Buy "chicago pneumatic" online - search for the best price - compare prices
Page (4 of 6)
1 2 3 4 5 6 |
Chicago Pneumatic 7inch Vertical Air Polisher - CPT865P
343.59
343.59
Rugged 1 hp motorAutomatic release trigger with positive stop action"Flex-edge" polishing pad to help eliminate scorching Muffled handle exhaustIdeal for buffing and polishing paint, metal, wood or plastic to a smooth, flawless finish Pad size diameter: 8"; free speed: 2500 rpm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 91; weight: 4.5 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 90 Degree Angle Head Heavy Duty Air Die Grinder - CPT862
168.97
168.97
90 degree angle head for easy accessibilityInsulated grip for greater comfortAdjustable speed regulator for precise controlLock off throttle to prevent accidental start upExcellent for blending, smoothing, porting, and deburring in confined areas Fine grinding and detail work is easily accomplished with this 90 degree? die grinder.? Also works great with 3M brand Scotch-Brite disks for removing old gaskets and old paint. Collet size: 1/4"; free speed: 22,000 RPM; average air consumption: 5.3 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 92; length: 6.19"; weight: 1.13 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 90 Degree Mini Air Die Grinder - CPT7562
118.99
118.99
Powerful .25HP High Performance Motor for power in all types of grinding conditionsCompact size with insulated handle grip for added comfort in all conditions23,000 RPM of Maximum SpeedEasy Access Speed Regulator for precise power controlRear Exhaust keeps air away from work area90 Degree Mini Die Grinder with Insulated Handle Grip, Powerful .25 HP High Performance Motor and 23,000 RPM of Maximum Speed. Also features easy access speed regulator, rear exhaust and lock off throttle.? Collet size: 1/4"; Air inlet: 1/4". Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Angle Polisher - CPT869P
317.99
317.99
"Flex-head" polishing pad to help eliminate scorchingBuilt-in air regulator adjusts speedMuffled rear exhaustHardened and ground spiral bevel gears for low vibration and long lifeExcellent for buffing and polishing flat and contoured surfaces Pad size diameter: 8"; free speed: 2500 RPM; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 102; weight: 6.5 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Cover For CPT749 - CPTCA155537
15.59
15.59
Oil bath clutch for smooth operation and extended durabilityOne hand push button forward/reverse power regulator - 3 positive power settings in forward and ultimate power in reverseMaximum torque: 1,700 ft./lbs.Adjustable side handle for supportIdeal for spring work, tractor pad removal and off road equipment. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Dual Action Sander - CPT870
81.79
81.79
Rotary and orbital motion for rapid removal as well as fine finishing Power regulator for precise controlLock off throttle to prevent accidental start upsInsulated grip provides comfort to operatorExcellent for blending and smoothing filler, feather edging and pre-paint preparation Pad size diameter: 6"; free speed: 10,000 RPM; average air consumption: 8 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 85; weight: 4.25 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Engraving Pen - CPT710
90.99
90.99
Lightweight for easy operationFine point stylus for precise engravingCushion finger grip for comfortLow air consumption at only 1 CFM14,000 blows per minute This engraving pen is lightweight at only 1-1/4 lbs.? With precise engraving, this pen makes a great gift!. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic GASKET 722 N - CPTCA145967
5.09
5.09
Chicago Pneumatic General Purpose Needle Scaler - CPT7120
228.59
228.59
Ideal for surface preparation workAdjustable sleeve to fit protrusion of the needles to the task to be performed19-1/8" steel needles with high resistance to wearEasily converts to chisel scaler4,600 BPMS. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic GRIP RUBBER 719 - CPTCA157228
12.69
12.69
Chicago Pneumatic HEAD HOUSING 86 - CPTCA157569
36.69
36.69
Chicago Pneumatic HEAD KIT 826 - CPTCA155034
74.29
74.29
Chicago Pneumatic HEAD KIT FOR 83 - CPTCA155084
69.19
69.19
Chicago Pneumatic HEAD REPAIR KIT - CPTCA157872
33.39
33.39
Chicago Pneumatic Heavy Duty Air Die Grinder - CPT860
165.79
165.79
Rugged, energy-efficient 1/2 hp motorAdjustable power regulator for precise controlLock off throttle to prevent accidental start upsSquare handle design for positive gripExcellent for cleaning tire moldings, porting and relieving engines, and general high-speed polishing and grinding Built-in regulator matches speed to job. Rear exhaust directs air away from work. Complete with 1/4" and 6mm collet. Free speed: 24,000 rpm; air consumption: 5.25 CFM; Air inlet thread: 1/4" NPTF; minimum hose size: 3/8 in.; sound dBA pressure: 93; length: 5.75; weight: 1.25 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy Duty Air Hammer Kit - CPT7110K
127.79
127.79
Features & Benefits: Powerful, yet economical for fast cutting actionIncludes (1) quick change retainer, (4) chisels, and heavy duty carrying caseVibration isolation system for smoother operation and greater comfortUnique cushioned exhaust deflector on barrel for comfort and controlTouch trigger for precision start ups and total control Ideal for exhaust system work, bolt cutting, bushing driving, shearing and front end work.? Shank: .401. Average air consumption: 3.65 cfm. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy Duty Air Nibbler - CPT835
315.69
315.69
Rugged nibbling head and .177" diameter punch cuts steel up to .060" (16 gauge) and aluminum up to .102" (10 gauge).Easy access to punch and die for quick replacement Four optional cutting positions Perfect for accurate cutting of steel and aluminumBest for tight corners and circles Possible to place die in four different cutting positions. 2,750 strokes per minute; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 97; length: 7.5"; weight: 2.25 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy Duty Air Reciprocating Saw - CPT881
336.79
336.79
Heavy duty construction for long life under heavy useAdjustable guard/guide allows operator to set depth of cutErgonomic rubber grip that provides operator comfort Lock off throttle to prevent accidental start ups Ideal for cutting aluminum, plastics, fiberglass and sheet metal up to 16 gauge Strokes per minutes: 9500; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 98; length: 8.63; weight: 1.63 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy Duty Air Shear - CPT785S
285.79
285.79
Powerful, energy efficient 1/2 horsepower motorTriple idler planetary gearing for smooth operation and extended tool lifeErgonomic handle design for operator comfort Heavy duty shear head provides long life and reliable cutting performance up to 18 gauge steelIdeal for cutting squares and angles in materials such as aluminum, tin and steel Strokes per minute: 2400; air inlet thread: 1/4"; minimum hose size: 3/8"; sound dBA: 94; length: 8.25"; weight: 2.5 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy Duty High Speed Cut-Off Tool - CPT861
174.99
174.99
Rugged, energy-efficient 1/2 hp motorLightweight-only 1-5/8 lbs.Square handle design for positive gripExcellent for cutting through sheet metal, fiberglass, bolts, muffler clamps and pipe hangersAlso used to grind down burrs and rough edges Cut through steel parts fast and without flames. Remove old exhaust? parts, rusted clamps and brackets without the risk of burning nearby plastic or paint. Rear exhaust directs air away from work. Chuck size: 2-7/8"; free speed: 20,000 RPM; average air consumption: 8.5 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 89; length; 7.75"; weight: 1.63 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy Duty Reciprocating Air Saw - CPT7900
142.59
142.59
Power at 10,000 strokes per minute allows you to quickly cut through material with easeAdjustable guard/guide allows operator to set depth of cutErgonomic design for comfort and easy handling and muffler workIncludes (1) each replacement blades: 18T, 28T, 32TEconomical tool for body, exhaust and muffler work This tool features a lock off throttle for protection against accidental start ups and an adjustable guide offers flexibility in setting depth of cut. Rear exhaust directs air away from the work area, while an ergonomic design increases comfort and handling. This tool offers the lowest vibration on the market. Strokes per minute: 10,000; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 92; length: 8.5"; weight: 1.3 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy-Duty Air Hammer - CPT715
73.70
73.70
Most powerful hammer in its classLonger piston strokes for more force per blow Integral muffler minimizes exhaust soundIdeal for bolt and rivet shearing, bushing driving and overall front end work 2,100 blows per minute Impact parts heat-treated for durability. Ergonomic handle for added operator comfort. Muffler and pipe removal, body shop work, shock work, scraping rust, and light front-end work. Shank: .401; bore: 3/4"; stroke: 3.5"; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 109; average air consumption: 3.5 cfm. Hammer weighs 4.5 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy-Duty Air Hammer Kit - CPT715K
96.89
96.89
Most powerful hammer in its class? Longer piston strokes for more force per blow Integral muffler minimizes exhaust sound? Ideal for bolt and rivet shearing, bushing driving and overall front end work Includes 4 chisels and a blow molded case Tool is specifically designed for body shop applications, tire shops and general vehicle repair.? Shank size: .401; bore: 3/4"; blows per minute @ 90 PSI: 2,100 average air consumption: 3.5 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 109. Weight of air hammer is 4.5 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic Heavy-Duty Air Orbital Sander - CPT777
241.26
241.26
Balanced counterweight design Patented, non-rotating gear housing makes tool easy to handle Smooth strength and power for shaping, blending and smoothing body filler and rapid material removal Positive rotation with oscillating action prolongs abrasive life. Circular exhaust diffuses air flow. Free speed: 900 rpm.; Pad size: 8 in.; Weight: 4-1/4 lb.; Average air consumption: 5 CFM; Air inlet NPTF: 1/4"; Minimum hose size: 3/8"; Sound dba pressure (power): 97. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic High Speed Tire Buffer - CPT871
90.79
90.79
Built-in regulatorJacob? s chuck for holding buffing accessoriesLock off throttle to prevent accidental start upsRear exhaust directs air away from the work areaIdeal for patchwork, roughing areas for recapping and cleaning tire moldings Wheel size: 3/8"; free speed: 22,000 RPM; length: 8"; weight: 1.75 lbs.; average air consumption: 13 cfm; air inlet thread: 1/4" NPT; minimum hose size: 3/8"; sound dBA: 99; length: 8"; weight: 1.75 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Page (4 of 6)
1 2 3 4 5 6 |
