Buy "chicago pneumatic" online - search for the best price - compare prices
Page (3 of 6)
1 2 3 4 5 6 |
Chicago Pneumatic 3/8inch Drive 12 Volt Cordless Impact Wrench Kit - CPT8738L
527.69
527.69
Smallest 3/8" cordless impact wrench in the industry gets into the tightest spots and weighs only 3.5 lbs.LED guide light comes on before the tool, premium trigger switch for long trouble free operation"Rubber over the Mold" on the tool and battery for comfort, slip resistance, and battery protectionCP has the only vented Li-Ion batteries to keep the tool cooler under extreme conditionsOne hand forward/reverse with feather trigger for better control This cordless impact wrench is the smallest and lightest on the market. The impact wrench features aluminum clutch housing, CP DuoPac clutch for strong smooth operation, impact resistant composite housing, easy touch forward/reverse, chemical resistant rubber over molded grip, Easy Connect sliding battery system and chemical resistant protective rubber over molded battery for slip resistance and drop protection. Maximum torque: 95 ft./lbs.; free speed; 2,400 RPM; length: 6.7". Universal charger has a Smart system to check battery performance and connector protection. With a one hour charge, charger works with 10.8 V to 19.2 V CP Ni-Cd, Ni-MH and Lithium Ion batteries. Works on 110VDC/240VAC. Kit includes impact wrench, (2) Li-Ion batteries and 1 universal charger. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive 12 Volt Cordless Impact Wrench, Drill and Light Kit - CPT8738KL
675.69
675.69
Smallest 3/8" cordless impact wrench in the industry gets into the tightest spots and weighs only 3.5 lbs.3/8" drill with locking industrial Jacobs chuck for secure bit connection2 vented Lithium Ion 12 volt batteries for extended use and comfort; batteries have a fuel gaugeUniversal charger does all CP batteries in less than one hour with Ni-Cad refresh abd overcharge protectionHigh output LED pivotal work light with hanging hook that last for 16 hours This very popular cordless kit is the smallest and lightest on the market. The impact wrench features aluminum clutch housing, CP DuoPac clutch for strong smooth operation, impact resistant composite housing, easy touch forward/reverse, chemical resistant rubber over molded grip, LED guide light comes on before the tool, premium trigger switch for long trouble free operation; Easy Connect sliding battery system and chemical resistant protective rubber over molded battery for slip resistance and drop protection. Maximum torque: 95 ft./lbs.; free speed; 2,400 RPM; length: 6.7". The 3/8" cordless drill has many features: aluminum clutch housing, impact resistant housing, two speed motor, premium trigger switch for long trouble free operation, easy connect sliding battery system, chemical resistant protective rubber over molded battery for slip resistance and drop protection, and a vented Li-Ion battery pack for care free extended use. Maximum torque: 300 in./lbs.; free speed: 0-360 RPM; weight: 4.3 lbs.; length: 9.2". Universal charger has a Smart system to check battery performance and connector protection. With a one hour charge, charger works with 10.8 V to 19.2 V CP Ni-Cd, Ni-MH and Lithium Ion batteries. Works on 110VDC/240VAC. LED work light features a 160 degree pivotal head, a built in hanger for hands free operation, LED light that lasts 16 hours with one battery charge and has an ergonomically superior balance and grip. Length: 11.3". Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Butterfly Impact Wrench - CPT7722
190.69
190.69
90 ft./lbs. of ultimate torqueRocking dog clutch for smooth operation and extreme durabilityEasy maneuvering with 360 degree swivel air inletBuilt in regulator for controlled torqueButterfly throttle for comfort and control This butterfly impact wrench features durable aluminum body housing and is strongest in its class. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive General Duty Impact Wrench - CPT727
255.59
255.59
Durable clutch mechanism for smooth operation and longer lifeComfortable ergonomic handle designHandle exhaust with 360 degree air inlet swivel to prevent hose kinksIdeal for transmission work, exhaust systems, body shops and general repair in 3/8" applications Working Torque Range 40-150 ft/lbs. Features a durable clutch mechanism for longer life and a positive action trigger for precise control.? The handle exhaust directs air away from the work piece and operator, while the contoured elastomer handle grip provides improved comfort and ergonomics. Maximum torque: 180 ft.-lbs.; blows per minute: 1800; free speed: 6800 RPM; average air consumption: 3 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 95. Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Heavy Duty Air Impact Wrench - CPT721
259.99
259.99
Rocking dog clutch with oil lubrication for long life and durabilityEnergy efficient motor for maximum performanceGreat tool for small engine repair, bench work and transmissionPistol-type grip with ergonomically designed handle for less fatigueFree speed: 11,000 RPM Built-in power regulator. Working torque: 5-50 ft./lbs.; maximum torque: 75 ft.-lbs.; blows per minute: 1620; average air consumption: 2.5 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 84.1; Weight: 2.63 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Heavy Duty Air Ratchet Kit - CPT828K
184.99
184.99
Features CP's new anti-slip head design which virtually eliminates slippage while reducing the potential for heat build-up, even in long run downsCompact, yet packed with power and speedEfficient 112 hp motor provides up to 50 ft./lb. of torqueAdvanced head design provides dramatically longer lifeIncludes 5 sockets, flashlight and blow molded case Teasing throttle for precise speed control. Applications: exhaust systems, all engines water pumps, fuel pumps, radiators etc.? Ergonomic square-handle design for a positive, comfortable grip. Working torque: 10-50 ft./lbs.; maximum torque: 50 ft./lbs.; free speed: 150 RPM; average air consumption: 3.75 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 96.5; length: 10"; weight: 2.4 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Heavy Duty Butterfly Impact Wrench - CPT722
216.59
216.59
? Rocking dog clutch for smooth operation and extreme durabilityEasy maneuvering with 360 degree air inlet swivelButterfly throttle for comfort and controlStreamline housing for greater access into tight areasApplications: bench work, carburetors, ignitions, body panels, transmissions, fender struts, oil pans, and small engine work Working torque: 5-50 ft./lbs.; maximum torque: 75 ft./lbs.; free speed: 9500 RPM; average air consumption: 2.25 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 86.3; length: 7.25 in.; weight: 2 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Heavy Duty Impact Wrench - CPT724H
212.29
212.29
DYNA-PACT oil bath clutch delivers smooth operation and extended durabilityOne hand push button forward/reverse power regulator4 positive power settings.? Full power in reverseHandle exhaust directs air away from the workpiece and operator360 degree air inlet swivel keeps air hose from being twisted and kinked Power and economy for general repair, transmission work, exhaust systems and body shops. Working torque: 40-170 ft./lbs.; maximum torque: 200 ft./bs.; blows per minute: 1680; free speed: 8500 RPM; average air consumption: 3 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 93; length: 6"; weight: 3.1 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Heavy Duty Ratchet - CPT828
148.89
148.89
CP's anti-slip head design which virtually eliminates slippage while reducing the potential for heat build-up, even in long run downsCompact, yet packed with power and speed. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Impact Wrench - CPT7735
290.99
290.99
300 ft./lbs. of ultimate torqueTwin hammer clutch with Mg Driven Technology for superior torque and reliabilityEasy one handed push button forward and reverseComposite handle for strong durability and less weight3 position power setting regulator in forward and full power reverse for maximum control Weighing only 2.5 lbs., this impact wrench is compact and lightweight. Handle exhaust with 360 degree air inlet swivel to prevent hose kinks. Free speed: 10,000 RPM. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Standard Duty Air Ratchet - Black Handle - CPT826T
232.09
232.09
Exceptional durability with an advanced head design that virtually eliminates slippage Urethane grip for comfort and control? Extended length - designed for greater reach in confined areas? ? Faster rundown with 250 RPMS? Excellent for under-dashboard work, small engine repair and body shops New improved head design reduces premature wear and eliminates slips. Working torque: 5-12 ft./lbs.; maximum torque: 15 ft./lbs.; free speed: 250 RPM; average air consumption: 3.5 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 90.5; length: 8"; weight: 1.13 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Standard Duty Air Ratchet - CPT824T
105.29
105.29
Easy speed control throughout rangeExtended length - designed for greater reach in confined areasCompact and lightweightExcellent for under-dashboard work, small engine repair and small fastenersEconomic design for a more productive use This standard duty air rachet's? working torque: 5-12 ft./lbs.; maximum torque: 12.5 ft./lbs.; free speed: 220 RPM; average air consumption: 3.75 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 90.4; extended length: 7-3/4" - designed for greater reach in confined areas. Weight: 1-1/8 lb. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Standard Duty Air Ratchet - CPT825T
165.29
165.29
Convenient forward/reverse button for one finger directional changes? ? Compact and lightweight with a square handle design for a positive gripEasy speed control throughout the rangeMaximum rundown speed of 200 RPMExcellent for under-dashboard work, small engine repair and small fasteners, compact/lightweight, ideal for confined working conditions This air ratchet features a working torque range of 5-12 ft./lbs. with a maximum torque of 15 ft./lbs.; maximum torque: 15 ft./lbs.; free speed: 200 RPM; average air consumption: 2.75 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 87; length: 6.5"; weight: 1.88 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Standard Duty Air Ratchet - CPT886
99.09
99.09
Compact head design allows greater flexibility in tight areasEasy to grip reverse lever for simple directional changesHardened gears provide greater durability over other economically priced ratchetsIdeal for installing or removing spark plug sockets, radiators, water pumps and exhaust systems. Working torque: 10-50 ft./lbs.; maximum torque: 50 ft./lbs.; free speed: 160 RPM; average air consumption: 4.25 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 98.2; length: 10.25"; weight: 2.63 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Drive Super Duty ? Quiet? Air Ratchet - CPT7830Q
259.99
259.99
Adjustable exhaust, sound level - as low as 79 dBaHighest torque on the market: 90 ft./lbs.Rubber handled gripFeatures CP's patented TriSpringLightweight and well balanced tool Also features durability and comfort with ratchet head protection. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch High Speed Quiet Ratchet Promo Kit - CPT7828P
159.99
159.99
Quiet operationCompact, yet packed with power and speed - 60 ft./lbs. maximum torqueFeatures CP's patented TRISPRING anti-slip head design which virtually eliminates slippageEasy touch variable speed trigger for speed control on all types of workComes with 1 pair of CP Precision Mechanics gloves and 1 CP racing knife360 degree adjustable low noise exhaust system - reduced noise levels for more comfortable working environment. Working torque: 5-50 ft./lbs.; free speed: 240 RPM; average air consumption: 4 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 87.5; length: 10.75"; weight: 2.75 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 3/8inch Super Heavy Duty Air Ratchet Kit - CPT7830K
213.08
213.08
CP's new high powered ratchet offers the most torque at 90 ft./lbs.Aircraft quality aluminum for lightweight durability and great balanceOnly weighs 2.7 lbs.Features CP's new anti-slip head design which virtually eliminates slippage while reducing the potential for heat build up, even in long run downsIncludes sockets, flashlight and is packaged in a blow molded case Premium tool for brake work, transmission and engine work when you need extra torque.? Working torque range: 10-90 ft./lbs.; free speed: 190 RPM; average air consumption: 4.63 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 92; length: 12"; weight: 2.7 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 4inch Heavy Duty Air Angle Grinder - CPT854
353.39
353.39
Powerful .6 hp high performance motor for fast, efficient grinding in tight quartersAluminum alloy housing is rugged yet lightweight for maximum operator comfortSpiral bevel gearing in angle head provides extended life and smooth low vibrationRemovable dead handle allows access to tight quarter workApplications: weld preparation and smoothing; rust removal; deburring and blending of steel, cast iron, and aluminum Spindle size; 3/8"-24; 4" wheel size; free speed: 12,000 RPM; average air consumption: 6 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 85; length: 9"; weight: 3.75 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 5inch Air Angle Grinder - CPT7554
301.99
301.99
Powerful .7 HP High Performance Motor provides power in all types of grinding conditions5/8" - 11 Spindle - same disc size as present electric grinders12,000 RPM maximum free speed gets the job done fastSpiral Bevel Gearing makes the tool run smoother and last longerCompact size Other features include spiral bevel gearing, one piece aluminum housing, speed regulator, lock off throttle and full 180 degree safety guard. Free speed: 12,000 RPM; average air consumption: 6 cfm; air inlet thread: 1/4"; length: 9.05"; weight: 3.9 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 6inch Heavy Duty Random Orbital Air Sander - CPT864
165.49
165.49
Rotary and orbital motion for rapid removal as well as fine finishingSure-grip insulated handleCrossbolt-style hub mounting minimizes vibrationCircular exhaust diffuses air flowIdeal for blending and smoothing filler, feather edging and pre paint preparation Pad size diameter: 6"; average air consumption: 8 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 86. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 6inch Premium Random Orbital Sander - CPT7215
201.49
201.49
Powerful .21 HP (160w) motor for tough jobsMaximum free speed: 12,000 RPMWeighs 1.59 lbs. - lightest in the industryTear drop handle for great controlLow vibration: less than 2.5 m/s2This random orbital sander features 3/8" orbit for heavy sanding. With comfort contoured handle with great speed control. CP noise control muffler minimizes sound levels. Chemical and impact resistant composite housing. Easy access speed control. Premium CP low vibration pads available in PSA or Hook and Loop 6 hole; vacuum or no-hole non-vacuum. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 6inch Random Orbital Sander - CPT7250
240.99
240.99
5mm orbit for high quality finishingEasy to handle, compact and lightweight, providing best power to weight ratio in its class0.3 hp oil free motor delivers the power you need to get the job done while keeping the work area free of contaminants Triple balance design provides balance with low vibration for superior control Adjustable speed regulator with safety shut off for maximum control The 6" high quality sander with 0.3 HP motor has the best power to weight ratio in its class. It's compact and lightweight, which means better productivity with less fatigue.? It features a 5mm orbit for standard finishing operations with low noise and vibration for superior control.? Free speed: 12,000 RPM; average air consumption: 8.3 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 76; weight: 1.7 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 7inch Heavy Duty Air Angle Grinder - CPT857
518.09
518.09
Powerful 1.25 hp high performance motor for fast metal removalAluminum alloy housing is rugged, yet lightweightSpiral bevel gearing in angle head for long tool life and low vibrationRemovable side handle for increased maneuverabilityUse with 7" type 27 grinding wheels for cleaning, deburring, blending and smoothing Spindle size: 1/4"; wheel size: 7"; free speed: 7500 RPM; average air consumption: 6 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 102; length: 13.13"; weight: 6.25 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 7inch Heavy Duty Angle Air Sander - CPT869S
317.99
317.99
Powerful 1 hp motorContoured throttle control for easy handlingDead handle mounts on either side for right or left hand operationHardened and ground spiral bevel gears for low vibration and long lifeWith up to 5,000 RPM of free speed, you can work faster on heavy rust removal, sanding of metal and shaping of contoured filler patches Pade size diameter: 7"; free speed: 5000 RPM; average air consumption: 13.25 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 100. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Chicago Pneumatic 7inch Heavy Duty Vertical Air Sander - CPT865S
294.79
294.79
Rugged 1 hp motor Automatic release throttle with positive stop actionMuffled handle exhaust to vent air away from work surfacePerfect for roughing in body filler, weld smoothing, paint and rust removal Pad size diameter: 7"; free speed: 5000 RPM; average air consumption: 11.25 cfm; air inlet thread: 1/4" NPTF; minimum hose size: 3/8"; sound dBA: 87. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Page (3 of 6)
1 2 3 4 5 6 |
