search for the best price - compare prices
Page (6 of 6)
2 3 4 5 6 |
Chicago Pneumatic Straight Line Sander - CPT7268
154.79
154.79
Powerful Twin Piston motor for balanced 3000 1" strokes per minuteCompact and lightweight at 6 lbs.CP exclusive pinch guard to protect operatorEasy comfort trigger and handleEasy attach abrasive clamps to make replacement a snap Dual piston straight line sander with all the power, performance and durability needed for your sanding requirements. 2-3/4" x 17-1/2" cushioned pad, great for shaping and smoothing of body filler. Has the power to prevent stalling during heavy material removal. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Super Duty Air Hammer - CPT717
796.00
796.00
Most powerful CP air hammer for automotive, truck and off road equipmentPositive action trigger for precise control1,800 blows per minute.498" diameter chisel shank to handle the extra power Applications: front end work, king pin removal, removal and installation of bulldozer walking beams, removal of truck springs and heavy-duty spring bushings.? Stroke: 2.69"; average air consumption: 3.13 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 95; length: 9.75"; weight: 4.75 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Super Duty Reciprocating Air Saw - CPT7901
190.99
190.99
Power at 10,000 strokes per minute allows you to quickly cut through material with easeLock off throttle for protection against accidental start upsLowest vibration on marketAdjustable guide offers flexibility in setting depth of cutErgonomic design for comfort and easy handling. This premium cutting tool offers exceptional value while providing increased comfort, performance and durability. Premium tool for body, exhaust and muffler work. Blade guide for added blade life. Rear exhaust directs air away from work piece.? Applications: cutting aluminum, plastic, fiberglass, wood, and sheet metal up to 16 gauge. Strokes per minute: 10,000; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 88; length: 9"; weight: 1.9 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Super Duty Reciprocating Air Saw Kit - CPT7901K
267.79
267.79
This heavy duty kit includes CP's 7901 reciprocating saw plus (5) each replacement blades: 18T, 24T, 32T packed in a heavy duty carrying caseLowest vibration on the market to reduce operator fatigue and ensure accurate cuttingPower at 10,000 strokes per minute allows you to cut through material with easeAdjustable guard/guide allows operator to set depth of cutErgonomic design for comfort and easy handling This premium cutting tool offers exceptional value while providing increased comfort, performance and durability. Premium tool for body, exhaust and muffler work. Blade guide for added blade life. Rear exhaust directs air away from work piece.? Applications: cutting aluminum, plastic, fiberglass, wood, and sheet metal up to 16 gauge. Strokes per minute: 10,000; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 88; length: 9"; weight: 1.9 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic TUNE UP KIT - CPTCA131501
78.79
78.79
Oil bath clutch for smooth operation and extended durabilityOne hand push button forward/reverse power regulator - 3 positive power settings in forward and ultimate power in reverseMaximum torque: 1,700 ft./lbs.Adjustable side handle for supportIdeal for spring work, tractor pad removal and off road equipment. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Tune-Up Kit for CPT734 - CPTCA051511
38.09
38.09
Chicago Pneumatic TUNE-UP KIT NS - CPTCA145228
110.19
110.19
Heavy Duty Zip Gun Air Hammer
414.95
414.95
Most controllable CP Hammer available. Ideal for complete body shop work. Positive action trigger...
Smart Mini Air Disc Sander/Surface Prep Kit - 3"
139.95
139.95
Small Area Repair Tools SMART are designed to get the job done faster. 15000 RPM 1/4 HP air motor ...
Page (6 of 6)
2 3 4 5 6 |
